最新的MSP430普通IO模拟IIC程序!
4661|11
雁舞白沙|  楼主 | 2009-10-29 15:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <GLOBAL.h>
#include <stdlib.h>
#include <stdbool.h>
#include <msp430x41x.h>
#define IicWpDirOut           P6DIR |=  BIT5
#define IicWpLow              P6OUT &=~ BIT5
#define IicWpHig              P6OUT |=  BIT5
#define IicSclDirOut          P6DIR |=  BIT6
#define IicSclLow             P6OUT &=~ BIT6
#define IicSclHig             P6OUT |=  BIT6
#define IicSdaDirOut          P6OUT &= ~BIT7
#define IicSdaLow             P6DIR |=  BIT7
#define IicSdaHig             P6DIR &=~ BIT7
#define IicSdaInSt            P6IN  &   BIT7
bool AckErr;
//------------------------------ *** - 时间延时 - *** ------------------------------//
void Delay(unsigned int count)
   unsigned int i;
   _NOP();
   _NOP();
   for(i=count; i>0; i--);
void IIcDelay(void)
   _NOP();
//-----***-IIC初始化-***-----//
void IicInit(void)
IicWpDirOut;
IicSdaDirOut;
IicSclDirOut;
IicWpHig;
IicSdaHig;
IicSclHig;
//-----***-IIC启示-***-----//
void IicStart(void)
      IicSdaHig;//IicSda=1;
      IIcDelay();
      IicSclHig;//IicScl=1;
      IIcDelay();
      IicSdaLow;//IicSda=0;
      IIcDelay();
      IicSclLow;//IicScl=0;
      IIcDelay();
//-----***-IIC停止-***-----//
void IicStop(void)
      IIcDelay();
      IIcDelay();
      IIcDelay();
//-----***-IIC应答-***-----//
void SendAcknowledge(bool ack)
      IicSdaDirOut;
      if(ack)//IicSda=ack;
              IicSdaHig;
      else
              IicSdaLow;
      IIcDelay();
      IIcDelay();
      IIcDelay();
//-----***-从slave端读取一个数据-***-----//
unsigned char IicReceiveByte(void)
      unsigned char i;
      unsigned char bytedata=0;
      IicSdaDirOut;
      for(i=0;i<8;i++)
          IIcDelay();
          bytedata<<=1;
          if(IicSdaInSt)
                  bytedata |=0x01;
          else
                  bytedata &=0xfe;
          IIcDelay();
      IicSdaDirOut;
      return bytedata;
//-----***-传送一个 Byte 数据到 slave-***-----//
void IicSentByte(unsigned char DataByte)
    unsigned char i;
    for(i=0;i<8;i++)
        if(DataByte & 0x80)
     else
     DataByte <<=1;
     IIcDelay();
     IIcDelay();
     IIcDelay();
    IicSdaHig;//IicSda=1;-----Y------D---IicSdaDirIn
    IIcDelay();
    IIcDelay();
    IIcDelay();
//-----***-无扇区读---多字节-***-----//
//读取指定器件无扇区指定地址多字节数据到指定地址
//Device=器件地址---单字节
//DataAdd=字节地址---单字节
void IicMuchByteRead(unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
    unsigned char i;
    _DINT();
    WDT();
    IicInit();
    IicStart();
    IicSentByte(0xa0);
    IicSentByte(DataAdd);
    IicStart();
    IicSentByte(0xa1);
    for(i=DataLend-1;i>0;i--)
          *DataDptr=IicReceiveByte();
          DataDptr++;
       SendAcknowledge(0);
    SendAcknowledge(1);
    IicStop();
    WDT();
    Delay(500);
    _EINT();
//-----***-无扇区写---多字节-***-----//
//写入指定器件无扇区指定地址中的多字节数据
//Device=器件地址---单字节
//DataAdd=字节地址---双字节
//DataByte=被存放数据的地址
//DataLend=被存放数据的长度
void IicMuchByteWrite(unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
    unsigned char i;
    _DINT();
    WDT();
    IicInit();
    IicWpLow;
    IicStart();
    IicSentByte(0xa0);
    for(i=DataLend;i>0;i--)
        IicSentByte(*DataDptr);
        DataDptr++;
    IicStop();
    WDT();
    Delay(3500);
    IicWpHig;
    _EINT();
//---特别说明
//---利用430芯片来模拟IIC,是不能够把SDA设置为输出模式而是
//---设置为输入,然后利用方向控制器来输出高或者低
//---如下:
ayl439| | 2009-10-30 19:20 | 只看该作者
白沙兄也用430 ! 有机会交流交流!
511| | 2009-11-3 19:32 | 只看该作者
关注,,
雁舞白沙|  楼主 | 2009-11-4 03:17 | 只看该作者
多谢关注,现在就像把一些细节通过自己的失误,防止别人重复出现而已!
430我用的不是很熟!
与时俱进| | 2009-11-7 13:50 | 只看该作者
新在哪里?
center| | 2010-1-14 15:25 | 只看该作者
请问,为何?
center| | 2010-1-14 15:26 | 只看该作者
是功耗的考虑吗?
paulsimons| | 2010-5-7 11:28 | 只看该作者
请问这个程序是在430多少频率的环境下的,谢谢
ayb_ice| | 2010-5-7 11:50 | 只看该作者
//---特别说明
//---如下:
这个不可能吧,430和其它的MCU不同吗(IO有输入输出区别的MCU),其它的MCU模拟IIC SDA都可以输出,而且我认为应该输出,只是切换方向前一般要预写输出寄存器...
设置输入然后控制上下拉电阻本质和输出没有什么不同...
upc_arm| | 2012-7-26 20:24 | 只看该作者
请问这个程序是在430多少频率的环境下的?
还是就是那个  WDT(); 函数是做什么用的啊?
ayb_ice| | 2012-7-27 09:17 | 只看该作者
这个结论不对吧,只是对于这种结构需要仔细点就是了
先设输出结果,再设输出状态就可以了
chokystone| | 2012-8-21 00:23 | 只看该作者
嘿嘿  原来是这样啊!我说我怎么收到的都是0xff,看来以后要多逛逛
个人签名:学者会友QQ群:72137827 三人行,必有我师!
213
