msp430头文件解释说明
1641|8
 楼主| lefeng 发表于 2016-2-29 21:59 | 显示全部楼层 |阅读模式
msp430头文件解释说明,有中文注释
yiyigirl2014 发表于 2016-2-29 23:07 | 显示全部楼层
MSP430F149祥解
对头文件做了比较详细的注释,记不清寄存器的人可以看看
#ifndef __msp430x14x
#define __msp430x14x
* STANDARD BITS
#define BIT0                0x0001
#define BIT1                0x0002
#define BIT2                0x0004
#define BIT3                0x0008
#define BIT4                0x0010
#define BIT5                0x0020
#define BIT6                0x0040
#define BIT7                0x0080
#define BIT8                0x0100
#define BIT9                0x0200
#define BITA                0x0400
#define BITB                0x0800
#define BITC                0x1000
#define BITD                0x2000
#define BITE                0x4000
#define BITF                0x8000
* STATUS REGISTER BITS
#define C                  0x0001
#define Z                  0x0002
#define N                  0x0004
#define V                  0x0100
#define GIE                0x0008
#define CPUOFF              0x0010
#define OSCOFF              0x0020
#define SCG0                0x0040
#define SCG1                0x0080
/* Low Power Modes coded with Bits 4-7 in SR */
#ifndef __IAR_SYSTEMS_ICC /* Begin #defines for assembler */
#define LPM0                CPUOFF
#define LPM1                SCG0+CPUOFF
#define LPM2                SCG1+CPUOFF
#define LPM3                SCG1+SCG0+CPUOFF
#define LPM4                SCG1+SCG0+OSCOFF+CPUOFF
/* End #defines for assembler */
#else /* Begin #defines for C */
#define LPM0_bits          CPUOFF
#define LPM1_bits          SCG0+CPUOFF
#define LPM2_bits          SCG1+CPUOFF
#define LPM3_bits          SCG1+SCG0+CPUOFF
#define LPM4_bits          SCG1+SCG0+OSCOFF+CPUOFF
#include <In430.h>
#define LPM0      _BIS_SR(LPM0_bits) /* Enter Low Power Mode 0 */
#define LPM0_EXIT _BIC_SR(LPM0_bits) /* Exit Low Power Mode 0 */
#define LPM1      _BIS_SR(LPM1_bits) /* Enter Low Power Mode 1 */
#define LPM1_EXIT _BIC_SR(LPM1_bits) /* Exit Low Power Mode 1 */
#define LPM2      _BIS_SR(LPM2_bits) /* Enter Low Power Mode 2 */
#define LPM2_EXIT _BIC_SR(LPM2_bits) /* Exit Low Power Mode 2 */
#define LPM3      _BIS_SR(LPM3_bits) /* Enter Low Power Mode 3 */
#define LPM3_EXIT _BIC_SR(LPM3_bits) /* Exit Low Power Mode 3 */
#define LPM4      _BIS_SR(LPM4_bits) /* Enter Low Power Mode 4 */
#define LPM4_EXIT _BIC_SR(LPM4_bits) /* Exit Low Power Mode 4 */
#endif /* End #defines for C */
* PERIPHERAL FILE MAP
* 特殊功能寄存器地址和控制位
/*中断使能1*/
#define IE1_                0x0000
sfrb    IE1              = IE1_;
#define WDTIE              0x01    /*看门狗中断使能*/
#define OFIE                0x02    /*外部晶振故障中断使能*/
#define NMIIE              0x10    /*非屏蔽中断使能*/
#define ACCVIE              0x20    /*可屏蔽中断使能/flash写中断错误*/
#define URXIE0              0x40    /*串口0接收中断使能*/
#define UTXIE0              0x80    /*串口0发送中断使能*/
/*中断标志1*/
#define IFG1_              0x0002
sfrb    IFG1              = IFG1_;
#define WDTIFG              0x01    /*看门狗中断标志*/
#define OFIFG              0x02    /*外部晶振故障中断标志*/
#define NMIIFG              0x10    /*非屏蔽中断标志*/
#define URXIFG0            0x40    /*串口0接收中断标志*/
#define UTXIFG0            0x80    /*串口0发送中断标志*/
/* 中断模式使能1 */
#define ME1_                0x0004
sfrb    ME1              = ME1_;
#define URXE0              0x40        /* 串口0接收中断模式使能 */
#define USPIE0              0x40        /* 同步中断模式使能 */
#define UTXE0              0x80        /* 串口0发送中断模式使能 */
/* 中断使能2 */
#define IE2_                0x0001
sfrb    IE2              = IE2_;
#define URXIE1              0x10      /* 串口1接收中断使能 */
#define UTXIE1              0x20      /* 串口1发送中断使能 */
/* 中断标志2 */
#define IFG2_              0x0003
sfrb    IFG2              = IFG2_;
#define URXIFG1            0x10        /* 串口1接收中断标志 */
#define UTXIFG1            0x20        /* 串口1发送中断标志 */
/* 中断模式使能2 */
#define ME2_                0x0005
sfrb    ME2              = ME2_;
#define URXE1              0x10        /* 串口1接收中断模式使能 */
#define USPIE1              0x10        /* 同步中断模式使能 */
#define UTXE1              0x20        /* 串口1发送中断模式使能 */
*          看门狗定时器的寄存器定义
#define WDTCTL_            0x0120
sfrw    WDTCTL            = WDTCTL_;
#define WDTIS0              0x0001          /*选择WDTCNT的四个输出端之一*/
#define WDTIS1              0x0002          /*选择WDTCNT的四个输出端之一*/
#define WDTSSEL            0x0004          /*选择WDTCNT的时钟源*/
#define WDTCNTCL            0x0008          /*清除WDTCNT端: 为1时 从0开始计数*/
#define WDTTMSEL            0x0010          /*选择模式 0: 看门狗模式; 1: 定时器模式*/
#define WDTNMI              0x0020          /*选择NMI/RST 引脚功能 0:为 RST; 1:为NMI*/
#define WDTNMIES            0x0040          /*WDTNMI=1时.选择触发延 0:为上升延 1:为下降延*/
#define WDTHOLD            0x0080          /*停止看门狗定时器工作 0:启动;1:停止*/
#define WDTPW              0x5A00          /* 写密码:高八位*/
/* SMCLK= 1MHz定时器模式 */
#define WDT_MDLY_32        WDTPW+WDTTMSEL+WDTCNTCL                        /* TSMCLK*2POWER15=32ms 复位状态 */
#define WDT_MDLY_8          WDTPW+WDTTMSEL+WDTCNTCL+WDTIS0                  /* TSMCLK*2POWER13=8.192ms    " */
#define WDT_MDLY_0_5        WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1                  /* TSMCLK*2POWER9=0.512ms " */
#define WDT_MDLY_0_064      WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1+WDTIS0          /* TSMCLK*2POWER6=0.512ms " */
/* ACLK=32.768KHz 定时器模式*/
#define WDT_ADLY_1000      WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL                /* TACLK*2POWER15=1000ms " */
#define WDT_ADLY_250        WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS0          /* TACLK*2POWER13=250ms " */
#define WDT_ADLY_16        WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1          /* TACLK*2POWER9=16ms    " */
#define WDT_ADLY_1_9        WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0 /* TACLK*2POWER6=1.9ms " */
