hp rp7420
1965|0
 楼主| xxjpj2009 发表于 2009-9-10 11:00 | 显示全部楼层 |阅读模式
hp rp7420
Cellboard with PA8800 1GHz Cpus A6913-69107  # all cellboards
Cellboard with PA8800 900MHz A6913-69006  # come with
Cellboard with PA8900 1GHz Cpus A6913-69012  # 4 dual core CPUs
Cellboard with PA8900 1.1GHz  A6913-69013  # mounted on the board
Cell Board Battery (CR2032)     1420-0356    (on PDH Riser Board)
CPU Socket Terminator A6912-60001
Itanium 2 Processor Tool Kit    A7231-67046
System Backplane A6752-69001
PCI-x Card Cage A6093-69013
PCI OLAR ASSY                   A6093-67114
PCI OLAR Gates                  A6093-40041
PCI OLAR Paddle Button Kit      A6093-67014
Disk/Media Backplane A6752-67044
Front Panel Display A6752-67005  with Power Switch&Cable
256MB DIMM                      A6802-69101
512MB DIMM A5198-69101
1GB DIMM A6098-69101
2GB DIMM A6100-69001
4GB DIMM                        AB322-69001
HV VRM 0950-4123    VRM# 7-14 if one of these fails order 8 HV VRMs
LV VRM 0950-4122    VRM# 1-6 & 15 if one of these fails order 7 LV VRMs
PCI-X VRM
MP/SCSI A9918-69001
MP Battery 1420-0356      (CR2032)
Lan/SCSI PCI Card A6794-69001
36GB disk, 15k A9896-69001
73GB disk, 15k A9897-69001    MAU3073NC
146GB disk, 10k A9898-69002
DVD A9879-67001    (old) readonly DVD-ROM 305
DVD RW                          AB351-62001    (new) RW DVD
Internal DDS drive              C5686-69204
SCSI Cable Bundle Assy A6752-63019
Front Panel Display Cable       A6752-63002
System Fan Internal Cable       A6752-67023
System Fan External Cable       A6752-67022
DVD Power Cable                 A6752-67021
Mass Storage Power #1 Cable     A6752-67019
Mass Storage Power #2 Cable     A6752-67020
Main Power Harness              A6752-67025  Special Tool needed
XCELITE "99" Screw Driver       NHPXSCREWDRIVER Tool for Main Power Harness
Instrusion Switch Cable         A6093-63025
Cable Int. Smart Array Contr.   A7027-63001
Fan Front/Rear A6752-67029  cabinet fan# 0-3
Fan PCI A6752-67030  PCI chassis fan# 0-5
PCI Power Modul A6093-69123
Bulk Power Supply A6752-69113
C19/C20,BLK,2.5M-JUMPER CABLE 8121-0802
C19/C20,BLK,4.5M-JUMPER CABLE 8121-0806
MP M-CABLE A6144-63001
Intrusion Switch                5040-6317
ASSY AC Cord Retention Brkt.    A6752-00123
Cellboard Air Baffle Kit        A6913-67005
Removable Media Rail Kit        A6752-67011
DIMM Removal Kit                A5201-68005
DIMM Installer Tool             A5201-68003
Anti Stat Kit w grd strap       A5201-68004
