MDK仿真GD103RBT6,为何有那么多错误?如何解决??
1633|2
 楼主| tdnx611g 发表于 2016-2-2 12:34 | 显示全部楼层 |阅读模式
***JLink Error: Can not read register 3 (R3) while CPU is running
***JLink Error: Can not read register 4 (R4) while CPU is running
***JLink Error: Can not read register 5 (R5) while CPU is running
***JLink Error: Can not read register 6 (R6) while CPU is running
***JLink Error: Can not read register 7 (R7) while CPU is running
***JLink Error: Can not read register 8 (R8) while CPU is running
***JLink Error: Can not read register 9 (R9) while CPU is running
***JLink Error: Can not read register 10 (R10) while CPU is running
***JLink Error: Can not read register 11 (R11) while CPU is running
***JLink Error: Can not read register 12 (R12) while CPU is running
***JLink Error: Can not read register 13 (R13) while CPU is running
***JLink Error: Can not read register 14 (R14) while CPU is running
***JLink Error: Can not read register 15 (R15) while CPU is running
***JLink Error: Can not read register 16 (XPSR) while CPU is running
pengxiao618 发表于 2016-2-2 16:55 | 显示全部楼层
只有在halt cpu的情况下才能获取内核寄存器。检查一下是不是MCU有问题了
vivilzb1985 发表于 2016-2-16 14:34 | 显示全部楼层
这是相关寄存器的都没配置好的。
