hp rp8400
 楼主| xxjpj2009 发表于 2009-9-10 11:01 | 显示全部楼层 |阅读模式
hp, AN, se, ST, TE
hp rp8400
SYSTEM BACKPLANE WITH SCREE B. A6093-69301   with new SEU (KIOX) connectors; old part# A6093-69002 may still be used if no SEU is connected
SCREE BOARD                    1253-5394     needed for FW update to rev. >=4.0 - see Service Note A6093A-12A
CELL WITH PDH RISER BOARD      A6094-69103   order also 1 Cleaning Kit
CPU 650MHz WITH SOCKET (2.x)   A6443-69001   order also 1 Cleaning Kit
CPU 750MHz WITH SOCKET         A6444-69001   IMPORTANT NOTE: This part can have version 3.x or 2.x, Firmware Version >=4.0 is required for 3.x.; order also 1 Cleaning Kit
CPU 875MHz WITH SOCKET (3.x)   A6435-69001   order also 1 Cleaning Kit
CLEANING KIT                   A3639-70101   contains: 4 CPU Sockets, 4 thermstrate pads, 4 EMI O-rings, 1 IPA wipe & cleaning manual
CPU PCX-W SOCKET               1253-0703     just one single CPU-socket
CELL BOARD BATTERY             1420-0356     CR2032, 3V; on the PDH Riser Board
256MB DIMM (SINGLE)            A6802-69101
512MB DIMM (SINGLE)            A6097-69001   replaced by A5198-69101 (min. FW 5.0 (PDC 16.011)); use till gone
1GB   DIMM (SINGLE)            A6098-69001   replaced by A6098-69101; use till gone
2GB   DIMM (SINGLE)            A6100-69001   (min. PDC: 16.011)
PCI CARD CAGE ASSY             A6093-69015   contains the PCI Backplane
PCI-X CARD CAGE ASSY           A6093-69013   contains the PCI-X Backplane
PCI OLR ASSY WITH 16 PADDLES   A6093-67114   old part#: A6093-67014
PCI OLR PADDLE ASSY            A6093-40041   old part#: A6093-67020
PCI SEPARATER WITH LIGHTPIPE   5065-7443
PCI FILLER PLATE               5001-6892
CORE I/O, MP A6096A            A6096-69201   old Core I/O; has no MP SEL LED!
CORE I/O, MP A7109A            A7109-69001   new Core I/O; has MP SEL LED!
BATTERY FOR MP                 1420-0356     CR2032, 3V; for new and old MP
MASS STORAGE BACKPLANE         A6093-67003
INTERNAL DAT40i 40GB DRIVE     C5686-69203   ioscan will return the Product ID: HP C5683A
INTERNAL SCSI-2 DVD ROM        A5220-67003
REMOVABLE MEDIA RAIL KIT       A6752-67011   blue plastic rails attached to DAT or DVD
INT. HOTPLUG DISK 18GB 10k     A6537-69002   ST318404LC, ST318406LC, MAN3184MC, Atlas 10k III 18.4 SCA, IC35L018UCD210-0, DK32DJ-18MC
INT. HOTPLUG DISK 36GB 10k     A6538-69002   ST336704LC, ST336706LC, MAN3367MC, Atlas 10k III 36.7 SCA, IC35L036UCD210-0, DK32DJ-36MC
INT. HOTPLUG DISK 36GB 15k     A6541-69002   ST336752LC, MAM3367MC, IC35L036UCPR15-0
INT. HTPLG U320 DISK 36GB 15k  A7329-69001   ST336753LC, MAS3367NC
INT. HOTPLUG DISK 73GB 10k     A6539-69001   ST373405LC, MAN3735MC, Atlas 10K III 73.4 SCA, IC35L072UCD210-0, DK32DJ-72MC
INT. HTPLG U320 DISK 73GB 10k  A7285-69002   HP 73.4GST373307LC, HP 73.4GMAP3735NC
INT. HTPLG U320 DISK 146GB 10k A7287-69002
FILLER FOR INTERNAL DISK SLOT  A6198-60002
BULK POWER SUPPLY              A6093-69021
