hp rp8420
2100|0
 楼主| xxjpj2009 发表于 2009-9-10 11:01 | 显示全部楼层 |阅读模式
hp, ST, AN, ce, TE
hp rp8420
SYSTEM BACKPLANE WITH SCREE B. A6093-69301   with new SEU (KIOX) connectors; old part# A6093-69002 may still be used if no SEU is connected
All cellboards come with 4 dual core CPU modules mounted on the board.
#Not needed CPUs should be removed from new cell and returned in the
#provided anti-static bags and compartments.
CELL with PA8800 1GHz CPUs     A6913-69107
CELL with PA8800 900MHz CPUs   A6913-69006
CELL with PA8900 1GHz CPUs     A6913-69012
CELL with PA8900 1.1GHz CPUs   A6913-69013
CPU SOCKET TERMINATOR          A6912-60001   in CPU slot 2 if only CPU module 0 installed
ITANIUM 2 PROCESSOR TOOL KIT   A7231-67046   includes Security TORX T-15 Driver
256MB DIMM (SINGLE)            A6802-69101
512MB DIMM (SINGLE)            A6097-69001   replaced by A5198-69101; use till gone
1GB   DIMM (SINGLE)            A6098-69001   replaced by A6098-69101; use till gone
2GB   DIMM (SINGLE)            A6100-69001
4GB   DIMM (SINGLE)            AB322-69001   min. FW is 2.0; do not mix with other DIMMs on same cell!
PCI-X CARD CAGE ASSY           A6093-69013   contains the PCI-X Backplane
PCI OLR ASSY WITH 16 PADDLES   A6093-67114   old part#: A6093-67014
PCI OLR PADDLE ASSY            A6093-40041   old part#: A6093-67020
PCI SEPARATER WITH LIGHTPIPE   5065-7443
PCI FILLER PLATE               5001-6892
CORE I/O, MP                   A7109-69001
BATTERY FOR MP                 1420-0356     CR2032, 3V
MASS STORAGE BACKPLANE         A6093-67003
INTERNAL DAT40i 40GB DRIVE     C5686-69203   quartz gray colored
INTERNAL DAT40i 40GB DRIVE     C5686-69204   same as C5686-69203 but carbon colored
INTERNAL DVD DEVICE            A9879-67001   in new Rainiers
INTERNAL DVD+RW DEVICE        AB351-62001
INTERNAL SCSI-2 DVD ROM        A5220-67003   in Keystone upgrades
REMOVABLE MEDIA RAIL KIT       A6752-67011   blue plastic rails attached to DAT or DVD
FILLER FOR DVD SLOT            A6912-00014   carbon colored
INT. HOTPLUG DISK 18GB 10k     A6537-69002   in Keystone upgrades; gray colored; ST318404LC, ST318406LC, MAN3184MC, Atlas 10k III 18.4 SCA, IC35L018UCD210-0, DK32DJ-18MC
INT. HOTPLUG DISK 36GB 10k     A6538-69002   in Keystone upgrades; gray colored; Ultra160; ST336704LC, ST336706LC, MAN3367MC, Atlas 10k III 36.7 SCA, IC35L036UCD210-0, DK32DJ-36MC
INT. HOTPLUG DISK 36GB 15k     A6541-69002   in Keystone upgrades; gray colored; Ultra160; ST336752LC, MAM3367MC, IC35L036UCPR15-0
INT. HTPLG U320 DISK 36GB 15k  A9896-69001   in new Rainiers; carbon colored; Ultra320; ST336753LC, MAS3367NC
INT. HTPLG U320 DISK 36GB 15k  A7329-69001   in Keystone upgrades; gray colored; Ultra320; ST336753LC, MAS3367NC
INT. HOTPLUG DISK 73GB 10k     A6539-69002   in Keystone upgrades; gray colored; Ultra160; ST373405LC, MAN3735MC, Atlas 10K III 73.4 SCA, IC35L072UCD210-0, DK32DJ-72MC
INT. HTPLG U320 DISK 73GB 10k  A7285-69002   in Keystone upgrades; gray colored; Ultra320; HP 73.4GST373307LC, HP 73.4GMAP3735NC
INT. HTPLG U320 DISK 73GB 15k  A9897-69001   in new Rainiers; carbon colored; Ultra320; MAS3735xx
INT. HTPLG U320 DISK 146GB 10k A9898-69002   in new Rainiers; carbon colored; Ultra320;
INT. HTPLG U320 DISK 146GB 10k A7287-69002   in Keystone upgrades; gray colored; Ultra320;
FILLER FOR INTERNAL DISK SLOT  A6198-60003   carbon colored
BULK POWER SUPPLY              A6093-69021
PCI POWER MODULE               A6093-69123
VRM FOR PCI-X BACKPLANE        0950-4122     VRM# 1-4; same as cell LOW-V VRM
VRM FOR CELL, LOW VOLTAGE      0950-4122     VRM# 1-6 & 15; order 7! - Check vendor (C&D [Celestica] and IKOR) of installed VRMs: If the same as the replacement, exchange only the failed one; if another vendor or part#, exchange all VRMs of that range.
