[USB驱动] USB枚举无法返回inquiries请求问题
1497|1
 楼主| yitianlanhei 发表于 2016-2-24 21:30 | 显示全部楼层 |阅读模式
USB, ui, SCR, des, ip
Device  Phase  Data        Description                       Delta  Cmd.Phase.Ofs(rep)
  16.0  CTL    80 06 00 01  00 00 12 00        GET DESCRIPTOR                     18sc         1.1.0
  16.0  IN     12 01 00 02  00 00 00 40  7d 0d 00 01  00 01 01 02  03 01                                               .......@..........                 66us         1.2.0
  16.0  CTL    80 06 00 02  00 00 09 00        GET DESCRIPTOR                      8us         2.1.0
  16.0  IN     09 02 20 00  01 01 04 c0  00        .. ......                         992us         2.2.0
  16.0  CTL    80 06 00 02  00 00 20 00        GET DESCRIPTOR                     19us         3.1.0
  16.0  IN     09 02 20 00  01 01 04 c0  00 09 04 00  00 02 08 06  50 05 07 05  01 02 00 02  00 07 05 81  02 00 02 00  .. .............P...............  981us         3.2.0
  16.0  CTL    80 06 00 03  00 00 02 00        GET DESCRIPTOR                     19us         4.1.0
  16.0  IN     04 03        ..                                990us         4.2.0
  16.0  CTL    80 06 00 03  00 00 04 00        GET DESCRIPTOR                      8us         5.1.0
  16.0  IN     04 03 09 04        ....                              993us         5.2.0
  16.0  CTL    80 06 03 03  09 04 02 00        GET DESCRIPTOR                      7us         6.1.0
  16.0  IN     20 03        .                                991us         6.2.0
  16.0  CTL    80 06 03 03  09 04 20 00        GET DESCRIPTOR                      7us         7.1.0
  16.0  IN     20 03 32 00  41 00 34 00  39 00 38 00  37 00 36 00  44 00 39 00  43 00 43 00  31 00 41 00  41 00 34 00   .2.A.4.9.8.7.6.D.9.C.C.1.A.A.4.  992us         7.2.0
  16.0  CTL    00 09 01 00  00 00 00 00        SET CONFIG                        372us         8.1.0
  16.0  CTL    01 0b 00 00  00 00 00 00        SET INTERFACE                     641us         9.1.0
  16.0  CTL    a1 fe 00 00  00 00 01 00        GET MAX LUN                       9.5ms        10.1.0
  16.0  IN     00        .                                 129us        10.2.0
  16.1  OUT    55 53 42 43  10 c0 9c ff  24 00 00 00  80 00 06 12  00 00 00 24  00 00 00 00  00 00 00 00  00 00 00     USBC....$..........$...........   120us        11.1.0
  16.1  IN     53 42 53 55  00 00 00 00  00 00 00 00  00                                                               SBSU.........                     879us        12.1.0
  16    RESET        19sc        13.1.0
  16    ok        58ms        13.2.0
  16.1  OUT    55 53 42 43  10 80 b4 ff  24 00 00 00  80 00 06 12  00 00 00 24  00 00 00 00  00 00 00 00  00 00 00     USBC....$..........$...........    93us        14.1.0
  16.1  IN     53 42 53 55  00 00 00 00  00 00 00 00  00                                                               SBSU.........                     119us        15.1.0(2)
  16    RESET        20sc        16.1.0(2)
  16    ok        61ms        16.2.0
  16.1  OUT    55 53 42 43  80 2b 9a f7  24 00 00 00  80 00 06 12  00 00 00 24  00 00 00 00  00 00 00 00  00 00 00     USBC.+..$..........$...........   224us        17.1.0(2)
  16.1  IN     53 42 53 55  00 00 00 00  00 00 00 00  00                                                               SBSU.........                      20sc        21.1.0
  16    RESET        20sc        22.1.0
  16    ok        59ms        22.2.0
前面获取设备描述符正常,到发送inquiry请求时,返回值不对,请问是什么原因?
 楼主| yitianlanhei 发表于 2016-2-24 21:37 | 显示全部楼层
用的是xilinx zc706加nandflash模拟u盘,遇到的上述问题
