[DemoCode下载] LCD12864指定位置反白显示程序
5463|6
 楼主| C洛达尔多 发表于 2016-2-29 19:53 | 显示全部楼层 |阅读模式
#include <iom128v.h>
    #include <macros.h>
    #define uchar unsigned char
    #define uint unsigned int
    #define nop()   NOP()
    #define xtal 8
    #define CS   PB5
    #define SID  PB6
    #define SCLK PB7
    #define Set_CS()    DDRB |= (1<<CS);PORTB |= (1<<CS)
    #define Set_SID()   DDRB |= (1<<SID);PORTB |= (1<<SID)
    #define Set_SCLK()  DDRB |= (1<<SCLK);PORTB |= (1<<SCLK)
    #define Clr_CS()    DDRB |= (1<<CS);PORTB &=~(1<<CS)
    #define Clr_SID()   DDRB |= (1<<SID);PORTB &=~(1<<SID)
    #define Clr_SCLK()  DDRB |= (1<<SCLK);PORTB &=~(1<<SCLK)
    //函数声明
    void Delay(uint ms);            //延时子程序
    void W_1byte(uchar RW, uchar RS, uchar W_data);
    void Write_8bits(uint W_bits);
    void LCD_Init(void);
    void Char_Set_XY(uchar x, uchar y, uchar *p);
    void Set_Draw(void);
    //设定哪一行,从那一个位置开始到那一个位置结束使用反白
    //x=液晶屏上汉字的位置(1~8);end_x=汉字结束的地址(1~8);y=1~4行
    //clear=1:清除反白;clear=0:设置反白;
    void Set_White(uchar x,uchar y,uchar end_x,uchar clear);
    void Draw_Pic(uchar x, uchar y, const uchar *Draw);
    const uchar PIC1[64][16]={
    /*--  调入了一幅图像:C:\Documents and Settings\Administrator\桌面\atmel.bmp  --*/
    /*--  宽度x高度=128x64  --*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
    0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
    0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
    0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
    0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
    0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
    0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,
    0x00,0x00,0x00,0x07,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    0x00,0x00,0x3F,0xE7,0xFC,0xFF,0xFF,0xFF,0xE0,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x00,0x3F,0xE7,0xFC,0xFF,0xFF,0xFF,0xF0,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x00,0x7F,0xE7,0xFC,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x00,0x7F,0xE7,0xFC,0xFF,0xFF,0xFF,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x00,0xFF,0xE7,0xFC,0xFF,0xBF,0xEF,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x00,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x01,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x03,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x07,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFC,0x00,0x0F,0xF8,0x00,0x00,0x00,
    0x00,0x07,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x0F,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x1F,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x3F,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0x7F,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0xFF,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
    0x00,0xFF,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFC,0x00,0x0F,0xF8,0x00,0x00,0x00,
    0x01,0xFF,0xBF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFE,0x00,0x0F,0xF8,0x00,0x00,0x00,
    0x01,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xF8,0x00,0x00,
    0x03,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xF8,0x00,0x00,
    0x03,0xFE,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xF0,0x00,0x00,
    0x07,0xFE,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xF0,0x00,0x00,
    0x07,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xE0,0x00,0x00,
    0x0F,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xE0,0x00,0x00,
