[Actel FPGA]
Libero 8.5 进入布局布线时出现的问题!
5683|3
NICKY99|  楼主 | 2009-10-11 20:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
从网上下载了一个UART程序,可以综合,但在进入布局布线时出现的问题:
Actel Designer Software
Version: 8.5.0.34
Release: v8.5
Netlist Reading Time = 0.0 seconds
Imported the files:
   E:\cpld_program\uart1\uart\synthesis\uart_tb.edn
   E:\cpld_program\uart1\uart\synthesis\uart_tb_sdc.sdc
The Import command succeeded ( 00:00:01 )
Info: The design E:\cpld_program\uart1\uart\designer\impl1\uart_tb.adb was last modified by software version 8.5.0.34.
Opened an existing Libero design E:\cpld_program\uart1\uart\designer\impl1\uart_tb.adb.
'BA_NAME' set to 'uart_tb_ba'
The Execute Script command succeeded ( 00:00:00 )
Checking for software updates...
Parameters used to run compile:
Family      : ProASIC3
Device      : A3P030
Package     : 100 VQFP
Source      : E:\cpld_program\uart1\uart\synthesis\uart_tb.edn
Format      : EDIF
Topcell     : uart_tb
Speed grade : -2
Temp        : 0:25:70
Voltage     : 1.58:1.50:1.42
Keep Existing Physical Constraints : No
Keep Existing Timing Constraints   : Yes
pdc_abort_on_error                 : Yes
pdc_eco_display_unmatched_objects  : No
pdc_eco_max_warnings               : 10000
demote_globals                     : No
promote_globals                    : No
localclock_max_shared_instances    : 12
localclock_buffer_tree_max_fanout  : 12
combine_register                   : No
delete_buffer_tree                 : No
report_high_fanout_nets_limit      : 10
Compile starts ...
Netlist Optimization Report
Optimized macros:
  - Dangling net drivers:   0
  - Buffers:                0
  - Inverters:              0
  - Tieoff:                 0
  - Logic combining:        0
    Total macros optimized  0
Error: CMP010: A design must contain at least one net.
There were 1 error(s) and 0 warning(s) in this design.
The Compile command failed ( 00:00:00 )
从这些提示看来,已经调入了*.edn文件!!·
请各位指点!!
synics| | 2009-10-24 20:40 | 只看该作者
出了什么问题?你说说
synics| | 2009-10-24 20:41 | 只看该作者
要是有软件吻和,硬件肯定不难连,我是一个做硬件的,我试过。你好好说
synics| | 2009-10-24 20:42 | 只看该作者
到底是因为什么硬件连不上!