/* SMCLK=1MHz看门狗模式 */
#define WDT_MRST_32        WDTPW+WDTCNTCL                                  /* TSMCLK*2POWER15=32ms 复位状态 */
#define WDT_MRST_8          WDTPW+WDTCNTCL+WDTIS0                          /* TSMCLK*2POWER13=8.192ms " */
#define WDT_MRST_0_5        WDTPW+WDTCNTCL+WDTIS1                          /* TSMCLK*2POWER9=0.512ms " */
#define WDT_MRST_0_064      WDTPW+WDTCNTCL+WDTIS1+WDTIS0                    /* TSMCLK*2POWER6=0.512ms " */
/* ACLK=32KHz看门狗模式 */
#define WDT_ARST_1000      WDTPW+WDTCNTCL+WDTSSEL                          /* TACLK*2POWER15=1000ms " */
#define WDT_ARST_250        WDTPW+WDTCNTCL+WDTSSEL+WDTIS0                  /* TACLK*2POWER13=250ms " */
#define WDT_ARST_16        WDTPW+WDTCNTCL+WDTSSEL+WDTIS1                  /* TACLK*2POWER9=16ms    " */
#define WDT_ARST_1_9        WDTPW+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0            /* TACLK*2POWER6=1.9ms " */
            硬件乘法器的寄存器定义
#define MPY_                0x0130 /* 无符号乘法 */
sfrw    MPY              = MPY_;
#define MPYS_              0x0132 /* 有符号乘法*/
sfrw    MPYS              = MPYS_;
#define MAC_                0x0134 /* 无符号乘加 */
sfrw    MAC              = MAC_;
#define MACS_              0x0136 /* 有符号乘加 */
sfrw    MACS              = MACS_;
#define OP2_                0x0138 /* 第二乘数 */
sfrw    OP2              = OP2_;
#define RESLO_              0x013A /* 低6位结果寄存器 */
sfrw    RESLO            = RESLO_;
#define RESHI_              0x013C /* 高6位结果寄存器 */
sfrw    RESHI            = RESHI_;
#define SUMEXT_            0x013E /*结果扩展寄存器 */
const sfrw SUMEXT        = SUMEXT_;
* DIGITAL I/O Port1/2 寄存器定义 有中断功能
#define P1IN_              0x0020 /* P1 输入寄存器 */
const sfrb P1IN          = P1IN_;
#define P1OUT_              0x0021 /* P1 输出寄存器 */
sfrb    P1OUT            = P1OUT_;
#define P1DIR_              0x0022 /* P1 方向选择寄存器 */
sfrb    P1DIR            = P1DIR_;
#define P1IFG_              0x0023 /* P1 中断标志寄存器*/
sfrb    P1IFG            = P1IFG_;
#define P1IES_              0x0024 /* P1 中断边沿选择寄存器*/
sfrb    P1IES            = P1IES_;
#define P1IE_              0x0025 /* P1 中断使能寄存器 */
sfrb    P1IE              = P1IE_;
#define P1SEL_              0x0026 /* P1 功能选择寄存器*/
sfrb    P1SEL            = P1SEL_;
#define P2IN_              0x0028 /* P2 输入寄存器 */
const sfrb P2IN          = P2IN_;
#define P2OUT_              0x0029 /* P2 输出寄存器 */
sfrb    P2OUT            = P2OUT_;
#define P2DIR_              0x002A /* P2 方向选择寄存器 */
sfrb    P2DIR            = P2DIR_;
#define P2IFG_              0x002B /* P2 中断标志寄存器 */
sfrb    P2IFG            = P2IFG_;
#define P2IES_              0x002C /* P2 中断边沿选择寄存器 */
sfrb    P2IES            = P2IES_;
#define P2IE_              0x002D /* P2 中断使能寄存器 */
sfrb    P2IE              = P2IE_;
#define P2SEL_              0x002E /* P2 功能选择寄存器 */
sfrb    P2SEL            = P2SEL_;
* DIGITAL I/O Port3/4寄存器定义 无中断功能
#define P3IN_              0x0018 /* P3 输入寄存器 */
const sfrb P3IN          = P3IN_;
#define P3OUT_              0x0019 /* P3 输出寄存器 */
sfrb    P3OUT            = P3OUT_;
#define P3DIR_              0x001A /* P3 方向选择寄存器 */
sfrb    P3DIR            = P3DIR_;
#define P3SEL_              0x001B /* P3 功能选择寄存器*/
sfrb    P3SEL            = P3SEL_;
#define P4IN_              0x001C /* P4 输入寄存器 */
const sfrb P4IN          = P4IN_;
#define P4OUT_              0x001D /* P4 输出寄存器 */
sfrb    P4OUT            = P4OUT_;
#define P4DIR_              0x001E /* P4 方向选择寄存器 */
sfrb    P4DIR            = P4DIR_;
#define P4SEL_              0x001F /* P4 功能选择寄存器 */
sfrb    P4SEL            = P4SEL_;
* DIGITAL I/O Port5/6      I/O口寄存器定义PORT5和6 无中断功能
#define P5IN_              0x0030 /* P5 输入寄存器 */
const sfrb P5IN          = P5IN_;
#define P5OUT_              0x0031 /* P5 输出寄存器*/
sfrb    P5OUT            = P5OUT_;
#define P5DIR_              0x0032 /* P5 方向选择寄存器*/
sfrb    P5DIR            = P5DIR_;
#define P5SEL_              0x0033 /* P5 功能选择寄存器*/
sfrb    P5SEL            = P5SEL_;
#define P6IN_              0x0034 /* P6 输入寄存器 */
const sfrb P6IN          = P6IN_;
#define P6OUT_              0x0035 /* P6 输出寄存器*/
sfrb    P6OUT            = P6OUT_;
#define P6DIR_              0x0036 /* P6 方向选择寄存器*/
sfrb    P6DIR            = P6DIR_;
#define P6SEL_              0x0037 /* P6 功能选择寄存器*/
sfrb    P6SEL            = P6SEL_;
//2
* USART 串口寄存器"UCTL","UTCTL","URCTL"定义的各个位 可串口1 串口2公用
/* UCTL 串口控制寄存器*/
#define PENA                0x80        /*校验允许位*/
#define PEV                0x40        /*偶校验 为0时为奇校验*/
#define SPB                0x20        /*停止位为2 为0时停止位为1*/
#define CHAR                0x10        /*数据位为8位 为0时数据位为7位*/
#define LISTEN              0x08        /*自环模式(发数据同时在把发的数据接收回来)*/
#define SYNC                0x04        /*同步模式 为0异步模式*/
#define MM                  0x02        /*为1时地址位多机协议(异步) 主机模式(同步);为0时线路空闲多机协议(异步) 从机模式(同步)*/
#define SWRST              0x01        /*控制位*/
/* UTCTL 串口发送控制寄存器*/
#define CKPH                0x80        /*时钟相位控制位(只同步方式用)为1时时钟UCLK延时半个周期*/
#define CKPL                0x40        /*时钟极性控制位 为1时异步与UCLK相反;同步下降延有效*/
#define SSEL1              0x20        /*时钟源选择位:与SSEL0组合为0,1,2,3四种方式*/
#define SSEL0              0x10        /*"0"选择外部时钟,"1"选择辅助时钟,"2","3"选择系统子时钟 */
#define URXSE              0x08        /*接收触发延控制位(只在异步方式下用)*/
#define TXWAKE              0x04        /*多处理器通信传送控制位(只在异步方式下用)*/
#define STC                0x02        /*外部引脚STE选择位 为0时为4线模式 为1时为3线模式*/
#define TXEPT              0x01        /*发送器空标志*/
/* URCTL 串口接收控制寄存器                同步模式下只用两位:FE和OE*/
#define FE                  0x80        /*帧错标志*/
#define PE                  0x40        /*校验错标志位*/
#define OE                  0x20        /*溢出标志位*/
#define BRK                0x10        /*打断检测位*/