    0x0F,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xC0,0x00,0x00,
    0x1F,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xC0,0x00,0x00,
    0x1F,0xFF,0x3F,0xE7,0xFC,0xFF,0x1F,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0x80,0x00,0x00,
    0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3E,0x00,0x00,
    0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x63,0x00,0x00,
    0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0x00,0x00,
    0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xB6,0x80,0x00,
    0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xBE,0x80,0x00,
    0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xB6,0x80,0x00,
    0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xF7,0x00,0x00,
    0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x63,0x00,0x00,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x00,
    const uchar PIC2[64][16]={
    /*--  调入了一幅图像:C:\Documents and Settings\Administrator\桌面\AVR.BMP  --*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x43,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xBD,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x27,
    0x00,0x00,0x1F,0xFF,0x83,0xFF,0xE0,0x00,0x00,0xFF,0xF8,0x3F,0xFF,0xFF,0x01,0x3C,
    0x00,0x00,0x3F,0xFF,0x81,0xFF,0xF0,0x00,0x01,0xFF,0xF0,0x7F,0xFF,0xFF,0xC1,0x3E,
    0x00,0x00,0x3F,0xFF,0xC1,0xFF,0xF0,0x00,0x01,0xFF,0xF0,0x7F,0xFF,0xFF,0xE0,0xA7,
    0x00,0x00,0x3F,0xFF,0xC1,0xFF,0xF0,0x00,0x03,0xFF,0xE0,0x7F,0xFF,0xFF,0xF0,0xE7,
    0x00,0x00,0x7F,0xFF,0xE0,0xFF,0xF8,0x00,0x03,0xFF,0xE0,0xFF,0xFF,0xFF,0xF8,0x7E,
    0x00,0x00,0x7F,0xFF,0xE0,0xFF,0xF8,0x00,0x03,0xFF,0xE0,0xFF,0xFF,0xFF,0xF8,0x00,
    0x00,0x00,0x7F,0xFF,0xE0,0x7F,0xFC,0x00,0x07,0xFF,0xC1,0xFF,0xFF,0xFF,0xFC,0x00,
    0x00,0x00,0xFF,0xFF,0xF0,0x7F,0xFC,0x00,0x07,0xFF,0xC1,0xFF,0xFF,0xFF,0xFC,0x00,
    0x00,0x00,0xFF,0xFF,0xF0,0x7F,0xFE,0x00,0x0F,0xFF,0x83,0xFF,0xFF,0xFF,0xFE,0x00,
    0x00,0x01,0xFF,0xFF,0xF8,0x3F,0xFE,0x00,0x0F,0xFF,0x83,0xFF,0xE0,0x7F,0xFE,0x00,
    0x00,0x01,0xFF,0xFF,0xF8,0x3F,0xFE,0x00,0x1F,0xFF,0x07,0xFF,0xC0,0x3F,0xFE,0x00,
    0x00,0x03,0xFF,0xFF,0xF8,0x3F,0xFF,0x00,0x1F,0xFF,0x07,0xFF,0xC0,0x3F,0xFE,0x00,
    0x00,0x03,0xFF,0xFF,0xFC,0x1F,0xFF,0x00,0x1F,0xFE,0x07,0xFF,0xC0,0x3F,0xFE,0x00,
    0x00,0x03,0xFF,0xFF,0xFC,0x1F,0xFF,0x80,0x3F,0xFE,0x0F,0xFF,0x80,0x3F,0xFE,0x00,
    0x00,0x07,0xFF,0xFF,0xFE,0x0F,0xFF,0x80,0x3F,0xFE,0x0F,0xFF,0x80,0x3F,0xFE,0x00,
    0x00,0x07,0xFF,0x9F,0xFE,0x0F,0xFF,0x80,0x7F,0xFC,0x1F,0xFF,0x00,0x7F,0xFE,0x00,
    0x00,0x07,0xFF,0x9F,0xFF,0x07,0xFF,0xC0,0x7F,0xFC,0x1F,0xFF,0x00,0xFF,0xFC,0x00,
    0x00,0x0F,0xFF,0x8F,0xFF,0x07,0xFF,0xC0,0x7F,0xF8,0x1F,0xFF,0x01,0xFF,0xFC,0x00,
    0x00,0x0F,0xFF,0x0F,0xFF,0x03,0xFF,0xC0,0xFF,0xF8,0x3F,0xFF,0xFF,0xFF,0xF8,0x00,
    0x00,0x0F,0xFF,0x0F,0xFF,0x83,0xFF,0xE0,0xFF,0xF8,0x3F,0xFF,0xFF,0xFF,0xF8,0x00,
    0x00,0x1F,0xFF,0x07,0xFF,0x83,0xFF,0xE1,0xFF,0xF0,0x7F,0xFF,0xFF,0xFF,0xF0,0x00,
    0x00,0x1F,0xFE,0x07,0xFF,0xC1,0xFF,0xF1,0xFF,0xF0,0x7F,0xFF,0xFF,0xFF,0xE0,0x00,
    0x00,0x3F,0xFE,0x07,0xFF,0xC1,0xFF,0xF3,0xFF,0xE0,0x7F,0xFF,0xFF,0xFF,0xC0,0x00,
    0x00,0x3F,0xFE,0x03,0xFF,0xC0,0xFF,0xFB,0xFF,0xE0,0xFF,0xFF,0xFF,0xFF,0x80,0x00,
    0x00,0x7F,0xFC,0x03,0xFF,0xE0,0xFF,0xFB,0xFF,0xC0,0xFF,0xFF,0xFF,0xFF,0x00,0x00,
    0x00,0x7F,0xFC,0x03,0xFF,0xE0,0x7F,0xFF,0xFF,0xC1,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
    0x00,0x7F,0xF8,0x01,0xFF,0xF0,0x7F,0xFF,0xFF,0x81,0xFF,0xFF,0xFF,0xE0,0x00,0x00,
