[开发工具] STM32L0和STM32F0用户的天大福利来了
12764|17
 楼主| mintspring 发表于 2016-2-22 09:15 | 显示全部楼层 |阅读模式
MDK for STM32L0 and STM32F0 Installation & Activation
看到没,MDK免费为这两系列提供服务了。
http://az717401.vo.msecnd.net/eval/MDK518.EXE
http://az717401.vo.msecnd.net/pack/Keil.STM32F0xx_DFP.1.4.0.pack
迅雷可以下载
Product Serial Number (PSN)
To activate the MDK for STM32F0 and STM32L0 Edition, use the following Product Serial Number (PSN). For more details on how to activate MDK, please refer to the Activation guide below.
U1E21-CM9GY-L3G4L
 楼主| mintspring 发表于 2016-2-22 09:16 | 显示全部楼层
Installation
  • Download Keil MDK-ARM v5 from https://www.keil.com/demo/eval/arm.htm
  • Run the downloaded MDK5xx.exe installer.
  • Install to any path you like. If you have existing MDK-ARM installations that you want to keep, select a new folder for MDK v5.
  • Click Install to download and install the STM32F0 and STM32L0 Device Family Packs supplied by Keil.
  • MDK Version 5 is now ready to use. Launch µVision5 to start component-based projects.
Activation
  • Login with an account that has administration rights.
  • Right-click the µVision icon and select Run as Administrator... from the context menu.
  • Open the dialog File — License Management... and select the Single-User License tab.
  • Click the button Get LIC via Internet..., then click the button OK to register the product. This action opens the License Management page on the Keil web site.
  • Enter the Product Serial Number U1E21-CM9GY-L3G4L along with your contact information and click the button Submit. An e-mail is sent back with the License ID Code (LIC) within a few minutes.
  • To activate the Software Product, enter the LIC in the field New License ID Code (LIC) of the dialog License Management... and click Add LIC.
 楼主| mintspring 发表于 2016-2-22 09:17 | 显示全部楼层
Example Projects
  • Open the Pack Installer from the µVision5 toolbar.
  • Switch to the Examples tab. From the list of available example select the example you want to install. The Devices tab allows to filter for specific devices or device series.
  • When pressing Copy, a dialog box will ask for the desired destination. The example will be directly installed into this folder. Folders that do not exist will be created automatically.
    Tick Launch µVision to open the project after installation.
 楼主| mintspring 发表于 2016-2-22 11:13 | 显示全部楼层
STMicroelectronics STM32F7 Series
216 MHz ARM Cortex-M7 processor with Floating Point Unit (FPU)
Up to 1 Mbytes of Flash, up to 320 Kbytes of SRAM
64 Kbytes of Data Tightly Coupled Memory (DTCM) for time critical data handling
mmuuss586 发表于 2016-2-22 19:21 | 显示全部楼层
maiweiqi 发表于 2016-2-22 21:02 | 显示全部楼层
厄…………一直用**版,内疚地路过……
 楼主| mintspring 发表于 2016-2-25 11:35 | 显示全部楼层
厄…………一直用**版,内疚地路过……
现在免费提供给大家用了,是不是很开心。
grant_jx 发表于 2016-2-25 13:50 | 显示全部楼层
以前就有,针对M0的,现在多加了M0+。
Jessicakjdsl 发表于 2016-2-26 09:06 | 显示全部楼层
Installation
  • 老版本的能支持吗,比如说4.6版本
    Cheribat 发表于 2016-4-22 16:11 | 显示全部楼层
    好消息 mark一下
     楼主| mintspring 发表于 2016-4-30 22:55 | 显示全部楼层
    以前以为那个地址是临时的呢,刚才试试,点开还可以继续下载。
    LingTian 发表于 2017-11-26 11:50 | 显示全部楼层
    好好好!
     楼主| mintspring 发表于 2017-12-4 20:25 | 显示全部楼层
    大家记得定期更新。
    10299823 发表于 2017-12-4 22:21 | 显示全部楼层
    10299823 发表于 2017-12-4 22:26 | 显示全部楼层
    STM32L0和STM32F0用的这么火了。
    yongwong9901 发表于 2017-12-5 08:03 | 显示全部楼层
    mark!什么时候M3,M4,M7也免费呀?
    一路向北lm 发表于 2017-12-5 08:50 | 显示全部楼层
    不错,感谢分享
