自己的usb设备,在兼容机上能识别,dell却的不行
3301|2
 楼主| mm7989680 发表于 2009-10-22 16:37 | 显示全部楼层 |阅读模式
如上
bushound的数据
能识别的都是自己配的兼容机,不能识别的都是dell的品牌机,怪了
兼容机上:
us Hound 5.00 capture. Complements of www.perisoft.net
usb_canconnet_bushound
  Device - Device ID (followed by the endpoint for USB devices)
            (12) USB Root Hub
            (22) W-CDMA信号源
  Phase  - Phase Type
            CTL   USB control transfer
            DI    Data in
  Data   - Hex dump of the data transferred
  Descr  - Description of the phase
  Cmd... - Position in the captured data
Device  Phase  Data                      Description       Cmd.Phase.Ofs(rep)
  12.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS               1.1.0(2)
  12.0  DI     01 01 01 00               ....                     1.2.0
  12.0  CTL    23 01 10 00  01 00 00 00  CLEAR FEATURE            3.1.0
  12.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS               4.1.0(2)
  12.0  DI     01 01 00 00               ....                     4.2.0
  12.0  CTL    23 03 04 00  01 00 00 00  SET FEATURE              6.1.0
  12.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS               7.1.0
  12.0  DI     03 01 10 00               ....                     7.2.0
  12.0  CTL    23 01 14 00  01 00 00 00  CLEAR FEATURE            8.1.0
  12.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS               9.1.0(2)
  12.0  DI     03 01 00 00               ....                     9.2.0
  12.0  CTL    23 03 04 00  01 00 00 00  SET FEATURE             11.1.0
  12.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS              12.1.0
  12.0  DI     03 01 10 00               ....                    12.2.0
  12.0  CTL    23 01 14 00  01 00 00 00  CLEAR FEATURE           13.1.0
  12.0  CTL    80 06 00 02  00 00 ff 00  GET DESCRIPTOR          14.1.0
  12.0  DI     09 02 2e 00  01 01 00 c0  ........                14.2.0
               32 09 04 00  00 04 dc a0  2.......                14.2.8
               b0 00 07 05  01 02 10 00  ........                14.2.16
               0a 07 05 81  02 10 00 0a  ........                14.2.24
  12.0  CTL    a3 00 00 00  02 00 04 00  GET STATUS              15.1.0
  12.0  DI     00 01 00 00               ....                    15.2.0
  22.0  CTL    80 06 00 01  00 00 12 00  GET DESCRIPTOR          16.1.0
  22.0  DI     12 01 10 01  dc 00 00 10  ........                16.2.0
               72 04 20 06  00 01 00 00  r. .....                16.2.8
               00 01                     ..                      16.2.16
  22.0  CTL    80 06 00 02  00 00 00 04  GET DESCRIPTOR          17.1.0
  22.0  DI     09 02 2e 00  01 01 00 c0  ........                17.2.0
               32 09 04 00  00 04 dc a0  2.......                17.2.8
               b0 00 07 05  01 02 10 00  ........                17.2.16
               0a 07 05 81  02 10 00 0a  ........                17.2.24
  22.0  CTL    00 09 01 00  00 00 00 00  SET CONFIG              18.1.0
在dell的机子上好像没有枚举成功
Bus Hound 5.00 capture. Complements of www.perisoft.net
usb_bushound_n
            (13) USB Root Hub
            (15) USB Root Hub
  Phase  - Phase Type
            DI    Data in
  13.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS               1.1.0(2)
  13.0  DI     01 01 01 00               ....                     1.2.0
  13.0  CTL    23 01 10 00  01 00 00 00  CLEAR FEATURE            3.1.0
  13.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS               4.1.0(2)
  13.0  DI     01 01 00 00               ....                     4.2.0
  13.0  CTL    23 03 04 00  01 00 00 00  SET FEATURE              6.1.0
  13.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS               7.1.0
  13.0  DI     03 01 10 00               ....                     7.2.0
  13.0  CTL    23 01 14 00  01 00 00 00  CLEAR FEATURE            8.1.0
  13.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS               9.1.0(2)
  13.0  DI     03 01 00 00               ....                     9.2.0
  13.0  CTL    23 03 04 00  01 00 00 00  SET FEATURE             11.1.0
  13.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS              12.1.0
  13.0  DI     03 01 10 00               ....                    12.2.0
  13.0  CTL    23 01 14 00  01 00 00 00  CLEAR FEATURE           13.1.0
  13.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS              14.1.0
  13.0  DI     03 01 00 00               ....                    14.2.0
  13.0  CTL    23 03 04 00  01 00 00 00  SET FEATURE             15.1.0
  13.0  CTL    a3 00 00 00  01 00 04 00  GET STATUS              16.1.0
  13.0  DI     03 01 10 00               ....                    16.2.0
  13.0  CTL    23 01 14 00  01 00 00 00  CLEAR FEATURE           17.1.0
  13.0  CTL    23 01 01 00  01 00 00 00  CLEAR FEATURE           18.1.0
  13.0  CTL    a3 00 00 00  02 00 04 00  GET STATUS              19.1.0
  13.0  DI     00 01 00 00               ....                    19.2.0
 楼主| mm7989680 发表于 2009-10-22 16:51 | 显示全部楼层
前面全一样的,就是上面那个后来发
而dell上的却没有
duojinian 发表于 2009-10-24 08:10 | 显示全部楼层
驱动不同,或者硬件不支持
