[STM8] STM8 PWM输入捕捉完成程序
1717|17
 楼主| 侠行江湖 发表于 2016-2-2 16:42 | 显示全部楼层 |阅读模式
PWM, STM8, TI, ic, pi
大家好,最近在做一个项目关于PWM输入捕捉的,使用的单片机为STM8S105,我在用STM8的输入捕捉功能 利用库函数TIME1 CH1 捕捉PE0的频率 很准,但是我在此程序基础上将PE0口的频率 改为由 TIME2 产生,同样使用TIME1 CH1 捕捉,捕捉到的频率不对是怎么回事? TIME2 产生的PWM 用示波器测试很准的 望高手指点,谢谢!!!!!!
库函数捕捉程序如下:
void main(void)
  TIM1_Channel = TIM1_CHANNEL_1
  TIM1_ICPolarity = TIM1_ICPOLARITY_FALLING
  TIM1_ICSelection = TIM1_ICSELECTION_DIRECTTI
  TIM1_ICPrescaler = TIM1_ICPSC_DIV8
  TIM1_ICFilter = 0x0
  TIM1_ICInit( TIM1_CHANNEL_1, TIM1_ICPOLARITY_FALLING, TIM1_ICSELECTION_DIRECTTI,  TIM1_ICPSC_DIV8, 0x0);
  TIM1_ITConfig(TIM1_IT_CC1, ENABLE);
   /* Enable TIM1 */
  TIM1_Cmd(ENABLE);
   /* Clear CC1 Flag*/
  TIM1_ClearFlag(TIM1_FLAG_CC1);
   /* Connect LSI to COO pin*/
  GPIO_Init(GPIOE, GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);
  CLK_CCOConfig(CLK_OUTPUT_LSI);
  CLK_CCOCmd(ENABLE);
  /* wait a capture on CC1 */
  while((TIM1->SR1 & TIM1_FLAG_CC1) != TIM1_FLAG_CC1);
  /* Get CCR1 value*/
        ICValue1 = TIM1_GetCapture1();
        /* wait a capture on cc1 */
  /* Get CCR1 value*/
        ICValue2 = TIM1_GetCapture1();
  /* Compute LSI clock frequency */
  LSIClockFreq = (8 * TIM1ClockFreq) / (ICValue2 - ICValue1);
/* Insert a break point here */
        while (1);
在此库函数基础上,改为TIME2产生PWM程序如下,
void init_hsiclk(void)
CLK_DeInit(); //寄存器复位
CLK_HSICmd(ENABLE); //内部高速时钟使能
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); //内部分频 2M
void TIM2_init(void)
  TIM2_TimeBaseInit(TIM2_PRESCALER_16, 6665);
  TIM2_OC3Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,CCR3_Val, TIM2_OCPOLARITY_HIGH);
  TIM2_OC3PreloadConfig(ENABLE);
  TIM2_ARRPreloadConfig(ENABLE);
  TIM2_Cmd(ENABLE);
void main(void)
  //CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);//主时钟16/16=1MHZ   4分频
        init_hsiclk();
        GPIO_Init(TIME2PWMOUT_PORT, TIME2PWMOUT_PIN , GPIO_MODE_OUT_PP_LOW_FAST);     //设置PA3端口为推挽输出模式
        GPIO_Init(TIME1PWMIN_PORT , TIME1PWMIN_PIN, GPIO_MODE_IN_FL_NO_IT);
  TIM2_init();
        /* Enable CC1 interrupt */
        /* Enable TIM1 */
  TIM1_Cmd(ENABLE);
        /* Clear CC1 Flag*/
//GPIO_Init(GPIOE, GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);    //不使用
        //CLK_CCOConfig(CLK_OUTPUT_LSI);
        //CLK_CCOCmd(ENABLE);
  /* Get CCR1 value*/
  /* Get CCR1 value*/
        while (1);
ccw1986 发表于 2016-2-2 21:04 | 显示全部楼层
你是用示波器测的吗,用定时准吗
 楼主| 侠行江湖 发表于 2016-2-2 21:08 | 显示全部楼层
你是用示波器测的吗,用定时准吗
我是用示波器测试,测试输出的PWM波 150HZ 很准的 ,现在就是搞不清楚问题出在哪里了
 楼主| 侠行江湖 发表于 2016-2-2 21:09 | 显示全部楼层
你是用示波器测的吗,用定时准吗
定时我倒没有用,只产生PWM
xmshao 发表于 2016-2-3 17:10 | 显示全部楼层
会不会太久发生溢出了?你把T2的输出频率抬高测试下
 楼主| 侠行江湖 发表于 2016-2-4 10:49 | 显示全部楼层
兄弟 太感谢了  刚才我试了一下 把原来测频率由150HZ 抬高到2.4KHZ  测试的参数果然准确了
 楼主| 侠行江湖 发表于 2016-2-4 10:50 | 显示全部楼层
低频太久溢出, 有什么好的解决办法没?
shangwei4444 发表于 2016-2-4 15:13 | 显示全部楼层
TIM1分频行不,丢点精度。
 楼主| 侠行江湖 发表于 2016-2-8 15:52 | 显示全部楼层
丢点精度是什么意思?
lovecat2015 发表于 2016-2-10 13:49 | 显示全部楼层
用的是定时器2,挺好用的
有例程吗,发我一份pjzmj2012@163.com  发表于 2016-5-25 10:52
xmshao 发表于 2016-2-17 10:37 | 显示全部楼层
兄弟 太感谢了  刚才我试了一下 把原来测频率由150HZ 抬高到2.4KHZ  测试的参数果然准确了 ...
不必客气。 找到原因了,解决办法也就应该可以有了啊。呵呵
你计数器发生了溢出,那你可以将计数频率做适当的分频。
xmshao 发表于 2016-2-21 18:11 | 显示全部楼层
 楼主| 侠行江湖 发表于 2016-2-26 11:43 | 显示全部楼层
这里有个详细分析,可以看看。
http://mp.weixin.qq.com/s?__biz=MzA3OTIxMjQyNQ==&mid=402370099&idx=1&sn ...
谢谢,shao兄的回复 。问题已经找到了
deviceplugs 发表于 2016-2-26 22:03 | 显示全部楼层
定时器能够正常工作吗
拉克丝 发表于 2016-2-27 20:20 | 显示全部楼层
把T2的输出频率抬高试试
gejigeji521 发表于 2016-3-9 11:23 | 显示全部楼层
官方提供的例程里貌似有这个捕获的例程,为何不参考一下呢,有库函数版本的,也有寄存器版本的。
