Source Insight 一小问:
2018|0
 楼主| hsw_21 发表于 2009-9-21 18:59 | 显示全部楼层 |阅读模式
volatile       unsigned char PMCON1  @ 0x18C;
/* Definitions for STATUS register */
volatile       bit CARRY  @ ((unsigned)&STATUS*8)+0;
volatile       bit DC  @ ((unsigned)&STATUS*8)+1;
volatile       bit ZERO  @ ((unsigned)&STATUS*8)+2;
volatile       bit PD  @ ((unsigned)&STATUS*8)+3;
volatile       bit TO  @ ((unsigned)&STATUS*8)+4;
               bit RP0  @ ((unsigned)&STATUS*8)+5;
               bit RP1  @ ((unsigned)&STATUS*8)+6;
               bit IRP  @ ((unsigned)&STATUS*8)+7;
请问怎么让Source Insight 识别并能跟踪这样定义的 PMCON1,CARRY,DC……变量?
试了很久,还是没搞定。谢谢!