#define URXEIE              0x08        /*接收出错中断允许位*/
#define URXWIE              0x04        /*接收唤醒中断允许位*/
#define RXWAKE              0x02        /*接收唤醒检测位*/
#define RXERR              0x01        /*接收错误标志位*/
* USART 0          串口0寄存器定义
#define U0CTL_              0x0070 /* 串口0基本控制寄存器 */
sfrb    U0CTL            = U0CTL_;
#define U0TCTL_            0x0071 /* 串口0发送控制寄存器 */
sfrb    U0TCTL            = U0TCTL_;
#define U0RCTL_            0x0072 /* 串口0接收控制寄存器 */
sfrb    U0RCTL            = U0RCTL_;
#define U0MCTL_            0x0073 /* 波特率调整寄存器 */
sfrb    U0MCTL            = U0MCTL_;
#define U0BR0_              0x0074 /* 波特率选择寄存器0 */
sfrb    U0BR0            = U0BR0_;
#define U0BR1_              0x0075 /* 波特率选择寄存器1 */
sfrb    U0BR1            = U0BR1_;
#define U0RXBUF_            0x0076 /* 接收缓存寄存器 */
const sfrb U0RXBUF        = U0RXBUF_;
#define U0TXBUF_            0x0077 /* 发送缓存寄存器 */
sfrb    U0TXBUF          = U0TXBUF_;
/* 改变的寄存器名定义 */
#define UCTL0_              0x0070 /* UART 0 Control */
sfrb    UCTL0            = UCTL0_;
#define UTCTL0_            0x0071 /* UART 0 Transmit Control */
sfrb    UTCTL0            = UTCTL0_;
#define URCTL0_            0x0072 /* UART 0 Receive Control */
sfrb    URCTL0            = URCTL0_;
#define UMCTL0_            0x0073 /* UART 0 Modulation Control */
sfrb    UMCTL0            = UMCTL0_;
#define UBR00_              0x0074 /* UART 0 Baud Rate 0 */
sfrb    UBR00            = UBR00_;
#define UBR10_              0x0075 /* UART 0 Baud Rate 1 */
sfrb    UBR10            = UBR10_;
#define RXBUF0_            0x0076 /* UART 0 Receive Buffer */
const sfrb RXBUF0        = RXBUF0_;
#define TXBUF0_            0x0077 /* UART 0 Transmit Buffer */
sfrb    TXBUF0            = TXBUF0_;
#define UCTL_0_            0x0070 /* UART 0 Control */
sfrb    UCTL_0            = UCTL_0_;
#define UTCTL_0_            0x0071 /* UART 0 Transmit Control */
sfrb    UTCTL_0          = UTCTL_0_;
#define URCTL_0_            0x0072 /* UART 0 Receive Control */
sfrb    URCTL_0          = URCTL_0_;
#define UMCTL_0_            0x0073 /* UART 0 Modulation Control */
sfrb    UMCTL_0          = UMCTL_0_;
#define UBR0_0_            0x0074 /* UART 0 Baud Rate 0 */
sfrb    UBR0_0            = UBR0_0_;
#define UBR1_0_            0x0075 /* UART 0 Baud Rate 1 */
sfrb    UBR1_0            = UBR1_0_;
#define RXBUF_0_            0x0076 /* UART 0 Receive Buffer */
const sfrb RXBUF_0        = RXBUF_0_;
#define TXBUF_0_            0x0077 /* UART 0 Transmit Buffer */
sfrb    TXBUF_0          = TXBUF_0_;
* USART 1        串口1寄存器定义
#define U1CTL_              0x0078 /* 串口1基本控制寄存器 */
sfrb    U1CTL            = U1CTL_;
#define U1TCTL_            0x0079 /* 串口1发送控制寄存器 */
sfrb    U1TCTL            = U1TCTL_;
#define U1RCTL_            0x007A /* 串口1接收控制寄存器 */
sfrb    U1RCTL            = U1RCTL_;
#define U1MCTL_            0x007B /* 波特率调整控制寄存器 */
sfrb    U1MCTL            = U1MCTL_;
#define U1BR0_              0x007C /* 波特率选择寄存器0 */
sfrb    U1BR0            = U1BR0_;
#define U1BR1_              0x007D /* 波特率选择寄存器1 */
sfrb    U1BR1            = U1BR1_;
#define U1RXBUF_            0x007E /* 接收缓存 */
const sfrb U1RXBUF        = U1RXBUF_;
#define U1TXBUF_            0x007F /* 发送缓存 */
sfrb    U1TXBUF          = U1TXBUF_;
/* 改变的寄存器名定义 */
#define UCTL1_              0x0078 /* UART 1 Control */
sfrb    UCTL1            = UCTL1_;
#define UTCTL1_            0x0079 /* UART 1 Transmit Control */
sfrb    UTCTL1            = UTCTL1_;
#define URCTL1_            0x007A /* UART 1 Receive Control */
sfrb    URCTL1            = URCTL1_;
#define UMCTL1_            0x007B /* UART 1 Modulation Control */
sfrb    UMCTL1            = UMCTL1_;
#define UBR01_              0x007C /* UART 1 Baud Rate 0 */
sfrb    UBR01            = UBR01_;
#define UBR11_              0x007D /* UART 1 Baud Rate 1 */
sfrb    UBR11            = UBR11_;
#define RXBUF1_            0x007E /* UART 1 Receive Buffer */
const sfrb RXBUF1        = RXBUF1_;
#define TXBUF1_            0x007F /* UART 1 Transmit Buffer */
sfrb    TXBUF1            = TXBUF1_;
yiyigirl2014 发表于 2016-2-29 23:08 | 显示全部楼层
#define UCTL_1_            0x0078 /* UART 1 Control */
sfrb    UCTL_1            = UCTL_1_;
#define UTCTL_1_            0x0079 /* UART 1 Transmit Control */
sfrb    UTCTL_1          = UTCTL_1_;
#define URCTL_1_            0x007A /* UART 1 Receive Control */
sfrb    URCTL_1          = URCTL_1_;
#define UMCTL_1_            0x007B /* UART 1 Modulation Control */
sfrb    UMCTL_1          = UMCTL_1_;
#define UBR0_1_            0x007C /* UART 1 Baud Rate 0 */
sfrb    UBR0_1            = UBR0_1_;
#define UBR1_1_            0x007D /* UART 1 Baud Rate 1 */
sfrb    UBR1_1            = UBR1_1_;
#define RXBUF_1_            0x007E /* UART 1 Receive Buffer */
const sfrb RXBUF_1        = RXBUF_1_;
#define TXBUF_1_            0x007F /* UART 1 Transmit Buffer */
sfrb    TXBUF_1          = TXBUF_1_;
* Timer A            定时器A寄存器定义
#define TAIV_              0x012E /* Timer A 中断向量寄存器 */
sfrw    TAIV              = TAIV_;
#define TACTL_              0x0160 /* Timer A 控制寄存器 */
sfrw    TACTL            = TACTL_;
#define TACCTL0_            0x0162 /* Timer A 捕获/比较控制寄存器0 */
sfrw    TACCTL0          = TACCTL0_;
#define TACCTL1_            0x0164 /* Timer A 捕获/比较控制寄存器1 */
sfrw    TACCTL1          = TACCTL1_;
#define TACCTL2_            0x0166 /* Timer A 捕获/比较控制寄存器2 */
sfrw    TACCTL2          = TACCTL2_;
#define TAR_                0x0170 /* Timer A 16位计数器内容*/
sfrw    TAR              = TAR_;
#define TACCR0_            0x0172 /* Timer A 捕获/比较寄存器0 */
sfrw    TACCR0            = TACCR0_;
#define TACCR1_            0x0174 /* Timer A 捕获/比较寄存器1 */
sfrw    TACCR1            = TACCR1_;
#define TACCR2_            0x0176 /* Timer A 捕获/比较寄存器2 */
sfrw    TACCR2            = TACCR2_;
