[MCU新闻] 给力新唐,2016年刚过完年一大批软件更新
2593|4
 楼主| Harvard 发表于 2016-2-28 09:58 | 显示全部楼层 |阅读模式
 楼主| Harvard 发表于 2016-2-28 13:38 | 显示全部楼层
最新的mdk插件用下来不错的 在SYSTEM VIEWER下,对寄存器的查看更加直观, 旁边直接有英文注释,比上一个版本好多了
记得以前某个版本也有这样的形式,只不过不知道为何被取代了]
现在好了
又可以用了
具体的插件更新如下;
Revision 1.31.6535 (Released 2016-02-01)
1. Supported Nano103, NM1120, NM1330, NM1820 for NuMicro M0 series.
2. Supported M4TK for NuMicro M4 series.
3. Supported N575, N576 and N570 for NuVoice series.
4. Updated SFR file of Mini58DE, M451 and NUC505 for register display.
5. Supported spin button edition of data flash.
6. Added the selection of connect type (connect normal and connect under reset).
7. Modified the behavior of option "memory verify code" in “Debug” tab. If checked and downloaded code to SRAM, it will do code verification.
8. Supported breakpoint setting and memory window periodically updating while the CPU is running.
9. Supported data and conditional breakpoint functions completely.
Micachl 发表于 2016-2-28 22:22 | 显示全部楼层
有支持mdk4.6的吗,不想用5
 楼主| Harvard 发表于 2016-2-29 17:45 | 显示全部楼层
支持4.6的
 楼主| Harvard 发表于 2016-2-29 17:46 | 显示全部楼层
我是4.74下测试的 没用问题呢
