[STM8]
用ST的stm8sfwlib例程(eeprom)编译时,出现这么多错误?
4542|0
guanjf222|  楼主 | 2009-8-23 18:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _NonHandledInterrupt not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _TRAP_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _TLI_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _AWU_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _CLK_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _EXTI_PORTA_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _EXTI_PORTB_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _EXTI_PORTC_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _EXTI_PORTD_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _EXTI_PORTE_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _CAN_RX_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _CAN_TX_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _SPI_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _TIM1_UPD_OVF_TRG_BRK_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _TIM1_CAP_COM_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _TIM2_UPD_OVF_BRK_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _TIM2_CAP_COM_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _TIM3_UPD_OVF_BRK_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _TIM3_CAP_COM_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _UART1_TX_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _UART1_RX_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _I2C_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _UART3_TX_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _UART3_RX_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _ADC2_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _TIM4_UPD_OVF_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _EEPROM_EEC_IRQHandler not defined (Debug\stm8_interrupt_vector.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _FLASH_SetProgrammingTime not defined (Debug\main.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _FLASH_Unlock not defined (Debug\main.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _FLASH_ProgramBlock not defined (Debug\main.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _FLASH_EraseBlock not defined (Debug\main.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _FLASH_WaitForLastOperation not defined (Debug\main.o )
#error clnk Debug\jf1_eep_pro.lkf:1 symbol _FLASH_ReadByte not defined (Debug\main.o )
The command: "clnk -m Debug\jf1_eep_pro.map -lE:\COSMIC\CXSTM8\Lib  -o Debug\jf1_eep_pro.sm8 Debug\jf1_eep_pro.lkf " has failed, the returned value is: 1
exit code=1.
jf1_eep_pro.elf - 35 error(s), 0 warning(s)
