蓝景世纪主推编码译码器AK4644
1376|0
 楼主| jameswangchip 发表于 2009-10-24 12:56 | 显示全部楼层 |阅读模式
编码译码器(CODEC) > AK4644
低能耗2声道ADC和2声道DAC配有ALC/Eq及麦克风/耳机/RCV放大器
  • Recording Function
    · 3 Stereo Inputs Selector
    · Stereo Mic Input (Full-differential or Single-ended)
    · Stereo Line Input
    · MIC Amplifier (+32dB/+26dB/+20dB or 0dB)
    · Digital ALC (Automatic Level Control)
    (+36dB ~ -54dB, 0.375dB Step, Mute)
    · ADC Performance: S/(N+D): 83dB, DR, S/N: 86dB (MIC-Amp=+20dB)
    S/(N+D): 88dB, DR, S/N: 95dB (MIC-Amp=0dB)
    · Wind-noise Reduction Filter
    · Stereo Separation Emphasis
  • Playback Function
    · Digital De-emphasis Filter (tc=50/15ms, fs=32kHz, 44.1kHz, 48kHz)
    · Digital Volume (+12dB ~ -115.0dB, 0.5dB Step, Mute)
    · Programmble EQ
    · Stereo Line Output
    - Performance: S/(N+D): 88dB, S/N: 92dB
    · Mono Receiver-Amp
    - BTL Output
    - Output Power: 30mW@32WΩ (AVDD=3.3V)
    · Stereo Headphone-Amp
    - S/(N+D): 70dB@7.5mW, S/N: 90dB
    - Output Power: 70mW@16Ω (HVDD=5V), 62mW@16Ω (HVDD=3.3V)
    - Pop Noise Free at Power ON/OFF
    · Analog Mixing: 3 Stereo Inputs
  • Power Management
  • Master Clock:
    (1) PLL Mode
    · Frequencies:
    11.2896MHz, 12MHz, 12.288MHz, 13.5MHz, 24MHz, 27MHz (MCKI pin)
    1fs (LRCK pin)
    32fs or 64fs (BICK pin)
    (2) External Clock Mode
    · Frequencies: 256fs, 512fs or 1024fs (MCKI pin)
  • Output Master Clock Frequencies: 32fs/64fs/128fs/256fs
  • Sampling Rate:
    · PLL Slave Mode (LRCK pin): 7.35kHz ~ 48kHz
    · PLL Slave Mode (BICK pin): 7.35kHz ~ 48kHz
    · PLL Slave Mode (MCKI pin):
    8kHz, 11.025kHz, 12kHz, 16kHz, 22.05kHz, 24kHz, 32kHz, 44.1kHz, 48kHz
    · PLL Master Mode:
    · EXT Slave Mode:
    7.35kHz ~ 48kHz (256fs), 7.35kHz ~ 26kHz (512fs), 7.35kHz ~ 13kHz (1024fs)
  • μP I/F: 3-wire Serial, I2C Bus (Ver 1.0, 400kHz High Speed Mode)
  • Master/Slave mode
  • Audio Interface Format: MSB First, 2’s compliment
    · ADC: 16bit MSB justified, I2S, DSP Mode
    · DAC: 16bit MSB justified, 16bit LSB justified, 16-24bit I2S, DSP Mode
  • Ta = -30 ~ 85°C
  • Power Supply:
    · AVDD, DVDD: 2.6 ~ 3.6V (typ. 3.3V)
    · HVDD: 2.6 ~ 5.25V (typ. 3.3V/5.0V)
  • Package: 32pin QFN (5mm x 5mm, 0.5mm pitch)
  • Pin/Register Compatible with AK4642EN
  • Evaluation Board: AKD4644
AK4644 BLOCK DIAGRAM
地址:北京市海淀区知春路128号泛亚大厦1892B#
邮编:
100086
电话:010-51663026
51664726
传真:010-51664726
联系人:李先生
个人签名:新浪微博:阿牛哥在北京 http://www.weibo.com/brotherbull QQ:1047177125
2860
