世纪蓝景推TI 的REF3012产品!
1905|0
jameswangchip|  楼主 | 2009-10-24 10:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TI, vi, ip, TE, AI
REF3012 SOT23-3 封装的 1.25V 输出 50ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列
北京蓝景世纪科技开发有限责任公司(Beijing Bluechip Semiconductors Co.,Ltd.)于1999年注册成立,公司毗邻中关村广场,位于素有“中国硅谷”之称的中关村科技园区腹地,是一家专业致力于为无线通信技术应用提供基于整体解决方案和IC器件服务的**技术企业。
市场/应用
蓝景世纪专业面向无线通信技术应用,产品覆盖通讯、工控、网络、安全、电力、安防等领域,产品技术涉及:
l       无线、射频(RF)及WIFI通讯应用技术
l       涵盖商业及军工级应用的全系列光耦产品
l       面向CPLD/FPGA/DSP/MCU/ARM的开发板卡
l       基于网络安全应用平台的芯片及加速卡方案
l       微型打印机的开发与应用
REF3012 状态: ACTIVE
采用 SOT23-3 封装的 1.25V 输出 50ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列
Product Information
Features
Description
Quality & Lead (Pb)-Free Data
Product ContentDPPM / MTBF / FIT Rate
DeviceEco Plan*Lead / Ball FinishMSL Rating / Peak ReflowDetailsDetails
REF3012AIDBZR Green (RoHS & no Sb/Br)CU NIPDAULevel-1-260C-UNLIMViewView
REF3012AIDBZRG4 Green (RoHS & no Sb/Br)CU NIPDAULevel-1-260C-UNLIMViewView
REF3012AIDBZT Green (RoHS & no Sb/Br)CU NIPDAULevel-1-260C-UNLIMViewView
REF3012AIDBZTG4 Green (RoHS & no Sb/Br)CU NIPDAULevel-1-260C-UNLIMViewView
  • MicroSIZE PACKAGE: SOT23-3
  • LOW DROPOUT: 1mV
  • HIGH OUTPUT CURRENT: 25mA
  • HIGH ACCURACY: 0.2%
  • LOW IQ: 50µA max
  • EXCELLENT SPECIFIED DRIFT PERFORMANCE:
        50ppm/°C (max) from 0°C to +70°C
        75ppm/°C (max) from –40°C to +125°C
  • APPLICATIONS
    • PORTABLE, BATTERY-POWERED EQUIPMENT
    • DATA ACQUISITION SYSTEMS
    • MEDICAL EQUIPMENT
    • HAND-HELD TEST EQUIPMENT
All trademarks are the property of their respective owners.
The REF30xx is a precision, low power, low voltage dropout voltage reference family available in a tiny SOT23-3.
The REF30xx small size and low power consumption (50µA max) make it ideal for portable and battery-powered applications. The REF30xx does not require a load capacitor, but is stable with any capacitive load.
Unloaded, the REF30xx can be operated with supplies within 1mV of output voltage. All models are specified for the wide temperature range, –40°C to +125°C.
地址:北京市海淀区知春路128号泛亚大厦1892B#
邮编:
100086
电话:010-51663026
51664726
传真:010-51664726
联系人:李先生
