哪位GGJJ有标准的5*7的英文点阵字库?
7948|7
 楼主| super057 发表于 2009-11-2 11:11 | 显示全部楼层 |阅读模式
项目需要用到5*7的英文点阵字库,在网上百度、谷歌都没找到。
请有用过这个字库的GGJJ们帮帮忙,谢谢!
highend 发表于 2009-11-2 12:59 | 显示全部楼层
找个1602液晶规格书,看一下就好了。
我是土匪 发表于 2009-11-2 23:22 | 显示全部楼层
找个批量生成的字库软件转一下
wangkj 发表于 2009-11-5 16:26 | 显示全部楼层
/*! \file font5x7.h \brief Graphic LCD Font (Ascii Characters). */
// File Name        : 'font5x7.h'
// Title                : Graphic LCD Font (Ascii Charaters)
// Author                : Pascal Stang
// Date                        : 10/19/2001
// Revised                : 10/19/2001
// Version                : 0.1
// Target MCU        : Atmel AVR
// Editor Tabs        : 4
// standard ascii 5x7 font
// defines ascii characters 0x20-0x7f (32-127)
//static unsigned char __attribute__ ((progmem))
const unsigned char code Fonts[][5] = {
        0x00, 0x00, 0x00, 0x00, 0x00,// ' '
        0x00, 0x00, 0x5F, 0x00, 0x00,// !
        0x00, 0x07, 0x00, 0x07, 0x00,// "
        0x14, 0x7F, 0x14, 0x7F, 0x14,// #
    0x24, 0x2A, 0x07, 0x2A, 0x12,// $
    0x23, 0x13, 0x08, 0x64, 0x62,// %
        0x37, 0x49, 0x55, 0x22, 0x50,// &
        0x00, 0x05, 0x03, 0x00, 0x00,// '
        0x00, 0x1C, 0x22, 0x41, 0x00,// (
        0x00, 0x41, 0x22, 0x1C, 0x00,// )
        0x08, 0x2A, 0x1C, 0x2A, 0x08,// *
        0x08, 0x08, 0x3E, 0x08, 0x08,// +
        0x00, 0x50, 0x30, 0x00, 0x00,// ,
        0x08, 0x08, 0x08, 0x08, 0x08,// -
        0x00, 0x60, 0x60, 0x00, 0x00,// .
        0x20, 0x10, 0x08, 0x04, 0x02,// /
        0x3E, 0x51, 0x49, 0x45, 0x3E,// 0
        0x00, 0x42, 0x7F, 0x40, 0x00,// 1
        0x42, 0x61, 0x51, 0x49, 0x46,// 2
        0x21, 0x41, 0x45, 0x4B, 0x31,// 3
        0x18, 0x14, 0x12, 0x7F, 0x10,// 4
        0x27, 0x45, 0x45, 0x45, 0x39,// 5
        0x3C, 0x4A, 0x49, 0x49, 0x30,// 6
        0x01, 0x71, 0x09, 0x05, 0x03,// 7
        0x36, 0x49, 0x49, 0x49, 0x36,// 8
        0x06, 0x49, 0x49, 0x29, 0x1E,// 9
        0x00, 0x36, 0x36, 0x00, 0x00,// :
        0x00, 0x56, 0x36, 0x00, 0x00,// ;
        0x00, 0x08, 0x14, 0x22, 0x41,// <
        0x14, 0x14, 0x14, 0x14, 0x14,// =
        0x41, 0x22, 0x14, 0x08, 0x00,// >
        0x02, 0x01, 0x51, 0x09, 0x06,// ?
