[应用相关] 请香主帮看下!!!
2705|2
 楼主| LiangXinJi 发表于 2009-8-26 19:17 | 显示全部楼层 |阅读模式
sd, IO, ST, se, ni
if (errorstatus == SD_OK)
    /* SD CARD */
    /* Send ACMD41 SD_APP_OP_COND with Argument 0x80100000 */
                                              //0x40000000
    while ((!validvoltage) && (count < SD_MAX_VOLT_TRIAL))
      /* SEND CMD55 APP_CMD with RCA as 0 */
      SDIO_CmdInitStructure.SDIO_Argument = 0x00;
      SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_APP_CMD;
      SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;
      SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;
      SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;
      SDIO_SendCommand(&SDIO_CmdInitStructure);
      errorstatus = CmdResp1Error(SDIO_APP_CMD);
      if (errorstatus != SD_OK)
        return(errorstatus);
      SDIO_CmdInitStructure.SDIO_Argument = SD_VOLTAGE_WINDOW_SD | SDType;
      SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_SD_APP_OP_COND;
      errorstatus = CmdResp3Error();
      response = SDIO_GetResponse(SDIO_RESP1);
      validvoltage = (bool) (((response >> 31) == 1) ? 1 : 0);
      count++;
    if (count >= SD_MAX_VOLT_TRIAL)
      errorstatus = SD_INVALID_VOLTRANGE;
    if (response &= SD_HIGH_CAPACITY)
      CardType = SDIO_HIGH_CAPACITY_SD_CARD;
  }/* else MMC Card */
这是万利399元STM32开发板中关于SDIO BUS操作SD卡的例子中的一段代码,但是有点不明白,
发送 ACMD41命令 ,回复应是R3  "errorstatus = CmdResp3Error();
"但后面有是“response = SDIO_GetResponse(SDIO_RESP1);”有点不理解。
还有就是为什么要“while ((!validvoltage) && (count < SD_MAX_VOLT_TRIAL))”
请香主帮我解释下,谢谢了!!
香主辛苦了!
香水城 发表于 2009-8-26 21:59 | 显示全部楼层
对不起,我没有研究过这个程序。
 楼主| LiangXinJi 发表于 2009-8-26 22:35 | 显示全部楼层
研究了SD接口规范,和STM32参考手册好几遍,都没整明白!
哎,那位整过,帮我看看!
小弟在此万分感谢!
