AD7705双通道的问题
2660|0
 楼主| richardji 发表于 2009-8-30 09:43 | 显示全部楼层 |阅读模式
使用AD7705采集两路模拟信号,总是只能正确读取一路信号,另一路错误,不知道是什么原因,把相关代码贴上来,麻烦大家给看看.
void reset_AD7705(void)
  u8 i;
  AD_RESET_LOW;
  Delay(5);
  AD_RESET_HIGH;
  AD_CS_LOW;
  AD_DIN_HIGH;
  for(i=0;i<100;i++)
    write_AD7705_byte(0xff); //持续DIN高电平写操作,恢复AD7705接口
  Delay(3000);  // 1000us
void AD7705_Init(void)
  AD7705_IO_Configuration();
  reset_AD7705();
  write_AD7705_byte(0x20);       //通道1,下一个写时钟寄存器
  write_AD7705_byte(0x00);       //写时钟寄存器设置更新速率为20hz
  write_AD7705_byte(0x10);       //通道1,下一个写设置寄存器
  write_AD7705_byte(0x46);       //自校准,增益1,单极极,缓冲
  Delay(3000);                  //延时1000us
  write_AD7705_byte(0x21);       //通道2,下一个写时钟寄存器
  write_AD7705_byte(0x11);       //通道2,下一个写设置寄存器
  write_AD7705_byte(0x46);       //自校准,增益1,单极性,缓冲
  Delay(3000);
u16 read_AD7705_word(void)
  u16 data = 0;
  for( u8 i=0; i<16; i++)
    AD_CLK_LOW;
    Delay(24);
    data <<= 1;
    if(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_6) == (BitAction)(1)) // APIO_Pin_6  AD_DOUT
      data++;
    AD_CLK_HIGH;
    Delay(24);
  return data;
void write_AD7705_byte( u8 data )
  for( u8 i=0; i<8; i++)
    AD_CLK_LOW;
    if(data&0x80)
      AD_DIN_HIGH;
    else
      AD_DIN_LOW;
    data <<= 1;
    Delay(24);
    AD_CLK_HIGH;
    Delay(24);
  AD_DIN_HIGH;//在空闲器件保持输入数据线为高