    0x00,0xFF,0xFF,0xFF,0xFF,0xF8,0x3F,0xFF,0xFF,0x83,0xFF,0xFF,0xFF,0xC0,0x00,0x00,
    0x00,0xFF,0xFF,0xFF,0xFF,0xF8,0x3F,0xFF,0xFF,0x83,0xFF,0xF3,0xFF,0xC0,0x00,0x00,
    0x00,0xFF,0xFF,0xFF,0xFF,0xF8,0x3F,0xFF,0xFF,0x03,0xFF,0xE3,0xFF,0xE0,0x00,0x00,
    0x01,0xFF,0xFF,0xFF,0xFF,0xFC,0x1F,0xFF,0xFF,0x07,0xFF,0xE3,0xFF,0xE0,0x00,0x00,
    0x01,0xFF,0xFF,0xFF,0xFF,0xFC,0x1F,0xFF,0xFE,0x07,0xFF,0xC3,0xFF,0xE0,0x00,0x00,
    0x03,0xFF,0xFF,0xFF,0xFF,0xFE,0x1F,0xFF,0xFE,0x0F,0xFF,0xC1,0xFF,0xF0,0x00,0x00,
    0x03,0xFF,0xFF,0xFF,0xFF,0xFE,0x0F,0xFF,0xFE,0x0F,0xFF,0x81,0xFF,0xF0,0x00,0x00,
    0x03,0xFF,0xFF,0xFF,0xFF,0xFE,0x0F,0xFF,0xFC,0x0F,0xFF,0x81,0xFF,0xF8,0x00,0x00,
    0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xFF,0xFC,0x1F,0xFF,0x81,0xFF,0xF8,0x00,0x00,
    0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xFF,0xF8,0x3F,0xFF,0x00,0xFF,0xF8,0x00,0x00,
    0x0F,0xFF,0xC0,0x00,0x1F,0xFF,0x83,0xFF,0xF8,0x3F,0xFF,0x00,0xFF,0xF8,0x00,0x00,
    0x0F,0xFF,0x80,0x00,0x0F,0xFF,0x83,0xFF,0xF0,0x3F,0xFE,0x00,0xFF,0xFC,0x00,0x00,
    0x0F,0xFF,0x80,0x00,0x0F,0xFF,0xC3,0xFF,0xF0,0x7F,0xFE,0x00,0x7F,0xFC,0x00,0x00,
    0x1F,0xFF,0x00,0x00,0x0F,0xFF,0xC1,0xFF,0xF0,0x7F,0xFC,0x00,0x7F,0xFC,0x00,0x00,
    0x1F,0xFF,0x00,0x00,0x07,0xFF,0xC1,0xFF,0xE0,0x7F,0xFC,0x00,0x7F,0xFE,0x00,0x00,
    0x1F,0xFF,0x00,0x00,0x07,0xFF,0xE0,0xFF,0xE0,0xFF,0xF8,0x00,0x7F,0xFE,0x00,0x00,
    0x3F,0xFE,0x00,0x00,0x03,0xFF,0xE0,0xFF,0xC0,0xFF,0xF8,0x00,0x3F,0xFE,0x00,0x00,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    void main()
        uchar i = 0;
        PORTB = 0XFF;           //
        DDRB = 0XFF;            //PB口全部设为输出模式
        Clr_CS();
        Clr_SID();
        Clr_SCLK();
        LCD_Init();
        Delay(50);
        LCD_Init();             //初始化两边是关键,否则液晶上电重起将不能显示
        while(1)
            nop();
            nop();
            Delay(500);
            Char_Set_XY(0,0,"ST7920_3_wires");
            Char_Set_XY(2,1,"反白练习");
            Char_Set_XY(0,2,"可以单字反白或不");
            Char_Set_XY(3,3,"反白");
            Delay(2000);
            Delay(2000);
            Set_Draw();
            Delay(100);
            Set_White(1,1,7,0);         //第1行,第1个汉字位置到第8汉字位置反白
            Set_White(3,2,6,0);         //第2行,第3个汉字位置到第6汉字位置反白
            Set_White(1,3,8,0);         //第3行,第1个汉字位置到第8汉字位置反白
            Set_White(4,4,5,0);         //第4行,第4个汉字位置到第5汉字位置反白
            Delay(2000);
            Delay(2000);
            Set_White(4,1,4,1);         //第1行,第4个汉字位置等取消反白
            Set_White(5,2,5,1);         //第2行,第5个汉字位置等取消反白
            Set_White(6,3,6,1);         //第3行,第6个汉字位置等取消反白
            Set_White(4,4,4,1);         //第4行,第4个汉字位置等取消反白
            Delay(2000);
            Delay(2000);
            Set_White(1,1,1,1);         //
            Set_White(3,2,3,1);         //
            Set_White(2,3,2,1);         //
            Set_White(5,4,5,1);         //
            Delay(2000);
            Delay(2000);
            Set_White(1,1,8,1);         //第1行,第1个汉字位置到第8汉字位置取消反白
            Set_White(1,2,8,1);         //第2行,第1个汉字位置到第8汉字位置取消反白
            Set_White(1,3,8,1);         //第3行,第1个汉字位置到第8汉字位置取消反白
            Set_White(1,4,8,1);         //第4行,第1个汉字位置到第8汉字位置取消反白
            Delay(2000);
            Delay(2000);
            W_1byte(0,0,0x30);      //基本指令集,,绘图显示OFF
            W_1byte(0,0,0x01);      //清除显示
            Set_Draw();
            Delay(100);
            Draw_Pic(0,0,*PIC1);    //先替换液晶内部RAM中的数据,再开显示
