[技术问题解答] 最近想做s12dxp512的can下载程序,AN4258SW例子里不支持啊,有没有人做过
1508|0
 楼主| wang1216 发表于 2016-1-27 17:12 | 显示全部楼层 |阅读模式
如题!如下面代码没有s12xd的支持,强行使用s12xe的部分连擦除都不能完成,郁闷中!!!忘大神指点一二!!!!
switch (PARTID)
          //S12XS 256k flash
          case MASK_0M05M:
                if (!((ProgSRec.LoadAddr >= 0x7C0000UL) && (ProgSRec.LoadAddr <= 0x7FEFDFUL)))
                  return(SRecRangeError);
                break;
          //S12XS 128k flash
          case MASK_0M04M:  //Falling to next case
          case MASK_1M04M:
                if (!((ProgSRec.LoadAddr >= 0x7E0000UL) && (ProgSRec.LoadAddr <= 0x7FEFDFUL)))
                break;
          //S12XE 1024k flash
          case MASK_0M48H:  //Falling to next case
          case MASK_1M48H:  //Falling to next case
          case MASK_2M48H:  //Falling to next case
          case MASK_3M48H:  //Falling to next case
          case MASK_4M48H_5M48H:
                if (!((ProgSRec.LoadAddr >= 0x700000UL) && (ProgSRec.LoadAddr <= 0x7FEFDFUL)))
                break;
          //S12XE, S12XF 512k flash
          case MASK_0M25J:  //Falling to next case
          case MASK_1M25J:  //Falling to next case
          case MASK_2M25J_3M25J:  //Falling to next case
          case MASK_1M64J_2M64J:
                if (!((ProgSRec.LoadAddr >= 0x780000UL) && (ProgSRec.LoadAddr <= 0x7FEFDFUL)))
                break;
          //S12XE 256k flash
          case MASK_0M53J:  //Falling to next case
          case MASK_1M53J_2M53J:
                if (!((ProgSRec.LoadAddr >= 0x780000UL) && (ProgSRec.LoadAddr <= 0x79FFFFUL)) && \
                break;
          default:
                return(UnknownPartID);
        //address is OK, program the record to flash
        if(Error = PFlash_Program(ProgSRec.LoadAddr, (UINT16 *)&ProgSRec.Data))
          return(Error);
        if(Error = PFlash_Program(ProgSRec.LoadAddr+8, (UINT16 *)&ProgSRec.Data[8]))
          return(Error);
        if(Error = PFlash_Program(ProgSRec.LoadAddr+16, (UINT16 *)&ProgSRec.Data[16]))
          return(Error);
        if(Error = PFlash_Program(ProgSRec.LoadAddr+24, (UINT16 *)&ProgSRec.Data[24]))
          return(Error);