VRM FOR CELL, HIGH VOLTAGE     0950-4123     VRM# 7-14; order 8! - Check vendor (C&D [Celestica] and IKOR) of installed VRMs: If the same as the replacement, exchange only the failed one; if another vendor or part#, exchange all VRMs of that range.
PCA, AC DISTRIBUTION           A6093-67007
PCA, DC DISTRIBUTION           A6093-67008
SMART FAN FRONT ASSY           A6093-67017   cabinet fan# 0-8
SMART FAN REAR ASSY            A6093-67018   cabinet fan# 9-20
SMART FAN PCI-X I/O ASSY       A6752-67030   same as in Matterhorn
SBA CABLE SET                  A6093-63005   for connection to a SEU
CABLE, FAN ASSY FRONT          A6093-63000
CABLE, FAN ASSY REAR           A6093-63001
CABLE, MASS STORAGE RIBBON     A6093-63028
CABLE, MASS STORAGE POWER      A6093-63008
CABLE, DC DISTRIBUTION SIGNAL  A6093-63014
CABLE, PCI OLR SWITCH          AB297-63001   old part#: A6093-63006 / -63027
CABLE, RS487 INTERNAL (SEU)    A6093-63012
CABLE, RS487 EXTERNAL (SEU)    A6434-63003   for connection to a SEU
CABLE, INTRUSION SWITCH        A6093-63025   cable to all cover open/closed switches (sensors)
POWER CORD, C19/CEE 7-7 4.5M   8120-6899
FRONT PANEL PCA                A6093-67005
FRONT PANEL PLASTIC ASSY       A6912-04010   carbon colored
COVER, FRONT PLASTIC NO NAME   A6912-04009   carbon colored Front Bezel without nameplate
NAMEPLATE RP8420               A6912-40005   for Front Bezel; carbon colored
COVER, RIGHT SIDE ASSY         A6093-04121
COVER, LEFT SIDE ASSY          A6093-04122
COVER, TOP ASSY                A6093-04120
RAINIER/KEYSTONE CHASSIS       A6093-04020
BKPLN JACK SREW KNOB KIT       A6093-04125   Jack Screw to fix system backplane
INTRUSION SWITCH               5040-6317     cover open/closed switch (sensor)
AC CABLE STRAIN RELIEF KIT     A6093-67029   see Service Note A6093A-13
CABLE MGMT TOWEL BAR KIT       A6093-04046
SPACER, CMA THREADED           A6093-00309   see Service Note A6093A-06
BLUE KNURLED KNOB              A6093-00180   for towel bar, if missing; 10-24 nut
MAKO/MADISON CPU BAFFLE        A6912-04015   has been replaced by VRM guard AB388-00002 and door opener AB388-00003
Mad9M CPU AIR BAFFLE LEFT      AB388-00002   VRM guard for Madison/Mako/Mad9M
Mad9M CPU AIR BAFFLE RIGHT     AB388-00003   door opener for Madison/Mako/Mad9M
FRONT BEZEL SNAP ATTACH        C2786-40002
CELL CARD GUIDE, FRONT (QTY 2) A6093-40014
CELL CARD GUIDE, REAR  (QTY 2) A6093-40015
CORE I/O PLASTIC GUIDE RAIL 1  0403-1126     5 inches long; one per chassis; cannot be ordered thru the normal channels ?open CPR for CC
CORE I/O PLASTIC GUIDE RAIL 2  0403-1119     3 per chassis; cannot be ordered thru the normal channels ?open CPR for CC
POWER SUPPLY EMI FILLER ASSY   A6093-04018
SPRING LATCH PEPL. KIT         5002-1655     only for new rack rails