            W_1byte(0,0,0x36);      //8BIT控制界面,扩充指令集,,绘图显示ON
            Delay(5000);
            W_1byte(0,0,0x34);      //绘图显示OFF,主要解决画图时拖尾的现象,即先
                                    //替换好液晶内部RAM中的数据在开显示。
            Draw_Pic(0,0,*PIC2);
            W_1byte(0,0,0x36);      //8BIT控制界面,扩充指令集,绘图显示ON
            Delay(5000);
                                    //画完图后要显示文字要重新设置成普通模式
  1. /******************************************************************/
  2.     void LCD_Init(void)
  3.     {
  4.         uchar cmd;
  5.         cmd=0x30;           //功能设置 8位数据,基本指令
  6.         W_1byte(0,0,cmd);
  7.         Delay(2);
  8.         cmd=0x0C;           //显示状态 ON,游标OFF,反白OFF
  9.         W_1byte(0,0,cmd);   //写指令
  10.         Delay(2);
  11.         cmd=0x01;           //清除显示
  12.         W_1byte(0,0,cmd);   //写指令
  13.         Delay(2);
  14.         cmd=0x02;           //地址归位
  15.         W_1byte(0,0,cmd);   //写指令
  16.         Delay(2);
  17.         cmd=0x80;           //设置DDRAM地址
  18.         W_1byte(0,0,cmd);   //写指令
  19.         Delay(2);           //延时
  20.     }
  21.     /*******************************************************************
  22.     函 数 名:W_1byte
  23.     入口参数:RW、RS、W_data
  24.     出口参数:无
  25.     建立日期:2007年3月3日
  26.     修改日期:
  27.     函数作用:写一个字节的数据到12864液晶,包括指令和数据
  28.     说    明:RW=1,从液晶读数据到MCU;RW=0,写一个数据到液晶;
  29.              (一般RW都设为0,即只向液晶写数据,不读数据)
  30.               RS=1,写入的是数据;RS=0,写入的是指令;
  31.               一般模式:RW=0,RS=1;写数据
  32.                         RW=0,RS=0;写指令
  33.     ********************************************************************/
  34.     void W_1byte(uchar RW, uchar RS, uchar W_data)
  35.     {
  36.         uint H_data,L_data,S_ID = 0xf8;  //11111RWRS0
  37.         if(RW == 0)
  38.         {
  39.             S_ID &=~ 0x04;
  40.         }
  41.         else                    //if(RW==1)
  42.         {
  43.             S_ID |= 0X04;
  44.         }
  45.         if(RS == 0)
  46.         {
  47.             S_ID &=~ 0x02;
  48.         }
  49.         else                    //if(RS==1)
  50.         {
  51.             S_ID |= 0X02;
  52.         }
  53.         H_data = W_data;
  54.         H_data &= 0xf0;         //屏蔽低4位的数据
  55.         L_data = W_data;        //xxxx0000格式
  56.         L_data &= 0x0f;         //屏蔽高4位的数据
  57.         L_data <<= 4;         //xxxx0000格式
  58.         Set_CS();
  59.         Write_8bits(S_ID);      //发送S_ID
  60.         Write_8bits(H_data);    //发送H_data
  61.         Write_8bits(L_data);    //发送L_data
  62.         Clr_CS();
  63.     }
  64.     /********************************************************************
  65.     函 数 名:Write_8bits
  66.     入口参数:W_bits
  67.     出口参数:无
  68.     建立日期:2007年3月3日
  69.     修改日期:
  70.     函数作用:负责串行输出8个bit位
  71.     说    明:
  72.     ********************************************************************/
  73.     void Write_8bits(uint W_bits)
  74.     {
  75.         uint i,Temp_data;
  76.         for(i=0; i<8; i++)
  77.         {
  78.             Temp_data = W_bits;
  79.             Temp_data <<= i;
  80.             if((Temp_data&0x80)==0)
  81.             {
  82.                 Clr_SID();
  83.             }
  84.             else
  85.             {
  86.                 Set_SID();
  87.             }
  88.             nop();
  89.             Set_SCLK();
  90.             nop();
  91.             nop();
  92.             Clr_SCLK();
