供应HP PCI
1776|0
xxjpj2009|  楼主 | 2009-9-9 10:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
hp, PCI, TE, se, AN
公司提供小型机、服务器、工作站、存储设备、外设、CPU 内存 硬盘 电源 存储设备 控制卡 升级选件、维修配件(HP、IBM、EMC)等
联系人:李先生    联系电话:010-88147562
PCI-SCSI3,DIFF ULTRA/WIDE A4800-69002 (HVD)
    Internal Terminator    1252-6520
Single Port Ultra2 SCSI   A5149-69101 (LVD)   A, L, N, V2500  (No Exchange Part)
Single Port Ultra160 SCSI A6828-60101             A6828A (no A180 and V-Class Support !)
Dual Port Ultra2 SCSI     A5150-69101 (LVD)   A, L, N, V2500
Dual Port Ultra160 SCSI   A6829-60001             HPUX/Win/Linux A6829A (no A180 and V-Class Support !)
Dual Port Ultra320 SCSI   A6961-60011             A7173A (no A180 and V-Class Support !)
  (EFI Rom onboard)
Dual Port F/W-SCSI-2              A5159-60001 (HVD)   A, L, N, V2500,
                                                  A5159-69001 cannot be ordered!
Dual Port F/W-SCSI-2              A5159B                  For Itanium use Version B only!
  (B has EFI ROM)
2 port 100BT/2 port Ultra2          A5838-69101 (LVD)     A, L, N-Class (no boot on vpars)
2 Port GigE/2 port U320         AB290-69001
Ultra 160 SCSI HBA (A7059A) A6828-60101 Win/Linux
2-port Ultra 160 SCSI HBA (A6829A) A6829-60101 Win/Linux/HPUX
2-port Ultra 160 SCSI HBA (A7060A) A6829-60101 Win/Linux
2-port Ultra 320 SCSI HBA (A7060A)      A6961-60011     HP-UX/Win/OVMS/Linux
Raid 4Si PCI 4-Port Ultra-2 RAID        A5856-69101 (LVD)     L,N-Class
4-channel Ultra 160 RAID (A7143A)  A7143-69001
SA6402 (A9890A)  (A9890-69001 no longer orderable)
SA6400 Base board, 2 SCSI CH.     309520-001
128MB battery buffered cache      309521-001
SA6404 (A9891A)  (A9891-69001 no longer orderable)
256MB battery buffered cache      309522-001
SA6400 2 CH. SCSI extension       309523-001
Smart Array SA5302 (A9825A)             335891-001
Alternative order "red" parts :
sa5302 171383-001
128mb cache                       171387-001
Smart Array SA5304 (A9826A)             345334-001
sa5302 171383-001
2 CH SCSI expansion card                171384-001
256mb cache 262012-001
NetRAID-2m (P7749A)                     P7749-67001
alternative order P3475-69004, but this needs FW update !
PCI-10/100 BASE LAN ADAPTOR A3738-69001           BNC,RJ45,AUI
1-port PCI 100Base-T adpt.  B5509-66001           A, L, N-Class only, A5230A
4 Port 100BaseTX LAN        A5506-69101   A, N, L-Class       A5506A
                                                  (PHKL_20994 and 39.46)
4 Port 100BaseTX LAN        A5506-69102   A, N, L-Class       A5506B
                                                  PHNE_21887  min. DART 50 (Sep 2000)
1000 BaseSX Single Port     A4926-60001   L, N, V-Class (fibre)
1000 BaseSX Single Port     A6847-67101   A400,A500,L,N,rp7410,rp8400,Superdome
                                                  one duplex SC fibre connector
                                                  (NOTE: Driver is igelan)
                                                  rx-System with Linux: BCM5701 Gigabit Ethernet
1000 BaseT  Single Port     A6825-67101           A400,A500,L,N,rp7410,rp8400,Superdome
                                                  RJ45 connector
1000 BASE-T ADAPTER         A4929-69001           A, L, N, V-Class
                                                  (RJ45, 10/100/1000 BaseT)
PCI-X 2GB FC/1000BASE-SX HB A9782-69001           A9782A
PCI-X 2G FC/1000Base-T HBA  A9784-69001           A9784A
PCI-FDDI DUAL ATTACH LAN    A3739-69001
SC-MIC ADAPTER CABLE 0.3m   A4700-67073
802.5 Token Ring LAN     A5783-60001   A, L, N, V-Class
1000Base-T HBA (A7061A)     A6825-6710   Win/Linux
1000Base-SX HBA (A7073A)    A6847-67101           Win/Linux
2-port 1000Base-SX (A7011A) A7011-69001   Win/Linux
2-port 1000Base-T  (A7012A) A7012-67001   Win/Linux
PCI-FIBRE CHANNEL 1062Mbs   A3740-69101           FC-AL
PCI-Fibre Channel           A3726-69006           V-Class only !! (S/N A3725A-46)
PCI-FIBRE CHANNEL -fabric-  A5158-69001           FC SAN
PCI 2GBps FC-Adapter (A6795A)  A6795-69001
PCI 2GBps Dual Port FC (A6826A) A6826-69001
PCI-X 2GB FC/1000BASE-SX HB (A9782A) A9782-69001
PCI-X 2G FC/1000Base-T HBA (A9784A) A9784-69001
PCI-X 2GB FC Emulex LP982 (A7298A) A7298-69001       Windows
PCI-X 2GB FC Emulex LP9802 (AB232A)     313045-002       Windows
PCI-X 2GB FC Emulex LP1050 (AB466A)   366028-001       Windows
PCI-X 2GB FC Emulex LP1050 (AB467A) 366027-001       Windows
PCI-x 2GB FC QLOGIC QLA2340 (A7538A)    A7538-69001           LINUX
Hyperfabric Interconnect    A4919-69001   N-Class, V-Class
Hyperfabric Loopback Cable  A4919-63001
HyperFabric2 Fiber Adapter (A6386A) A6386-69001
2 Port X.25 Interface Card  J3525-69101   L, N, V-Class, Matterhorn, Keystone, Superdome, rx2600, rx5670
4 Port X.25 Interface Card  5063-1322   L, N, V-Class, Matterhorn, Keystone, Superdome
+++ HIPPI +++++++++++++++++++++++++++++
PCI Serial HIPPI-800        A5801-69001
PCI ATM 155Mbps MMF Adapter (A5513A)  A5513-69002
2-port 4X Infinband HBA (AB286A)   AB286-69001
PCI  8 port MUX            A6748-69001  (old part J3592-69101) A, L, N, V, Keystone, Superdome
PCI 64 port MUX            A6749-69001  (old part J3593-69001) A, L, N, V, Keystone, Superdome
Use J3592/J3593 if available, else use the new parts A6748A / A6749A
(see http://wwwtpec.grenoble.hp.com/l ... n/psp/8/psp8435.htm
for more details)
16 Port RS232 RJ45 Module   J2484-69010   A, L, N, V-Class
16 Port RS232 DB25 Module   J2485-69010
16 Port RS422 RJ45 Module   J2501-69010   A, L, N, V-Class
RJ45 to HP-RJ45 converters  J2488A
RJ45 to HP-DB25 converters  J3830A
25feet cable to port module J3595-63001
MUX card Port Module cable  J2483-60013
PCI USB Card                A6150-60001
PCI Graphics Card           A6150-60002           Achtung!! Das angeschlossene Grafikterminal kann
                                                  NICHT als Systemconsole genutzt werden (not supported!)
HP Open VMS 3D/2D PCI Graphic Card (AB551A)       30-10119-01
Card, Graphics for Itanium Systems (A6869A)   A6869-67501