/* 改变的寄存器名定义 */
#define CCTL0_              0x0162 /* Timer A Capture/Compare Control 0 */
sfrw    CCTL0            = CCTL0_;
#define CCTL1_              0x0164 /* Timer A Capture/Compare Control 1 */
sfrw    CCTL1            = CCTL1_;
#define CCTL2_              0x0166 /* Timer A Capture/Compare Control 2 */
sfrw    CCTL2            = CCTL2_;
#define CCR0_              0x0172 /* Timer A Capture/Compare 0 */
sfrw    CCR0              = CCR0_;
#define CCR1_              0x0174 /* Timer A Capture/Compare 1 */
sfrw    CCR1              = CCR1_;
#define CCR2_              0x0176 /* Timer A Capture/Compare 2 */
sfrw    CCR2              = CCR2_;
/*TACTL 控制寄存器 16个位寄存器定义*///对应寄存器的位
#define TASSEL2            0x0400 /* 未用 */
#define TASSEL1            0x0200 /* 时钟输入源控制位1 */
#define TASSEL0            0x0100 /* 时钟输入源控制位0 */
#define ID1                0x0080 /* 分频系数选择位1 */
#define ID0                0x0040 /* 分频系数选择位0 */
#define MC1                0x0020 /* 计数模式控制位1 */
#define MC0                0x0010 /* 计数模式控制位0 */
#define TACLR              0x0004 /* 置1位清除定时器 */
#define TAIE                0x0002 /* 定时器中断允许 */
#define TAIFG              0x0001 /* 定时器中断标志 */
//对应寄存器的位 的相应的 选择模式
#define MC_0                00*0x10 /* 停止模式 */
#define MC_1                01*0x10 /* 增计数模式 */
#define MC_2                02*0x10 /* 连续计数模式 */
#define MC_3                03*0x10 /* 增/减计数模式 */
#define ID_0                00*0x40 /* 直通 */
#define ID_1                01*0x40 /* 2分频 */
#define ID_2                02*0x40 /* 4分频 */
#define ID_3                03*0x40 /* 8分频 */
#define TASSEL_0            00*0x100 /* 时钟源为 TACLK */
#define TASSEL_1            01*0x100 /* 时钟源为ACLK */
#define TASSEL_2            02*0x100 /* 时钟源为SMCLK */
#define TASSEL_3            03*0x100 /* 时钟源为INCLK */
//3
/* Timer A ,Timer B 可公用 捕获/比较控制寄存器X */
#define CM1                0x8000 /* 捕获模式选择位1 */
#define CM0                0x4000 /* 捕获模式选择位0 */
#define CCIS1              0x2000 /* 捕获输入信号源选择位1 */
#define CCIS0              0x1000 /* 捕获输入信号源选择位0 */
#define SCS                0x0800 /* 信号同步位 0:异步捕获;1:同步捕获 */
#define SCCI                0x0400 /* 锁存输入信号 */
#define CAP                0x0100 /* 模式选择: 0:比较模式;1:捕获模式 */
#define OUTMOD2            0x0080 /* 输出模式选择位2 */
#define OUTMOD1            0x0040 /* 输出模式选择位1 */
#define OUTMOD0            0x0020 /* 输出模式选择位0 */
#define CCIE                0x0010 /* 中断允许位 */
#define CCI                0x0008 /* 读出输入信号源位ccis0\1 */
#define OUT                0x0004 /* 输出信号(选择输出模式0) */
#define COV                0x0002 /* 捕获溢出标志 */
#define CCIFG              0x0001 /* 中断标志 */
#define OUTMOD_0            0*0x20 /* 输出模式 */
#define OUTMOD_1            1*0x20 /* 置位模式 */
#define OUTMOD_2            2*0x20 /* 翻转/复位模式 */
#define OUTMOD_3            3*0x20 /* 置位/复位模式 */
#define OUTMOD_4            4*0x20 /* 翻转模式 */
#define OUTMOD_5            5*0x20 /* 复位模式 */
#define OUTMOD_6            6*0x20 /* 翻转/置位模式 */
#define OUTMOD_7            7*0x20 /* 复位/置位模式*/
#define CCIS_0              0*0x1000 /* 选择CCIXA为捕获事件的输入信号源 */
#define CCIS_1              1*0x1000 /* 选择CCIXB为捕获事件的输入信号源 */
#define CCIS_2              2*0x1000 /* 选择GND为捕获事件的输入信号源 */
#define CCIS_3              3*0x1000 /* 选择VCC为捕获事件的输入信号源 */
#define CM_0                0*0x4000 /* 禁止捕获模式 */
#define CM_1                1*0x4000 /* 上升延捕获模式 */
#define CM_2                2*0x4000 /* 下降沿捕获模式 */
#define CM_3                3*0x4000 /* 上升沿和下降沿都捕获模式 */
* Timer B        定时器B寄存器定义
#define TBIV_              0x011E /* 中断向量寄存器:BIT1-BIT3有效 */
sfrw    TBIV              = TBIV_;
#define TBCTL_              0x0180 /* 定时器B控制寄存器:全部控制都集中在这 */
sfrw    TBCTL            = TBCTL_;
#define TBCCTL0_            0x0182 /* 定时器B捕获/比较控制寄存器0*/
sfrw    TBCCTL0          = TBCCTL0_;
#define TBCCTL1_            0x0184 /* 定时器B捕获/比较控制寄存器1 */
sfrw    TBCCTL1          = TBCCTL1_;
#define TBCCTL2_            0x0186 /* 定时器B捕获/比较控制寄存器2 */
sfrw    TBCCTL2          = TBCCTL2_;
#define TBCCTL3_            0x0188 /* 定时器B捕获/比较控制寄存器3 */
sfrw    TBCCTL3          = TBCCTL3_;
#define TBCCTL4_            0x018A /* 定时器B捕获/比较控制寄存器4 */
sfrw    TBCCTL4          = TBCCTL4_;
#define TBCCTL5_            0x018C /* 定时器B捕获/比较控制寄存器5 */
sfrw    TBCCTL5          = TBCCTL5_;
#define TBCCTL6_            0x018E /* 定时器B捕获/比较控制寄存器6 */
sfrw    TBCCTL6          = TBCCTL6_;
#define TBR_                0x0190 /* 计数器 */
sfrw    TBR              = TBR_;
#define TBCCR0_            0x0192 /* 定时器B捕获/比较寄存器0 */
sfrw    TBCCR0            = TBCCR0_;
#define TBCCR1_            0x0194 /* 定时器B捕获/比较寄存器1 */
sfrw    TBCCR1            = TBCCR1_;
#define TBCCR2_            0x0196 /* 定时器B捕获/比较寄存器2 */
sfrw    TBCCR2            = TBCCR2_;
#define TBCCR3_            0x0198 /* 定时器B捕获/比较寄存器3 */
sfrw    TBCCR3            = TBCCR3_;
#define TBCCR4_            0x019A /* 定时器B捕获/比较寄存器4 */
sfrw    TBCCR4            = TBCCR4_;
#define TBCCR5_            0x019C /* 定时器B捕获/比较寄存器5 */
sfrw    TBCCR5            = TBCCR5_;
#define TBCCR6_            0x019E /* 定时器B捕获/比较寄存器6 */
sfrw    TBCCR6            = TBCCR6_;
#define SHR1                0x4000 /* 装载比较锁存器控制位1 :受TBCCTLx中的CCLDx位控制 */
#define SHR0                0x2000 /* 装载比较锁存器控制位0 :受TBCCTLx中的CCLDx位控制*/
#define TBCLGRP1            0x4000 /* 装载比较锁存器控制位1 :受TBCCTLx中的CCLDx位控制*/
#define TBCLGRP0            0x2000 /* 装载比较锁存器控制位0 :受TBCCTLx中的CCLDx位控制*/
#define CNTL1              0x1000 /* 定时器位数长度控制位1 */
#define CNTL0              0x0800 /* 定时器位数长度控制位0 */
#define TBSSEL2            0x0400 /* 未用 */
#define TBSSEL1            0x0200 /* 时钟输入源控制位1 */
#define TBSSEL0            0x0100 /* 时钟输入源控制位0 */
#define TBCLR              0x0004 /* 置1清除定时器 */
#define TBIE                0x0002 /* 中断允许 */
#define TBIFG              0x0001 /* 中断标志 */