  93.             nop();
  94.             Clr_SID();
  95.         }
  96.     }
  97.     /********************************************************************
  98.     函 数 名:Delay
  99.     入口参数:ms
  100.     出口参数:无
  101.     建立日期:2007年3月3日
  102.     修改日期:
  103.     函数作用:毫秒级的延时程序,当晶振为12Mhz时,xtal=12;
  104.     说    明:
  105.     ********************************************************************/
  106.     void Delay(uint ms)
  107.     {
  108.         uint i;
  109.         while(ms--)
  110.        {
  111.          for(i=1;i<(uint)(xtal*143-2);i++)
  112.              ;
  113.        }
  114.     }
  115.     //===================================================================*/
  116.     /********************************************************************
  117.     函 数 名:Char_Set_XY
  118.     入口参数:x,y,*p
  119.     出口参数:无
  120.     建立日期:2007年8月26日
  121.     修改日期:
  122.     函数作用:
  123.     说    明:
  124.     ********************************************************************/
  125.     void Char_Set_XY(uchar x, uchar y, uchar *p)
  126.     {
  127.          if(y == 0)
  128.         {
  129.             W_1byte(0,0,(0x80+x));
  130.         }
  131.         if(y == 1)
  132.         {
  133.             W_1byte(0,0,(0x90+x));
  134.         }
  135.         if(y == 2)
  136.         {
  137.             W_1byte(0,0,(0x88+x));
  138.         }
  139.         if(y == 3)
  140.         {
  141.             W_1byte(0,0,(0x98+x));
  142.         }
  143.         while(*p != 0)
  144.         {
  145.             W_1byte(0,1,*p++);
  146.         }
  147.     }
  148.     //===================================================================*/
  149.
  150.     /********************************************************************
  151.     函 数 名:Set_Draw(
  152.     入口参数:无
  153.     出口参数:无
  154.     建立日期:2007年8月26日
  155.     修改日期:
  156.     函数作用:
  157.     说    明:
  158.     ********************************************************************/
  159.     void Set_Draw(void)
  160.     {
  161.         //W_1byte(0,0,0x01);            //清屏
  162.         Delay(20);                  //延时
  163.         //W_1byte(0,0,0x34);            //8BIT控制界面,扩充指令集,,绘图显示OFF
  164.         W_1byte(0,0,0x36);
  165.         Delay(20);                  //延时
  166.     }
 楼主| C洛达尔多 发表于 2016-2-29 19:54 | 显示全部楼层
  1. //===================================================================*/
  2.     /********************************************************************
  3.     函 数 名:Draw_Pic  128*64
  4.     入口参数:x,y,*Draw
  5.     出口参数:无
  6.     建立日期:2007年8月26日
  7.     修改日期:
  8.     函数作用:
  9.     说    明:
  10.     ********************************************************************/
  11.     /*************************************************/
  12.
  13.     void Draw_Pic(uchar x, uchar y, const uchar *Draw)
  14.     {
  15.         uchar i, j, temp_x, temp_y;     //
  16.         temp_x = x;                     //
  17.         temp_y = y;                     //
  18.         temp_x |= 0x80;                 //
  19.         temp_y |= 0x80;                 //
  20.         for(i=0;i<32;i++ )               //上半屏32行
  21.         {
  22.             W_1byte(0,0,temp_y++);      //设置绘图区的Y地址坐标0
  23.             W_1byte(0,0,temp_x);        //设置绘图区的X地址坐标0
  24.             for(j=0;j<16;j++)            //
  25.             {
  26.                  W_1byte(0,1,*Draw++);  //
  27.             }
  28.         }
  29.
