[疑难问答] 编译问题???
864|6
 楼主| litengg 发表于 2016-2-24 22:49 | 显示全部楼层 |阅读模式
电脑安装WIN7 64位,安装环境ubuntu12.04,安装包L3.0.35_4.1.0_130816_source.tar.gz。
ltib编译详细错误:
Updating lpp from local packages
Processing platform: Host support packages
using /home/auto06/IMX6/L3.0.35_4.1.0_130816_source/source/ltib/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: m4
Processing: bison
Processing: flex
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
/opt/freescale/ltib/usr/src/rpm/BUILD/flex-2.5.37
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
Started: Sat Jan  2 23:13:48 2016
Ended:   Sat Jan  2 23:13:54 2016
Elapsed: 6 seconds
These packages failed to build:
flex
Build Failed
zhouhuanの 发表于 2016-2-24 22:55 | 显示全部楼层
Remove this by hand if you really want to rebuild this package from scratch。。
sourceInsight 发表于 2016-2-24 22:58 | 显示全部楼层
楼上的那句话应该就是解决问题的方法......
boy1990 发表于 2016-2-24 23:07 | 显示全部楼层
问下楼主::你装的ubantu是64位的吗??
CallReceiver 发表于 2016-2-24 23:09 | 显示全部楼层
貌似要手动去除啊??可以试试看看:D
hfdy01 发表于 2016-2-24 23:18 | 显示全部楼层
/bin/bash: texi2dvi: command not found
仔细看看log......
xia00 发表于 2016-2-24 23:20 | 显示全部楼层
学会自己看log,一般的错误,log里面都会告诉你的......