#define TBSSEL_0            0*0x0100 /* 时钟源为:TBCLK */
#define TBSSEL_1            1*0x0100 /* 时钟源为: ACLK */
#define TBSSEL_2            2*0x0100 /* 时钟源为:SMCLK */
#define TBSSEL_3            3*0x0100 /* 时钟源为:INCLK */
#define CNTL_0              0*0x0800 /* 16 位计数模式*/
#define CNTL_1              1*0x0800 /* 12 位计数模式*/
#define CNTL_2              2*0x0800 /* 10 位计数模式 */
#define CNTL_3              3*0x0800 /* 8 位计数模式 */
#define SHR_0                0*0x2000 /* 单独装载(初始值) */
#define SHR_1                1*0x2000 /* 分三组装载: 1 - 3 groups (1-2, 3-4, 5-6) */
#define SHR_2                2*0x2000 /* 分二组装载: 2 - 2 groups (1-3, 4-6)*/
#define SHR_3                3*0x2000 /* 不分组装载: 3 - 1 group (all) */
#define TBCLGRP_0            0*0x2000 /* 单独装载(初始值) */
#define TBCLGRP_1            1*0x2000 /* 分三组装载: 1 - 3 groups (1-2, 3-4, 5-6) */
#define TBCLGRP_2            2*0x2000 /* 分二组装载: 2 - 2 groups (1-3, 4-6)*/
#define TBCLGRP_3            3*0x2000 /* 不分组装载: 3 - 1 group (all) */
/* Additional Timer B Control Register bits are defined in Timer A */
#define SLSHR1              0x0400 /* Compare latch load source 1 */
#define SLSHR0              0x0200 /* Compare latch load source 0 */
#define CLLD1              0x0400 /* 定义比较锁存器TBCLx的装载方式控制位1 */
#define CLLD0              0x0200 /* 定义比较锁存器TBCLx的装载方式控制位0 */
#define SLSHR_0              0*0x0200 /* 立即装载 */
#define SLSHR_1              1*0x0200 /* TBR 计数到0时装载 */
#define SLSHR_2              2*0x0200 /* 在增减模式下,计数到TBCLx或0时装载; 在连续计数模式下,计数到0时装载 */
#define SLSHR_3              3*0x0200 /* 当计数到TBCL0时装载*/
#define CLLD_0              0*0x0200 /* 立即装载 */
#define CLLD_1              1*0x0200 /* TBR 计数到0时装载 */
#define CLLD_2              2*0x0200 /* 在增减模式下,计数到TBCLx或0时装载; 在连续计数模式下,计数到0时装载 */
#define CLLD_3              3*0x0200 /* 当计数到TBCL0时装载 */
点击查看:怎样获取“电子币”的详细说明---漫步于开源世界之中,一起与自由同行!
Posted: 2007-04-13 00:14 | [楼 主]
hueiyew
级别: 新手上路
发帖: 24
威望: 25 点
电子币: 46 元
贡献值: 0 点
* Basic Clock Module
#define DCOCTL_            0x0056 /* DCO 时钟频率控制寄存器 :复位后的值位060h*/
sfrb    DCOCTL            = DCOCTL_;
#define BCSCTL1_            0x0057 /* 系统时钟控制寄存器1 :复位后的值位084h*/
sfrb    BCSCTL1          = BCSCTL1_;
#define BCSCTL2_            0x0058 /* 系统时钟控制寄存器2 :复位后的值位000h*/
sfrb    BCSCTL2          = BCSCTL2_;
/* DCO 时钟频率控制寄存器 */
#define MOD0                0x01 /* DCO插入周期控制位0 */
#define MOD1                0x02 /* DCO插入周期控制位1 */
#define MOD2                0x04 /* DCO插入周期控制位2 */
#define MOD3                0x08 /* DCO插入周期控制位3 */
#define MOD4                0x10 /* DCO插入周期控制位4 */
#define DCO0                0x20 /* 8种频率控制位0 */
#define DCO1                0x40 /* 8种频率控制位1 */
#define DCO2                0x80 /* 8种频率控制位2 */
#define RSEL0              0x01 /* 选择内部电阻控制位0 */
#define RSEL1              0x02 /* 选择内部电阻控制位1 */
#define RSEL2              0x04 /* 选择内部电阻控制位2 */
#define XT5V                0x08 /* 必须为0*/
#define DIVA0              0x10 /* ACLK分频系数控制位0*/
#define DIVA1              0x20 /* ACLK分频系数控制位1 */
#define XTS                0x40 /* LFXT1工作模式控制位 0:低频模式. / 1: 高频模式. */
#define XT2OFF              0x80 /* XT2CLK 使能控制位 0:开启; 1:关闭 */
#define DIVA_0              0x00 /* ACLK分频系数为: 1 */
#define DIVA_1              0x10 /* ACLK分频系数为: 2 */
#define DIVA_2              0x20 /* ACLK分频系数为: 4 */
#define DIVA_3              0x30 /* ACLK分频系数为: 8 */
#define DCOR                0x01 /* 内外电阻选择控制位 */
#define DIVS0              0x02 /* SMCLK分频控制位0*/
#define DIVS1              0x04 /* SMCLK分频控制位1 */
#define SELS                0x08 /* SMCLK 时钟源选择位t 0:DCOCLK / 1:XT2CLK/LFXTCLK */
#define DIVM0              0x10 /* MCLK分频控制位0 */
#define DIVM1              0x20 /* MCLK分频控制位1 */
#define SELM0              0x40 /* MCLK 时钟输入源选择位0 */
#define SELM1              0x80 /* MCLK 时钟输入源选择位1 */
#define DIVS_0              0x00 /* SMCLK 分频系数为: 1 */
#define DIVS_1              0x02 /* SMCLK 分频系数为: 2 */
#define DIVS_2              0x04 /* SMCLK 分频系数为: 4 */
#define DIVS_3              0x06 /* SMCLK 分频系数为: 8 */
#define DIVM_0              0x00 /* MCLK 分频系数为: 1 */
#define DIVM_1              0x10 /* MCLK 分频系数为: 2 */
#define DIVM_2              0x20 /* MCLK 分频系数为: 4 */
#define DIVM_3              0x30 /* MCLK 分频系数为: 8 */
#define SELM_0              0x00 /* MCLK 时钟输入源: DCOCLK */
#define SELM_1              0x40 /* MCLK 时钟输入源: DCOCLK */
#define SELM_2              0x80 /* MCLK 时钟输入源: XT2CLK/LFXTCLK */
#define SELM_3              0xC0 /* MCLK 时钟输入源: LFXTCLK */
* Flash Memory      FLASH操作寄存器定义
#define FCTL1_              0x0128 /* FLASH控制寄存器1:控制编程、擦除 */
sfrw    FCTL1            = FCTL1_;
#define FCTL2_              0x012A /* FLASH 控制寄存器2 :控制时钟分频*/
sfrw    FCTL2            = FCTL2_;
#define FCTL3_              0x012C /* FLASH 控制寄存器3: 状态标志 */
sfrw    FCTL3            = FCTL3_;
#define FRKEY              0x9600 /* 读FLASH 密码 */
#define FWKEY              0xA500 /* 写FLASH 密码 */
#define FXKEY              0x3300 /* for use with XOR instruction */
#define ERASE              0x0002 /* 擦除段使能 */
#define MERAS              0x0004 /* 主存擦除使能 */
#define WRT                0x0040 /* 编程使能 */
#define BLKWRT              0x0080 /* 段编程使能 */
雾霾和青山 发表于 2016-2-29 23:08 | 显示全部楼层
中文的解释,不错
yiyigirl2014 发表于 2016-2-29 23:09 | 显示全部楼层
#define FN_0                0x0000 /*直通 */
#define FN_1                0x0001 /*2分频 */
#define FN_2                0x0002 /*3分频*/
#define FN_3                0x0003 /*4分频 */
#define FN_4                0x0004 /*5分频 */
#define FN_5                0x0005 /*6分频*/
#define FN_6                0x0006 /*7分频 */
#define FN_7                0x0007 /*8分频*/
#define FN_8                0x0008 /*9分频 */
#define FN_9                0x0009 /*10分频 */
#define FN_10                0x000A /*11分频*/
#define FN_11                0x000B /*12分频 */
#define FN_12                0x000C /*13分频*/
