[Actel FPGA]
请求FPGA高手帮忙,下载不了程序
3882|6
3108009184|  楼主 | 2009-9-17 12:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
买了周立功的一块FPGA开发板,FlashPro下载的时候出现下面的错误提示,不知道是什么原因引起的,高手帮帮忙,谢谢了!!! “Error: programmer 'FPBBALTLPT1' : Signal Integrity Failure Integrity Check Pattern Not Found. Integrity Check Pattern : 550FAAF000FF0000FFFF IrScan Error. Possible chain exceeds expected maximum device count: 256. Chain Analysis Failed. Error: programmer 'FPBBALTLPT1' : Data Bit length : 8272 Error: programmer 'FPBBALTLPT1' : Compare Data : 01DB07047C00FF0000FFFF000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Error: programmer 'FPBBALTLPT1' : Scan Chain FAILED.
孤独行者| | 2009-10-25 10:54 | 只看该作者
看不懂
孤独行者| | 2009-10-25 10:55 | 只看该作者
你是不是没有现在成功啊
lobby| | 2009-11-5 14:55 | 只看该作者
是不是硬件电路有问题
找不到板子
linhai1986| | 2009-11-5 21:31 | 只看该作者
看不懂,怎么这么多0
xiaoxin1986| | 2009-11-5 21:34 | 只看该作者
看不懂
laslison| | 2009-11-5 23:10 | 只看该作者
:),顶顶