PCI POWER MODULE               A6093-69123
VRM FOR PCI BACKPLANE          0950-4352     old. part#: 0950-3793 - see Service Note A6093A-17B
VRM FOR PCI-X BACKPLANE        0950-4122     VRM# 1-4;
VRM FOR CELL, LOW VOLTAGE      0950-4448     VRM# 0-3 & 5-9; order 8! - Don't mix part# or vendors! - see Service Note A6093A-17B
VRM FOR CELL, HIGH VOLTAGE     0950-4353     VRM# 10-12    ; order 3! - Don't mix part# or vendors! - see Service Note A6093A-17B
PCA, AC DISTRIBUTION           A6093-67007
PCA, DC DISTRIBUTION           A6093-67008
SMART FAN FRONT ASSY           A6093-67017   cabinet fan# 0-8
SMART FAN REAR ASSY            A6093-67018   cabinet fan# 9-20
SMART FAN PCI I/O ASSY         A6093-67019
SMART FAN PCI-X I/O ASSY       A6752-67030   same as in Matterhorn
CABLE, FAN ASSY FRONT          A6093-63000
CABLE, FAN ASSY REAR           A6093-63001
CABLE, MASS STORAGE RIBBON     A6093-63028
CABLE, MASS STORAGE POWER      A6093-63008
CABLE, DC DISTRIBUTION SIGNAL  A6093-63014
CABLE, PCI OLR SWITCH          AB297-63001   old part#: A6093-63006 / -63027
CABLE, RS487 INTERNAL (SEU)    A6093-63012
CABLE, RS487 EXTERNAL (SEU)    A6434-63003   for connection to a SEU
SBA CABLE SET                  A6093-63005   for connection to a SEU
CABLE, INTRUSION SWITCH        A6093-63025   cable to all cover open/closed switches (sensors)
POWER CORD, C19/CEE 7-7 4.5M   8120-6899
FRONT PANEL PCA                A6093-67005
FRONT PANEL PLASTIC ASSY       A6093-04049
COVER, FRONT PLASTIC W. NAME   A6093-04048   Front Bezel with name rp8400
COVER, FRONT PLASTIC NO NAME   A6093-04117   Front Bezel without nameplate -> order add. plate!
NAMEPLATE RP8400               A6093-40002   for Front Bezel A6093-04117
COVER, RIGHT SIDE ASSY         A6093-04055
COVER, LEFT SIDE ASSY          A6093-04069
COVER, TOP ASSY                A6093-04056
KEYSTONE CHASSIS               A6093-04020
BKPLN JACK SREW KNOB KIT       A6093-04125   Jack Screw to fix system backplane
INTRUSION SWITCH               5040-6317     cover open/closed switch (sensor)
AC CABLE STRAIN RELIEF KIT     A6093-67029   see Service Note A6093A-13
CABLE MGMT TOWEL BAR KIT       A6093-04046
SPACER, CMA THREADED           A6093-00309   see Service Note A6093A-06
BLUE KNURLED KNOB              A6093-00180   for towel bar, if missing; 10-24 nut
CELL BOARD AIR BAFFLE KIT      A6093-67016
FRONT BEZEL SNAP ATTACH        C2786-40002
CARD GUIDE, FRONT (QTY 2)      A6093-40014
CARD GUIDE, REAR  (QTY 2)      A6093-40015
CORE I/O PLASTIC GUIDE RAIL 1  0403-1126     5 inches long; one per chassis; cannot be ordered thru the normal channels ?open CPR for CC
CORE I/O PLASTIC GUIDE RAIL 2  0403-1119     3 per chassis; cannot be ordered thru the normal channels ?open CPR for CC
POWER SUPPLY EMI FILLER ASSY   A6093-04018
SPRING LATCH PEPL. KIT         5002-1655     only for new rack rails
BACKPLANE REO CABLE SHROUDS    A6434-04041