#define FN_13                0x000D /*14分频 */
#define FN_14                0x000E /*15分频 */
#define FN_15                0x000F /*16分频*/
#define FN_16                0x0010 /*17分频 */
#define FN_17                0x0011 /*18分频*/
#define FN_18                0x0012 /*19分频 */
#define FN_19                0x0013 /*20分频 */
#define FN_20                0x0014 /*21分频*/
#define FN_21                0x0015 /*22分频 */
#define FN_22                0x0016 /*23分频*/
#define FN_23                0x0017 /*24分频 */
#define FN_24                0x0018 /*25分频 */
#define FN_25                0x0019 /*26分频*/
#define FN_26                0x001A /*27分频 */
#define FN_27                0x001B /*28分频*/
#define FN_28                0x001C /*29分频 */
#define FN_29                0x001D /*30分频 */
#define FN_30                0x001E /*31分频*/
#define FN_31                0x001F /*32分频 */
#define FN_32                0x0020 /*33分频*/
#define FN_33                0x0021 /*34分频 */
#define FN_34                0x0022 /*35分频 */
#define FN_35                0x0023 /*36分频*/
#define FN_36                0x0024 /*37分频 */
#define FN_37                0x0025 /*38分频*/
#define FN_38                0x0026 /*39分频 */
#define FN_39                0x0027 /*40分频 */
#define FN_40                0x0028 /*41分频*/
#define FN_41                0x0029 /*42分频 */
#define FN_42                0x002A /*43分频*/
#define FN_43                0x002B /*44分频 */
#define FN_44                0x002C /*45分频 */
#define FN_45                0x002D /*46分频*/
#define FN_46                0x002E /*47分频 */
#define FN_47                0x002F /*48分频*/
#define FN_48                0x0030 /*49分频 */
#define FN_49                0x0031 /*50分频 */
#define FN_50                0x0032 /*51分频*/
#define FN_51                0x0033 /*52分频 */
#define FN_52                0x0034 /*53分频*/
#define FN_53                0x0035 /*54分频 */
#define FN_54                0x0036 /*55分频 */
#define FN_55                0x0037 /*56分频*/
#define FN_56                0x0038 /*57分频 */
#define FN_57                0x0039 /*58分频*/
#define FN_58                0x003A /*59分频 */
#define FN_59                0x003B /*60分频 */
#define FN_60                0x003C /*61分频*/
#define FN_61                0x003D /*62分频 */
#define FN_62                0x003E /*63分频*/
#define FN_63                0x003F /*64分频 */
#define FSSEL_0            0x0000 /* Flash时钟选择: ACLK */
#define FSSEL_1            0x0040 /* Flash时钟选择: MCLK */
#define FSSEL_2            0x0080 /* Flash时钟选择: SMCLK */
#define FSSEL_3            0x00C0 /* Flash时钟选择: SMCLK */
#define BUSY                0x0001 /* Flash忙标志*/
#define KEYV                0x0002 /* Flash安全键值出错标志 */
#define ACCVIFG            0x0004 /* Flash非法访问中断标志*/
#define WAIT                0x0008 /* 等待指示信号位*/
#define LOCK                0x0010 /* 锁定位 */
#define EMEX                0x0020 /* 紧急退出位 */
* Comparator A            比较器A寄存器定义
#define CACTL1_            0x0059 /* 比较器A控制寄存器1 */
sfrb    CACTL1            = CACTL1_;
#define CACTL2_            0x005A /* 比较器A控制寄存器2 */
sfrb    CACTL2            = CACTL2_;
#define CAPD_              0x005B /*比较器A端口禁止寄存器*/
sfrb    CAPD              = CAPD_;
/* 比较器A控制寄存器1 */
#define CAIFG              0x01    /*比较器A中断标志*/
#define CAIE                0x02    /* 比较器A中断使能 */
#define CAIES              0x04    /* 比较器A中断边沿触发选择 0:上升延 1:下降延 */
#define CAON                0x08    /* 比较器电源开关*/
#define CAREF0              0x10    /* 选择参考源位0 */
#define CAREF1              0x20    /* 选择参考源位1 */
#define CARSEL              0x40    /* 选择内部参考源加到比较器的正端或负端 */
#define CAEX                0x80    /* 交换比较器的输入端 */
#define CAREF_0            0x00    /* 选择参考源0 : Off 使用外部参考源*/
#define CAREF_1            0x10    /* 选择参考源1 : 0.25*Vcc为参考源 */
#define CAREF_2            0x20    /* 选择参考源2 : 0.5*Vcc为参考源 */
#define CAREF_3            0x30    /* 选择参考源3 : Vt*/
/* 比较器A控制寄存器2 */
#define CAOUT              0x01    /* 比较器输出 */
#define CAF                0x02    /* 选择比较器是否经过RC低通滤波器 */
#define P2CA0              0x04    /* 外部引脚信号连接到比较器A的CA0 */
#define P2CA1              0x08    /* 外部引脚信号连接到比较器A的CA1 */
#define CACTL24            0x10
#define CACTL25            0x20
#define CACTL26            0x40
#define CACTL27            0x80
#define CAPD0              0x01    /* Comp. A Disable Input Buffer of Port Register .0 */
#define CAPD1              0x02    /* Comp. A Disable Input Buffer of Port Register .1 */
#define CAPD2              0x04    /* Comp. A Disable Input Buffer of Port Register .2 */
#define CAPD3              0x08    /* Comp. A Disable Input Buffer of Port Register .3 */
#define CAPD4              0x10    /* Comp. A Disable Input Buffer of Port Register .4 */
#define CAPD5              0x20    /* Comp. A Disable Input Buffer of Port Register .5 */
#define CAPD6              0x40    /* Comp. A Disable Input Buffer of Port Register .6 */
#define CAPD7              0x80    /* Comp. A Disable Input Buffer of Port Register .7 */
//4
* ADC12 A/D采样寄存器定义
/*ADC12转换控制类寄存器*/
#define ADC12CTL0_          0x0;' /* ADC12 Control 0 */
sfrw    ADC12CTL0        = ADC12CTL0_;
#define ADC12CTL1_          0x01A2 /* ADC12 Control 1 */
sfrw    ADC12CTL1        = ADC12CTL1_;
/*ADC12中断控制类寄存器*/
#define ADC12IFG_          0x01A4 /* ADC12 Interrupt Flag */
sfrw    ADC12IFG          = ADC12IFG_;
#define ADC12IE_            0x01A6 /* ADC12 Interrupt Enable */
sfrw    ADC12IE          = ADC12IE_;
#define ADC12IV_            0x01A8 /* ADC12 Interrupt Vector Word */
sfrw    ADC12IV          = ADC12IV_;
/*ADC12存贮器类寄存器*/
#define ADC12MEM_          0x0140 /* ADC12 Conversion Memory */
#define ADC12MEM            ADC12MEM_ /* ADC12 Conversion Memory (for assembler) */
#else
#define ADC12MEM            ((int*) ADC12MEM_) /* ADC12 Conversion Memory (for C) */