  30.         temp_x = 0x88;                  //
  31.         temp_y = 0x80;                  //
  32.         j = 0;                          //
  33.         for(;i<64;i++ )
  34.         {
  35.             W_1byte(0,0,temp_y++);      //设置绘图区的Y地址坐标
  36.             W_1byte(0,0,temp_x);        //设置绘图区的X地址坐标
  37.             for(j=0;j<16;j++)
  38.             {
  39.                  W_1byte(0,1,*Draw++);  //
  40.             }
  41.         }
  42.
  43.     }
  44.     /**************************************************/
  45.     /**************************************************/
  46.     void Set_White(uchar x,uchar y,uchar end_x,uchar clear)
  47.     {
  48.         uchar i, j, white_x, white_y,white_end_x,clr_x,clr_y;       //
  49.         white_end_x = (end_x-x+1);
  50.         white_end_x <<= 1;
  51.         if(y==1)
  52.         {
  53.             white_x = (0x80+x-1);
  54.             white_y = 0x80;
  55.             clr_x = 0x80;
  56.             clr_y = 0x80;
  57.         }
  58.         else if(y==2)
  59.         {
  60.             white_x = (0x80+x-1);
  61.             white_y = 0x90;
  62.             clr_x = 0x80;
  63.             clr_y = 0x90;
  64.         }
  65.         else if(y==3)
  66.         {
  67.             white_x = (0x88+x-1);
  68.             white_y = 0x80;
  69.             clr_x = 0x88;
  70.             clr_y = 0x80;
  71.         }
  72.         else if(y==4)
  73.         {
  74.             white_x = (0x88+x-1);
  75.             white_y = 0x90;
  76.             clr_x = 0x88;
  77.             clr_y = 0x90;
  78.         }
  79.         if(clear==0)//要反白时,先将整行的液晶全部清成不反白(此处行指y)
  80.         {
  81.             for(i=0;i<16;i++ )           //16行
  82.             {
  83.                 W_1byte(0,0,clr_y++);   //设置绘图区的Y地址坐标0
  84.                 W_1byte(0,0,clr_x);     //设置绘图区的X地址坐标0
  85.                 for(j=0;j<16;j++)        //
  86.                 {
  87.                     W_1byte(0,1,0x00);  //清成不反白
  88.                     nop();
  89.                 }
  90.             }
  91.         }
  92.         nop();
  93.         for(i=0;i<16;i++ )               //16行,因为是16*16汉字
  94.         {
  95.             W_1byte(0,0,white_y++);     //设置绘图区的Y地址坐标0
  96.             W_1byte(0,0,white_x);       //设置绘图区的X地址坐标0
  97.             for(j=0;j<white_end_x;j++)   //
  98.             {
  99.                  if(clear==1)
  100.                  {
  101.                     W_1byte(0,1,0x00); //取消这一行的8个点的反白,液晶地址自动加1
  102.                                        //(此处行指一个一个液晶点所组成的行)
  103.                  }
  104.                  else
  105.                  {
  106.                     W_1byte(0,1,0xff); //反白这一行的8个点,液晶地址自动加1
  107.                                        //(此处行指一个一个液晶点所组成的行)
  108.                  }
  109.                  nop();
  110.             }
  111.         }
  112.     }
  113.     /*************************************************/
neeringstu 发表于 2016-3-3 16:08 | 显示全部楼层
这个LCD的程序是串行的吧
lovecat2015 发表于 2016-3-5 19:57 | 显示全部楼层
这个反白和画图不一样的道理吗
mintspring 发表于 2016-3-6 22:12 | 显示全部楼层
#define Set_CS()    DDRB |= (1<<CS)ORTB |= (1<<CS)
    #define Set_SID()   DDRB |= (1<<SID)ORTB |= (1<<SID)
    #define Set_SCLK()  DDRB |= (1<<SCLK)ORTB |= (1<<SCLK)
    #define Clr_CS()    DDRB |= (1<<CS)ORTB &=~(1<<CS)
    #define Clr_SID()   DDRB |= (1<<SID)ORTB &=~(1<<SID)
    #define Clr_SCLK()  DDRB |= (1<<SCLK)ORTB &=~(1<<SCLK)
mintspring 发表于 2016-3-6 22:13 | 显示全部楼层
为何前面几行都混用那个表情了,?楼主重新编辑看看有没有禁用表情的。
