A04E 技术参数 欢迎订购
5980|0
hxtcoco|  楼主 | 2009-10-7 17:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TI, AC, TE, ST, ce
A1101, A1102, A1103, A1104, and A1106
Continuous-Time Switch Family A1101EUA-T.pdf
Features and Benefits
  • Continuous-time operation
    • Fast power-on time
    • Low noise
  • Stable operation over full operating temperature range
  • Reverse battery protection
  • Solid-state reliability
  • Factory-programmed at end-of-line for optimum performance
  • Robust EMC performance
  • High ESD rating
  • Regulator stability without a bypass capacitor
Description
The Allegro® A1101-A1104 and A1106 Hall-effect switches are next generation replacements for the popular Allegro 312x and 314x lines of unipolar switches. The A110x family, produced with BiCMOS technology, consists of devices that feature fast power-on time and low-noise operation. Device programming is performed after packaging, to ensure increased switchpoint accuracy by eliminating offsets that can be induced by package stress. Unique Hall element geometries and low-offset amplifiers help to minimize noise and to reduce the residual offset voltage normally caused by device overmolding, temperature excursions, and thermal stress.
The A1101-A1104 and A1106 Hall-effect switches include the following on a single silicon chip: voltage regulator, Hall-voltage generator, small-signal amplifier, Schmitt trigger, and NMOS output transistor. The integrated voltage regulator permits operation from 3.8 to 24 V. The extensive on-board protection circuitry makes possible a ±30 V absolute maximum voltage rating for superior protection in automotive and industrial motor commutation applications, without adding external components. All devices in the family are identical except for magnetic switchpoint levels.
The small geometries of the BiCMOS process allow these devices to be provided in ultrasmall packages. The package styles available provide magnetically optimized solutions for most applications. Package LH is an SOT23W, a miniature low-profile surface-mount package, while package UA is a three-lead ultramini SIP for through-hole mounting. Each package is lead (Pb) free, with 100% matte tin plated leadframes.
Replacement Device Characteristics Table
Device
A110x Characteristics
BOP
BRP
Hys
Legacy
Replacement
Min
Max
Min
Max
Min
Max
3141
A1101
30
175
20
80
3142
A1102
115
245
60
190
30
80
3143
A1103
205
355
150
300
30
80
3144
A1104
35
450
25
430
20
3121
A1106
260
430
160
330
70
140
Functional Block Diagram
Allegro’s products are not to be used in life support devices or systems, if a failure of an Allegro product can reasonably be expected to cause the failure of that life support device or system, or to affect the safety or effectiveness of that device or system
华芯通电子优势原装现货热卖如下:
A3977SED-T  A3977SLP-T  A3985SLD-T  A3979SLP-T  ATS665LSG-T  ACS712ELC-05B  ACS712ELC-20A  ACS712ELC-30A  ACS754LCB-050-PFF ACS754LCB-100-PFF  ACS754LCB-200-PFF  TLE4921-5U
A1104EU-T A1104EUA-T  A3212EUA-T A3212ELHLT-T  A3213EUA-T A1212LUA-T  US1881KUA-T  SS441A  SS443A  SS543A THS119  US79KUA  A1321EUA-T  A1321LUA-T  A1302EUA-T
只做原装现货
详情欢迎致电:13670104769  王**
QQ:243247683
MSN/EMAIL:zoe86@163.com
