STM32 ADC多通道采集奇怪问题
6696|5
 楼主| jie841010 发表于 2009-9-5 19:25 | 显示全部楼层 |阅读模式
我现采集六个ADC通道,用DMA进行传输,但一段时间后,发现所采集到的数据顺序会乱跳,程序如下,请各位大侠指点一下小弟哪里出错了!谢谢
代码如下:
void ADCConfig(void)
/* DMA channel1 configuration ----------------------------------------------*/
  DMA_DeInit(DMA_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 6;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA_Channel1, &DMA_InitStructure);
  /* Enable DMA channel1 */
  DMA_Cmd(DMA_Channel1, ENABLE);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 6;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel14 configuration */
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 1, ADC_SampleTime_239Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 2, ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 3, ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 4, ADC_SampleTime_239Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 5, ADC_SampleTime_239Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 6, ADC_SampleTime_239Cycles5);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
午夜霓虹 发表于 2009-9-5 19:36 | 显示全部楼层
呵呵 好多人遇到过了,没解决呢。你是调试的时候出现的,还是正常运行就这样了。
 楼主| jie841010 发表于 2009-9-5 20:07 | 显示全部楼层
已解决
午夜霓虹 发表于 2009-9-6 13:03 | 显示全部楼层
哈哈,希望是真的解决了,因为这个问题出了很多次,也许你该说一下造成的原因.
jinjing999 发表于 2009-9-7 10:47 | 显示全部楼层
我遇到过
规则传送和注入规则同时用会出问题
菜鸟宅男 发表于 2013-8-31 15:28 | 显示全部楼层
LZ不厚道啊,解决了也不让大伙明白