#endif
#define ADC12MEM0_          ADC12MEM_ /* ADC12 Conversion Memory 0 */
sfrw    ADC12MEM0        = ADC12MEM0_;
#define ADC12MEM1_          0x0142 /* ADC12 Conversion Memory 1 */
sfrw    ADC12MEM1        = ADC12MEM1_;
#define ADC12MEM2_          0x0144 /* ADC12 Conversion Memory 2 */
sfrw    ADC12MEM2        = ADC12MEM2_;
#define ADC12MEM3_          0x0146 /* ADC12 Conversion Memory 3 */
sfrw    ADC12MEM3        = ADC12MEM3_;
#define ADC12MEM4_          0x0148 /* ADC12 Conversion Memory 4 */
sfrw    ADC12MEM4        = ADC12MEM4_;
#define ADC12MEM5_          0x014A /* ADC12 Conversion Memory 5 */
sfrw    ADC12MEM5        = ADC12MEM5_;
#define ADC12MEM6_          0x014C /* ADC12 Conversion Memory 6 */
sfrw    ADC12MEM6        = ADC12MEM6_;
#define ADC12MEM7_          0x014E /* ADC12 Conversion Memory 7 */
sfrw    ADC12MEM7        = ADC12MEM7_;
#define ADC12MEM8_          0x0150 /* ADC12 Conversion Memory 8 */
sfrw    ADC12MEM8        = ADC12MEM8_;
#define ADC12MEM9_          0x0152 /* ADC12 Conversion Memory 9 */
sfrw    ADC12MEM9        = ADC12MEM9_;
#define ADC12MEM10_        0x0154 /* ADC12 Conversion Memory 10 */
sfrw    ADC12MEM10        = ADC12MEM10_;
#define ADC12MEM11_        0x0156 /* ADC12 Conversion Memory 11 */
sfrw    ADC12MEM11        = ADC12MEM11_;
#define ADC12MEM12_        0x0158 /* ADC12 Conversion Memory 12 */
sfrw    ADC12MEM12        = ADC12MEM12_;
#define ADC12MEM13_        0x015A /* ADC12 Conversion Memory 13 */
sfrw    ADC12MEM13        = ADC12MEM13_;
#define ADC12MEM14_        0x015C /* ADC12 Conversion Memory 14 */
sfrw    ADC12MEM14        = ADC12MEM14_;
#define ADC12MEM15_        0x015E /* ADC12 Conversion Memory 15 */
sfrw    ADC12MEM15        = ADC12MEM15_;
/*ADC12存贮控制类寄存器*/
#define ADC12MCTL_          0x0080 /* ADC12 Memory Control */
#define ADC12MCTL          ADC12MCTL_ /* ADC12 Memory Control (for assembler) */
#else
#define ADC12MCTL          ((char*) ADC12MCTL_) /* ADC12 Memory Control (for C) */
#endif
#define ADC12MCTL0_        ADC12MCTL_ /* ADC12 Memory Control 0 */
sfrb    ADC12MCTL0        = ADC12MCTL0_;
#define ADC12MCTL1_        0x0081 /* ADC12 Memory Control 1 */
sfrb    ADC12MCTL1        = ADC12MCTL1_;
#define ADC12MCTL2_        0x0082 /* ADC12 Memory Control 2 */
sfrb    ADC12MCTL2        = ADC12MCTL2_;
#define ADC12MCTL3_        0x0083 /* ADC12 Memory Control 3 */
sfrb    ADC12MCTL3        = ADC12MCTL3_;
#define ADC12MCTL4_        0x0084 /* ADC12 Memory Control 4 */
sfrb    ADC12MCTL4        = ADC12MCTL4_;
#define ADC12MCTL5_        0x0085 /* ADC12 Memory Control 5 */
sfrb    ADC12MCTL5        = ADC12MCTL5_;
#define ADC12MCTL6_        0x0086 /* ADC12 Memory Control 6 */
sfrb    ADC12MCTL6        = ADC12MCTL6_;
#define ADC12MCTL7_        0x0087 /* ADC12 Memory Control 7 */
sfrb    ADC12MCTL7        = ADC12MCTL7_;
#define ADC12MCTL8_        0x0088 /* ADC12 Memory Control 8 */
sfrb    ADC12MCTL8        = ADC12MCTL8_;
#define ADC12MCTL9_        0x0089 /* ADC12 Memory Control 9 */
sfrb    ADC12MCTL9        = ADC12MCTL9_;
#define ADC12MCTL10_        0x008A /* ADC12 Memory Control 10 */
sfrb    ADC12MCTL10      = ADC12MCTL10_;
#define ADC12MCTL11_        0x008B /* ADC12 Memory Control 11 */
sfrb    ADC12MCTL11      = ADC12MCTL11_;
#define ADC12MCTL12_        0x008C /* ADC12 Memory Control 12 */
sfrb    ADC12MCTL12      = ADC12MCTL12_;
#define ADC12MCTL13_        0x008D /* ADC12 Memory Control 13 */
sfrb    ADC12MCTL13      = ADC12MCTL13_;
#define ADC12MCTL14_        0x008E /* ADC12 Memory Control 14 */
sfrb    ADC12MCTL14      = ADC12MCTL14_;
#define ADC12MCTL15_        0x008F /* ADC12 Memory Control 15 */
sfrb    ADC12MCTL15      = ADC12MCTL15_;
/* ADC12CTL0 内16位控制寄存器位*/
#define ADC12SC            0x001        /*采样/转换控制位*/
#define ENC                0x002        /* 转换允许位*/
#define ADC12TOVIE          0x004        /*转换时间溢出中断允许位*/
#define ADC12OVIE          0x008        /*溢出中断允许位*/
#define ADC12ON            0x010        /*ADC12内核控制位*/
#define REFON              0x020        /*参考电压控制位*/
#define REF2_5V            0x040        /*内部参考电压的电压值选择位 '0'为1.5V; '1'为2.5V*/
#define MSH                0x080        /*多次采样/转换位*/
#define MSC                0x080        /*多次采样/转换位*/
/*SHT0 采样保持定时器0 控制ADC12的结果存贮器MEM0~MEM7的采样周期*/
#define SHT0_0              0*0x100      /*采样周期=TADC12CLK*4 */
#define SHT0_1              1*0x100      /*采样周期=TADC12CLK*8 */
#define SHT0_2              2*0x100      /*采样周期=TADC12CLK*16 */
#define SHT0_3              3*0x100      /*采样周期=TADC12CLK*32 */
#define SHT0_4              4*0x100      /*采样周期=TADC12CLK*64 */
#define SHT0_5              5*0x100      /*采样周期=TADC12CLK*96 */
#define SHT0_6              6*0x100      /*采样周期=TADC12CLK*128 */
#define SHT0_7              7*0x100      /*采样周期=TADC12CLK*192 */
#define SHT0_8              8*0x100      /*采样周期=TADC12CLK*256 */
#define SHT0_9              9*0x100      /*采样周期=TADC12CLK*384 */
#define SHT0_10            10*0x100      /*采样周期=TADC12CLK*512 */
#define SHT0_11            11*0x100      /*采样周期=TADC12CLK*768 */
#define SHT0_12            12*0x100      /*采样周期=TADC12CLK*1024 */
#define SHT0_13            13*0x100      /*采样周期=TADC12CLK*1024 */
#define SHT0_14            14*0x100      /*采样周期=TADC12CLK*1024 */
#define SHT0_15            15*0x100      /*采样周期=TADC12CLK*1024 */
/*SHT1 采样保持定时器1 控制ADC12的结果存贮器MEM8~MEM15的采样周期*/
#define SHT1_0              0*0x100      /*采样周期=TADC12CLK*4 */
#define SHT1_1              1*0x100      /*采样周期=TADC12CLK*8 */
#define SHT1_2              2*0x100      /*采样周期=TADC12CLK*16 */
#define SHT1_3              3*0x100      /*采样周期=TADC12CLK*32 */
#define SHT1_4              4*0x100      /*采样周期=TADC12CLK*64 */
#define SHT1_5              5*0x100      /*采样周期=TADC12CLK*96 */
