STM32固件库NVIC疑问
4527|1
 楼主| auzxj 发表于 2009-8-21 17:27 | 显示全部楼层 |阅读模式
固件库中有这么一段:
NVIC_InitTypeDef NVIC_InitStructure;
/* Configure the Priority Grouping with 1 bit */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
/* Enable TIM3 global interrupt with Preemption Priority 0 and Sub
Priority as 2 */
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_InitStructure(&NVIC_InitStructure);
/* Enable USART1 global interrupt with Preemption Priority 1 and Sub
Priority as 5 */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 5;
/* Enable RTC global interrupt with Preemption Priority 1 and Sub
Priority as 7 */
NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 7;
/* Enable EXTI4 interrupt with Preemption Priority 1 and Sub
Priority as 7 */
NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQChannel;
/* TIM3 interrupt priority is higher than USART1, RTC and EXTI4
interrupts priorities. USART1 interrupt priority is higher than RTC
and EXTI4 interrupts priorities. RTC interrupt priority is higher
than EXTI4 interrupt prioriy. */
问题:
RTC,EXTI4的NVIC_IRQChannelPreemptionPriority和NVIC_IRQChannelCmd为什么没有设置
香水城 发表于 2009-8-21 17:40 | 显示全部楼层
在设置RTC和EXTI4的NVIC之前,已经设置了USART1的参数:
这里已经设置了NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1,在函数NVIC_InitStructure中并没有改变这个变量的数值,所以随后的RTC和EXTI4部分省略了一条语句。
我不认为这是一个好的办法,因为它减低了程序的可读性和可移植性,却可以减小程序代码量,但是不推荐大家这样做,除非你非常清楚你在做什么。
个人签名:當我不如意時.我掏出小JJ.凝視靜思他所蘊涵的精神-能長能短.能粗能細.能曲能伸.能軟能硬.那困難還算個鳥?
629
