世纪蓝景LM2902M NS品牌 特卖
1900|0
 楼主| jameswangchip 发表于 2009-10-24 09:23 | 显示全部楼层 |阅读模式
北京蓝景世纪科技开发有限责任公司(Beijing Bluechip Semiconductors Co.,Ltd.)于1999年注册成立,公司毗邻中关村广场,位于素有“中国硅谷”之称的中关村科技园区腹地,是一家专业致力于为无线通信技术应用提供基于整体解决方案和IC器件服务的**技术企业。
市场/应用
蓝景世纪专业面向无线通信技术应用,产品覆盖通讯、工控、网络、安全、电力、安防等领域,产品技术涉及:
l       无线、射频(RF)及WIFI通讯应用技术
l       涵盖商业及军工级应用的全系列光耦产品
l       面向CPLD/FPGA/DSP/MCU/ARM的开发板卡
l       基于网络安全应用平台的芯片及加速卡方案
l       微型打印机的开发与应用
LM2902M 品牌 NS
LM2902   品牌 TI
LM2902 状态: ACTIVE四路运算放大器
产品信息特性
  • 2-kV ESD Protection for:
    • LM224K, LM224KA
    • LM324K, LM324KA
    • LM2902K, LM2902KV, LM2902KAV
  • Wide Supply Ranges
    • Single Supply . . . 3 V to 32 V (26 V for LM2902)
    • Dual Supplies . . . ±1.5 V to ±16 V (±13 V for LM2902)
  • Low Supply-Current Drain Independent of Supply Voltage . . . 0.8 mA Typ
  • Common-Mode Input Voltage Range Includes Ground, Allowing Direct Sensing Near Ground
  • Low Input Bias and Offset Parameters
    • Input Offset Voltage . . . 3 mV Typ
      A Versions . . . 2 mV Typ
    • Input Offset Current . . . 2 nA Typ
    • Input Bias Current . . . 20 nA Typ
      A Versions . . . 15 nA Typ
  • Differential Input Voltage Range Equal to Maximum-Rated Supply Voltage . . . 32 V (26 V for LM2902)
  • Open-Loop Differential Voltage Amplification . . . 100 V/mV Typ
  • Internal Frequency Compensation
说明
These devices consist of four independent high-gain frequency-compensated operational amplifiers that are designed specifically to operate from a single supply over a wide range of voltages. Operation from split supplies also is possible if the difference between the two supplies is 3 V to 32 V (3 V to 26 V for the LM2902), and VCC is at least 1.5 V more positive than the input common-mode voltage. The low supply-current drain is independent of the magnitude of the supply voltage.
Applications include transducer amplifiers, dc amplification blocks, and all the conventional operational-amplifier circuits that now can be more easily implemented in single-supply-voltage systems. For example, the LM124 can be operated directly from the standard 5-V supply that is used in digital systems and provides the required interface electronics, without requiring additional ±15-V supplies.
地址:北京市海淀区知春路128号泛亚大厦1892B#
邮编:
100086
电话:010-51663026
51664726
传真:010-51664726
联系人:李先生
