hp rp4440 parts
1945|0
xxjpj2009|  楼主 | 2009-9-10 09:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
hp, TE, AN, pc, BLE
hp rp4440 parts
PCA, CPU Extender               A6961-69007
PCA, IO Baseboard (w VRMs)      A6961-69201   SFW must be greater than 1.13
                                              Switch S5102 (VGA enable) -> off
PCA, 16 Slot Memory Board       A6961-69204   (Multiple SBE dimm replacements = Service Note A6961A-02C/A7124A-02)
PCA, 32 Slot Memory Board       A9739-69007   SFW > 1.13 (old Part-#: A7124-60002 / Service Note A6961A-02C)
PCA, Midplane Riser Board       A6961-67005
PCA, SCSI Duplex Board          A6961-67006
PCA, I/O BD to DVD Connectivity A6961-67013
PCA, Power Distribution Board   A6961-67015
PCA, SCSI Backplane/Management  A6961-67024   (includes SCSI Simplex board)
PCA, Visual Diag Board          A6961-67009
PCA, Front Panel Display        A6961-67008
CPU PA8800 800 MHz 32MB Cache   A7125-69002 (Mako32)
CPU PA8800 1GHz 32MB Cache      A7135-69002 (Mako32)
CPU PA8900 800 MHz 64MB Cache   AB526-69001 (Mako64)
CPU PA8900 1GHz 64MB Cache      AB527-69001 (Mako64)
#Memory 1.7 " Dimms have been replaced with 1.2 " Dimms.
#See WTEC/KMINE 4000076558
***NOTE: IF REPEATED SBE OCCURRED AND DIMMS ALREADY REPLACED MULTIPLE TIMES SEE Service Note A6961A-02C/A7124A-02 ***
256MB DIMM              A6967AX     (do not order A6833-69001 - too high)
512MB DIMM              A6968AX     (do not order A6746-69001 - too high)
***Note: for dimms>=1 GB: PDC>=45.11, BMC>=02.30, see Service Note A7124A-02C !!!
***Memory Carrier must be A7124-60002 or A6961-60004 with EDC>=A-4420
1GB Dimm                A6969-69001   (Product: A6969AX)
2GB Dimm                A6835-69001   (Product: A6970AX)
4GB Dimm AB475-69001   (see info one bottom of page concerning compatibility)
SCSI Card U160 (Core IO) A6829-60101
LAN Card (Core IO)              A6825-67101
CPU Clock Battery 1420-0386
36GB 15K RPM SCSI Disk A9896-69001
73GB 15K RPM SCSI Disk A9897-69001
146GB 10K RPM SCSI Disk A9898-69002
DVD-R/CD-R Drive A7163-04001
DVD-R/CD-RW Drive               A7007-67001
CABLES
Cable, internal SCSI A6961-63006
Cable, Power Distr. to Midplane A6961-63003     10 PIN Cable
Cable, Power Distr. to Midplane A6961-63004     Ribbon Cable
Cable, SCSI Controller Jumper   A6961-63011
Cable, Visual Diag to Midplane  A6961-63005
Cable, SCSI Backpl. to Midplane A6961-63008
Cable, Display to IDE to Midpl. A6961-63002
HPUX USB - to - PS/2 Adapter    A7782-63001
POWER
AC Power Supply 0950-4428
DC-DC Converter (VRM) 12V       0950-4417
DC-DC Converter (VRM) 3.3V      0950-4419
DC-DC Converter (VRM) 5V        0950-4418
IO FAN  (Fan 0 + 1)             A6961-04055
Power Supply Fan (Fan 2)        A6961-04028
PCI Card OL* Divider            A6961-67020
PCI Retention Clip              A6961-67021
Filler, Memory, Air Blocker     A6961-40034