#define SHT1_6              6*0x100      /*采样周期=TADC12CLK*128 */
#define SHT1_7              7*0x100      /*采样周期=TADC12CLK*192 */
#define SHT1_8              8*0x100      /*采样周期=TADC12CLK*256 */
#define SHT1_9              9*0x100      /*采样周期=TADC12CLK*384 */
#define SHT1_10            10*0x100      /*采样周期=TADC12CLK*512 */
#define SHT1_11            11*0x100      /*采样周期=TADC12CLK*768 */
#define SHT1_12            12*0x100      /*采样周期=TADC12CLK*1024 */
#define SHT1_13            13*0x100      /*采样周期=TADC12CLK*1024 */
#define SHT1_14            14*0x100      /*采样周期=TADC12CLK*1024 */
#define SHT1_15            15*0x100      /*采样周期=TADC12CLK*1024 */
/* ADC12CTL1 内16位控制寄存器位*/
#define ADC12BUSY          0x0001        /*ADC12忙标志位*/
#define CONSEQ_0            0*2          /*单通道单次转换*/
#define CONSEQ_1            1*2          /*序列通道单次转换*/
#define CONSEQ_2            2*2          /*单通道多次转换*/
#define CONSEQ_3            3*2          /*序列通道多次转换*/
#define ADC12SSEL_0          0*8          /*ADC12内部时钟源*/
#define ADC12SSEL_1          1*8          /*ACLK*/
#define ADC12SSEL_2          2*8          /*MCLK*/
#define ADC12SSEL_3          3*8          /*SCLK*/
#define ADC12DIV_0          0*0x20        /*1分频*/
#define ADC12DIV_1          1*0x20        /*2分频*/
#define ADC12DIV_2          2*0x20        /*3分频*/
#define ADC12DIV_3          3*0x20        /*4分频*/
#define ADC12DIV_4          4*0x20        /*5分频*/
#define ADC12DIV_5          5*0x20        /*6分频*/
#define ADC12DIV_6          6*0x20        /*7分频*/
#define ADC12DIV_7          7*0x20        /*8分频*/
#define ISSH                0x0100        /*采样输入信号反向与否控制位*/
#define SHP                  0x0200        /*采样信号(SAMPCON)选择控制位*/
#define SHS_0                0*0x400      /*采样信号输入源选择控制位 ADC12SC*/
#define SHS_1                1*0x400      /*采样信号输入源选择控制位 TIMER_A.OUT1*/
#define SHS_2                2*0x400      /*采样信号输入源选择控制位 TIMER_B.OUT0*/
#define SHS_3                3*0x400      /*采样信号输入源选择控制位 TIMER_B.OUT1*/
/*转换存贮器地址定义位*/
#define CSTARTADD_0          0*0x1000      /*选择MEM0首地址*/
#define CSTARTADD_1          1*0x1000      /*选择MEM1首地址*/
#define CSTARTADD_2          2*0x1000      /*选择MEM2首地址*/
#define CSTARTADD_3          3*0x1000      /*选择MEM3首地址*/
#define CSTARTADD_4          4*0x1000      /*选择MEM4首地址*/
#define CSTARTADD_5          5*0x1000      /*选择MEM5首地址*/
#define CSTARTADD_6          6*0x1000      /*选择MEM6首地址*/
#define CSTARTADD_7          7*0x1000      /*选择MEM7首地址*/
#define CSTARTADD_8          8*0x1000      /*选择MEM8首地址*/
#define CSTARTADD_9          9*0x1000      /*选择MEM9首地址*/
#define CSTARTADD_10        10*0x1000      /*选择MEM10首地址*/
#define CSTARTADD_11        11*0x1000      /*选择MEM11首地址*/
#define CSTARTADD_12        12*0x1000      /*选择MEM12首地址*/
#define CSTARTADD_13        13*0x1000      /*选择MEM13首地址*/
#define CSTARTADD_14        14*0x1000      /*选择MEM14首地址*/
#define CSTARTADD_15        15*0x1000      /*选择MEM15首地址*/
/* ADC12MCTLx */
#define INCH_0              0                /*选择模拟量通道0 A0 */
#define INCH_1              1                /*选择模拟量通道0 A1*/
#define INCH_2              2                /*选择模拟量通道0 A2*/
#define INCH_3              3                /*选择模拟量通道0 A3*/
#define INCH_4              4                /*选择模拟量通道0 A4*/
#define INCH_5              5                /*选择模拟量通道0 A5*/
#define INCH_6              6                /*选择模拟量通道0 A6*/
#define INCH_7              7                /*选择模拟量通道0 A7*/
#define INCH_8              8                /*VEREF+*/
#define INCH_9              9                /*VEREF-*/
#define INCH_10            10                /*片内温度传感器的输出*/
#define INCH_11            11                /*(AVCC-AVSS)/2*/
#define INCH_12            12                /*(AVCC-AVSS)/2*/
#define INCH_13            13                /*(AVCC-AVSS)/2*/
#define INCH_14            14                /*(AVCC-AVSS)/2*/
#define INCH_15            15                /*(AVCC-AVSS)/2*/
/*参考电压源选择位*/
#define SREF_0              0*0x10            /*VR+ = AVCC; VR- = AVSS*/
#define SREF_1              1*0x10            /*VR+ = VREF+; VR- = AVSS*/
#define SREF_2              2*0x10            /*VR+ = VEREF+; VR- = AVSS*/
#define SREF_3              3*0x10            /*VR+ = VEREF+; VR- = AVSS*/
#define SREF_4              4*0x10            /*VR+ = AVCC; VR- = VREF-*/
#define SREF_5              5*0x10            /*VR+ = VREF+; VR- = VREF-*/
#define SREF_6              6*0x10            /*VR+ = VEREF+; VR- = VREF-*/
#define SREF_7              7*0x10            /*VR+ = VEREF+; VR- = VREF-*/
#define EOS                0x80              /*序列结束选择位*/
* Interrupt Vectors (offset from 0xFFE0) 16个中断矢量定义
//#define BASICTIMER_VECTOR 0 * 2 /* 0xFFE0 Basic Timer MSP430F149 没有*/
#define PORT2_VECTOR        1 * 2 /* 0xFFE2 Port 2 */
#define UART1TX_VECTOR      2 * 2 /* 0xFFE4 UART 1 Transmit */
#define UART1RX_VECTOR      3 * 2 /* 0xFFE6 UART 1 Receive */
#define PORT1_VECTOR        4 * 2 /* 0xFFE8 Port 1 */
#define TIMERA1_VECTOR      5 * 2 /* 0xFFEA Timer A CC1-2, TA */
#define TIMERA0_VECTOR      6 * 2 /* 0xFFEC Timer A CC0 */
#define ADC_VECTOR          7 * 2 /* 0xFFEE ADC */
#define UART0TX_VECTOR      8 * 2 /* 0xFFF0 UART 0 Transmit */
#define UART0RX_VECTOR      9 * 2 /* 0xFFF2 UART 0 Receive */
#define WDT_VECTOR          10 * 2 /* 0xFFF4 Watchdog Timer */
#define COMPARATORA_VECTOR 11 * 2 /* 0xFFF6 Comparator A */
#define TIMERB1_VECTOR      12 * 2 /* 0xFFF8 Timer B 1-6 */
#define TIMERB0_VECTOR      13 * 2 /* 0xFFFA Timer B 0 */
#define NMI_VECTOR          14 * 2 /* 0xFFFC Non-maskable */
#define RESET_VECTOR        15 * 2 /* 0xFFFE Reset [Highest Priority] */
* End of Modules
大果仁儿 发表于 2016-3-7 14:18 | 显示全部楼层
xiaoyaozt 发表于 2016-3-11 22:18 | 显示全部楼层
头文件也需要修改吗
xiaoyaozt 发表于 2016-3-11 22:25 | 显示全部楼层
反正我拿过来是直接用的。
