HP 12H
1672|0
 楼主| xxjpj2009 发表于 2009-9-10 09:34 | 显示全部楼层 |阅读模式
HP 12H
A3515-69001 Backplane Assembly
A3517-69004 2 Gbyte LP Disk Module 7200 SE
A3646-69003 4 Gbyte LP Disk Module 7200 SE
A3319-69001 4 Gbyte HH Disk Module 7200 SE, ONLY FOR OEM!!!
A3518-69001 Controller Module 24 MB (firmware HP02)
A3518-69002 Controller Module 24 MB (firmware HP11)
A3518-69003 Controller Module 24 MB (firmware HP15)
A3518-69004 Controller Module 24 MB (firmware HP25)
A3538-69003 Power Supply Module
Model 12H // A3700A / A3700AZ / A3700AD
Part Number Description
A3702-69003 4.3 GB Disk Module  7200 rpm ID:   ST34371N & ST34572WC & ST34573WC
A3703-69002 9.1 GB Disk Module  7200 rpm ID:   ST19171N & ST39173WC
A3713-69002 9.1 GB Disk Module   10k rpm ID:  ST39102LC
A3710-69001 18,2 GB Disk Module 7200 rpm ID: ST118273WC & ST318275LC
A3714-69002 18,2 GB Disk Module  10k rpm ID: ST118202LC & ST318203LC & ST318404LC
A5289-69001 36 GB Disk Module   7200 rpm ID: ST136475LW
A5292-69002 36 GB Disk Module    10k rpm ID: ST136403LC & ST336704LC
A6518-69001     36 GB Disk Module    10K rpm ID: ???
A3706-69001 96 MB Controller (firmware HP06)
A3706-69002 96 MB Controller (firmware HP24)
A3706-69003 96 MB Controller (firmware HP32)
A3706-69004 96 MB Controller (firmware HP54)
A3706-69005 96 MB Controller (firmware HP56)
A3706-69006 96 MB Controller (firmware HP60)
A3706-69107 96 MB Controller (firmware HP62)   Only this can be ordered!!!!
A3708-69002 Power Supply Module
MISC PARTS
Model 12 // A3515A / A3516A / A3516AZ
  0515-1457 T-15 M4x0.7 mm Torx Screw
  0515-2270 T-15 M4x0.7 16mm Torx Screw
  0535-0028 M3x0.5 Nut w/washer
  0590-0804 6-32 Captive Rack Nuts
  1420-0532 Battery Pack: 2x pro Controller!!!
  2680-0323 T-25 6-32x0.625 Torx Screw
  3050-1141 M3 Flat Washer
  5181-7779 AC Power Adapter
  5181-7789 Security Lock
  5181-7790 Keys (Set of Two)
  5181-7791 T-15 M4x0.7 10mm Torx Screw
C2786-00002 Rack Rail
C2786-40002 Door Snap (Rack mount)
C2786-40003 Rack Mount Door Handle
C3573-40070 Pedestal Base (Deskside)
A3326-67002 Fan Module
C3595-00009 Rack Door Hinge Bracket
C3595-00010 Latch Bracket
C3595-00021 Batter Box Cover
C3595-40003 Top Cover
C3595-40007 Disk, Fan Module Cam Handle
C3595-40009 Push Rod
C3595-40010 Power Switch Push Button
C3595-40015 Left Cover Panel (Deskside)
C3595-40016 Right Cover Panel (Deskside)
C3595-40030 Controller Module Cam Handles
A3516-67002 Front Door (Rack mount)
C3595-40050 Front Door Latch
C3595-60011 LCD Module
A3515-67002 Front Door (Deskside)
C3595-60018 Shipping Package
A3709-60002 Fan Module (High speed fan 10K)/ A3709B
C3595-60141 Battery Box cover
C3595-40043 Battery cover
C3595-40030 Cntlr mod cam hdl
C3595-40010 Push button
C3595-40009 Push rod
C3595-40031 Pwr flapper door
A3700-60100 Gen fr door ass
C5445-60005 A3700 Backplane assy
C5445-60043 A3700 bkpl assy Hrdw
   064-2404 AC power adapter kit
  5064-2405 Door snap kit
C5445-00024 Chassis Hinge bracket
C5445-00025 Chassis Latch bracket
  5064-2406 Hinge/Latch Brk Hdw kit
  5064-2407 Chassis Cam Tooth Kit
C5445-60042 P/S lockout hdw kit
C5445-60027 Display mod assy
C3595-4007 Module cam hdl
