请问数字示波器100MS/S的采样率能做到多少MHz的带宽?
3790|6
xwj| | 2007-11-23 23:58 | 只看该作者
根据奈奎斯特采样定律最多50MHz,但这时的波形都是方波了
而且此时混叠现象严重
要想波形显示出来象正弦波,只能最多10MHz
edanzg|  楼主 | 2007-11-24 00:57 | 只看该作者
Lecroy 9400A(老古董,停产了)示波器做到了175M
The 9400A’s  two identical  input  channels  are equipped  with a
I00 megasample/second (megasample/sec), 8-bit ADC and a 32 kiloword
acquisition memory (See Figure 2.1). This dual ADC architecture ensures
absolute amplitude and phase correlation, maximum ADC performance for
both single and dual channel acquisition modes, large record lengths
and high time resolution.
The 9400A’s two 32K acquisition memories simplify transient capture by
providing very long waveform records that capture waveform features
even when trigger timing is uncertain. In addition, very accurate time
measurement is made possible by a digitally controlled zoom providing
an expansion factor of up to I00 times the time base speed.
The  9400A  oscilloscope  is  capable  of  acquiring  and  storing  repetitive
signals  at  a  Random  Interleaved  Sampling  rate  of  5  gigasamples/second
(gigasamples/sec).  An  exclusive  high-precision  time  digitizing
technique  enables  measurement  of  repetitive  signals  to  a  bandwidth  of 175  MHz at  an  effective  measuring  interval  of  200  psec.
当然,上面也说了是重复信号,
jmu2001| | 2007-11-25 01:35 | 只看该作者
hehe
   谈论带宽,不要离开信号呀,就是需要测试的信号!
王紫豪| | 2007-11-26 11:03 | 只看该作者
你要是等效采样做好的话,带宽可以高于采样率!
不过:
高速采样好做,高的带宽就难鸟。。。
edanzg|  楼主 | 2007-11-26 20:58 | 只看该作者
呵呵,我打算买回来看看,就是太笨重了。
whnzcm| | 2007-12-10 16:56 | 只看该作者
直流耦合
是直流耦合,看来我得给你们上上课了。
