[电源]
REF3012 静态电流的(带隙)电压参考系列
2912|2
jameswangchip|  楼主 | 2009-10-24 13:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
REF3012 状态: ACTIVE 采用 SOT23-3 封装的 1.25V 输出 50ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列
Product Information
Features
Description
Quality & Lead (Pb)-Free Data
Product ContentDPPM / MTBF / FIT Rate
DeviceEco Plan*Lead / Ball FinishMSL Rating / Peak ReflowDetailsDetails
REF3012AIDBZR Green (RoHS & no Sb/Br)CU NIPDAULevel-1-260C-UNLIMViewView
REF3012AIDBZRG4 Green (RoHS & no Sb/Br)CU NIPDAULevel-1-260C-UNLIMViewView
REF3012AIDBZT Green (RoHS & no Sb/Br)CU NIPDAULevel-1-260C-UNLIMViewView
REF3012AIDBZTG4 Green (RoHS & no Sb/Br)CU NIPDAULevel-1-260C-UNLIMViewView
  • MicroSIZE PACKAGE: SOT23-3
  • LOW DROPOUT: 1mV
  • HIGH OUTPUT CURRENT: 25mA
  • HIGH ACCURACY: 0.2%
  • LOW IQ: 50µA max
  • EXCELLENT SPECIFIED DRIFT PERFORMANCE:
        50ppm/°C (max) from 0°C to +70°C
        75ppm/°C (max) from –40°C to +125°C
  • APPLICATIONS
    • PORTABLE, BATTERY-POWERED EQUIPMENT
    • DATA ACQUISITION SYSTEMS
    • MEDICAL EQUIPMENT
    • HAND-HELD TEST EQUIPMENT
All trademarks are the property of their respective owners.
The REF30xx is a precision, low power, low voltage dropout voltage reference family available in a tiny SOT23-3.
The REF30xx small size and low power consumption (50µA max) make it ideal for portable and battery-powered applications. The REF30xx does not require a load capacitor, but is stable with any capacitive load.
Unloaded, the REF30xx can be operated with supplies within 1mV of output voltage. All models are specified for the wide temperature range, –40°C to +125°C.
thf2008| | 2009-10-26 20:10 | 只看该作者
LZ是做销售的吗?
linhai2009| | 2009-10-26 21:33 | 只看该作者
收藏了
个人签名:新浪微博:阿牛哥在北京 http://www.weibo.com/brotherbull QQ:1047177125
2833
