用CuteFTP也还是一样,信息如下:
*** CuteFTP 8.3 - build Aug 25 2008 ***
状态:> [2009-9-6 9:36:27] 正在获取列表“”...
状态:> [2009-9-6 9:36:27] 正在解析主机名 ftp.21ic.com...
状态:> [2009-9-6 9:36:30] 已解析主机名 ftp.21ic.com: ip = 121.52.216.118。
状态:> [2009-9-6 9:36:30] 正在连接到 FTP 服务器... ftp.21ic.com:21 (ip = 121.52.216.118)...
状态:> [2009-9-6 9:36:30] Socket 已连接。正在等候欢迎消息...
[2009-9-6 9:36:34] 220 Serv-U FTP Server v5.0 for WinSock ready...
状态:> [2009-9-6 9:36:34] 已连接。正在验证...
命令:> [2009-9-6 9:36:34] USER 21icuser
[2009-9-6 9:36:35] 331 User name okay, need password.
命令:> [2009-9-6 9:36:35] PASS *****
[2009-9-6 9:36:36] 230 User logged in, proceed.
状态:> [2009-9-6 9:36:36] 登录成功。
命令:> [2009-9-6 9:36:36] PWD
[2009-9-6 9:36:36] 257 "/" is current directory.
状态:> [2009-9-6 9:36:36] 主目录: /
命令:> [2009-9-6 9:36:36] FEAT
[2009-9-6 9:36:41] 仅仅信息消息:
211-Extension supported
CLNT
MDTM
MDTM YYYYMMDDHHMMSS[+-TZ];filename
SIZE
SITE PSWD;EXEC;SET;INDEX;ZONE;CHMOD;MSG
REST STREAM
XCRC filename;start;end
211 End
状态:> [2009-9-6 9:36:41] 该站点支持 features。
状态:> [2009-9-6 9:36:41] 该站点支持 XCRC。
状态:> [2009-9-6 9:36:41] 该站点支持 SIZE。
状态:> [2009-9-6 9:36:41] 该站点可以续传中断的下载。
命令:> [2009-9-6 9:36:41] REST 0
[2009-9-6 9:36:42] 350 Restarting at 0. Send STORE or RETRIEVE.
命令:> [2009-9-6 9:36:42] PORT xxx,xxx,x,xxx,18,116
[2009-9-6 9:36:42] 200 PORT Command successful.
命令:> [2009-9-6 9:36:42] LIST
[2009-9-6 9:36:43] 150 Opening ASCII mode data connection for /bin/ls.
错误:> [2009-9-6 9:37:14] 接受来自服务器的数据连接时发生超时(30000 毫秒)。
[2009-9-6 9:37:15] 426 Data connection closed, transfer aborted.
错误:> [2009-9-6 9:37:15] 接收到无效应答。
