【xnwxq】实现对INI文件格式及其操作代码
2339|0
xnwxq|  楼主 | 2009-8-23 14:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本模块主要用于软件的开发!
INI文件格式如下:
[Database]
server=wlq
database=mydatabase
uid=sa
pwd=123456
说明:(有4个key)
Section为:Database
Key为:server database uid pwd
/***************代码******************/
using System;
using System.IO;
using System.Runtime.InteropServices;
using System.Text;
namespace Sx_Mdi
/// <summary>
/// Summary description for Class1.
/// </summary>
public class IniFile
//文件INI名称
public string Path;
////声明读写INI文件的API函数
[DllImport("kernel32")]
private static extern long WritePrivateProfileString(string section,string key,string val,string filePath);
private static extern int GetPrivateProfileString(string section,string key,string def,StringBuilder retVal,int size,string filePath);
//类的构造函数,传递INI文件名
public IniFile(string inipath)
// TODO: Add constructor logic here
Path = inipath;
//写INI文件
public void IniWriteValue(string Section,string Key,string Value)
WritePrivateProfileString(Section,Key,Value,this.Path);
//读取INI文件指定
public string IniReadValue(string Section,string Key)
StringBuilder temp = new StringBuilder(255);
int i = GetPrivateProfileString(Section,Key,"",temp,255,this.Path);
return temp.ToString();
操作范例:
public static SqlConnection MyConnection()
string sPath;
string ServerName,userId,sPwd,DataName;
sPath = GetPath();
IniFile ini = new IniFile(sPath);
ServerName = ini.IniReadValue ("Database","server");
userId = ini.IniReadValue ("Database","uid");
sPwd = ini.IniReadValue ("Database","pwd");
DataName = ini.IniReadValue ("Database","database");
string strSql = "server =" + ServerName+";uid ="+ userId +";pwd =;database ="+ DataName;
    SqlConnection myConn="new" SqlConnection(strSql);
    return myConn;
