CACHE_setL2Mode请各位给指点一下!
3382|0
 楼主| ccjchen 发表于 2009-9-24 17:12 | 显示全部楼层 |阅读模式
下面是在CSL中关于CACHE_setL2Mode的原话,可是我看不懂,请大家给指点一下!
If the cache size decreases, all of L2 is writeback-invalidated, then the mode
is changed. If the cache size increases, the part of SRAM that is about to be
turned into cache is writeback-invalidated from L1D and all of L2 is
writeback-invalidated; then the mode is changed.
writeback-invalidated是什么意思?哪位能把上面这句话给解释一下吗?