        0x32, 0x49, 0x79, 0x41, 0x3E,// @
        0x7E, 0x11, 0x11, 0x11, 0x7E,// A
        0x7F, 0x49, 0x49, 0x49, 0x36,// B
        0x3E, 0x41, 0x41, 0x41, 0x22,// C
        0x7F, 0x41, 0x41, 0x22, 0x1C,// D
        0x7F, 0x49, 0x49, 0x49, 0x41,// E
        0x7F, 0x09, 0x09, 0x01, 0x01,// F
        0x3E, 0x41, 0x41, 0x51, 0x32,// G
        0x7F, 0x08, 0x08, 0x08, 0x7F,// H
        0x00, 0x41, 0x7F, 0x41, 0x00,// I
        0x20, 0x40, 0x41, 0x3F, 0x01,// J
        0x7F, 0x08, 0x14, 0x22, 0x41,// K
        0x7F, 0x40, 0x40, 0x40, 0x40,// L
        0x7F, 0x02, 0x04, 0x02, 0x7F,// M
        0x7F, 0x04, 0x08, 0x10, 0x7F,// N
        0x3E, 0x41, 0x41, 0x41, 0x3E,// O
        0x7F, 0x09, 0x09, 0x09, 0x06,// P
        0x3E, 0x41, 0x51, 0x21, 0x5E,// Q
        0x7F, 0x09, 0x19, 0x29, 0x46,// R
        0x46, 0x49, 0x49, 0x49, 0x31,// S
        0x01, 0x01, 0x7F, 0x01, 0x01,// T
        0x3F, 0x40, 0x40, 0x40, 0x3F,// U
        0x1F, 0x20, 0x40, 0x20, 0x1F,// V
        0x7F, 0x20, 0x18, 0x20, 0x7F,// W
        0x63, 0x14, 0x08, 0x14, 0x63,// X
        0x03, 0x04, 0x78, 0x04, 0x03,// Y
        0x61, 0x51, 0x49, 0x45, 0x43,// Z
        0x00, 0x00, 0x7F, 0x41, 0x41,// [
        0x02, 0x04, 0x08, 0x10, 0x20,// "\"
        0x41, 0x41, 0x7F, 0x00, 0x00,// ]
        0x04, 0x02, 0x01, 0x02, 0x04,// ^
        0x40, 0x40, 0x40, 0x40, 0x40,// _
        0x00, 0x01, 0x02, 0x04, 0x00,// `
        0x20, 0x54, 0x54, 0x54, 0x78,// a
        0x7F, 0x48, 0x44, 0x44, 0x38,// b
        0x38, 0x44, 0x44, 0x44, 0x20,// c
        0x38, 0x44, 0x44, 0x48, 0x7F,// d
        0x38, 0x54, 0x54, 0x54, 0x18,// e
        0x08, 0x7E, 0x09, 0x01, 0x02,// f
        0x08, 0x14, 0x54, 0x54, 0x3C,// g
        0x7F, 0x08, 0x04, 0x04, 0x78,// h
        0x00, 0x44, 0x7D, 0x40, 0x00,// i
        0x20, 0x40, 0x44, 0x3D, 0x00,// j
        0x00, 0x7F, 0x10, 0x28, 0x44,// k
        0x00, 0x41, 0x7F, 0x40, 0x00,// l
        0x7C, 0x04, 0x18, 0x04, 0x78,// m
        0x7C, 0x08, 0x04, 0x04, 0x78,// n
        0x38, 0x44, 0x44, 0x44, 0x38,// o
        0x7C, 0x14, 0x14, 0x14, 0x08,// p
        0x08, 0x14, 0x14, 0x18, 0x7C,// q
        0x7C, 0x08, 0x04, 0x04, 0x08,// r
        0x48, 0x54, 0x54, 0x54, 0x20,// s
        0x04, 0x3F, 0x44, 0x40, 0x20,// t
        0x3C, 0x40, 0x40, 0x20, 0x7C,// u
        0x1C, 0x20, 0x40, 0x20, 0x1C,// v
        0x3C, 0x40, 0x30, 0x40, 0x3C,// w
        0x44, 0x28, 0x10, 0x28, 0x44,// x
        0x0C, 0x50, 0x50, 0x50, 0x3C,// y
        0x44, 0x64, 0x54, 0x4C, 0x44,// z
        0x00, 0x08, 0x36, 0x41, 0x00,// {
        0x00, 0x00, 0x7F, 0x00, 0x00,// |
        0x00, 0x41, 0x36, 0x08, 0x00,// }
        0x02, 0x01, 0x02, 0x04, 0x02,// ~
        0xff, 0xff, 0xff, 0xff, 0xff //black block//
纵向排列的。
 楼主| super057 发表于 2009-12-2 18:16 | 显示全部楼层
谢谢wangkj!
it_yrj 发表于 2015-12-3 22:27 | 显示全部楼层
老大这个怎么生成的,我需要横向生成5*7的字库
Wang11121 发表于 2015-12-7 18:56 | 显示全部楼层
0x00,0x04,0x0C,0x04,0x04,0x04,0x0E,0x00,//’1’   0
0x0E,0x11,0x01,0x02,0x04,0x08,0x1F,0x00,//’2’   1
0x1F,0x02,0x04,0x02,0x01,0x11,0x0E,0x00,//’3’   2
0x02,0x06,0x0A,0x12,0x1F,0x02,0x02,0x00,//’4’   3
0x1F,0x10,0x1E,0x01,0x01,0x11,0x0E,0x00,//’5’   4
0x06,0x08,0x10,0x1E,0x11,0x11,0x0E,0x00,//’6’   5
0x1F,0x01,0x02,0x04,0x08,0x08,0x08,0x00,//’7’   6
0x0E,0x11,0x11,0x0E,0x11,0x11,0x0E,0x00,//’8’   7
0x0E,0x11,0x11,0x0F,0x01,0x02,0x0C,0x00,//’9’   8
0x0E,0x11,0x13,0x15,0x19,0x11,0x0E,0x00,//’0’   9
0x0E,0x11,0x11,0x11,0x1F,0x11,0x11,0x00,//’A’   10
0x1E,0x11,0x11,0x1E,0x11,0x11,0x1E,0x00,//’B’  11
0x0E,0x11,0x10,0x10,0x10,0x11,0x0E,0x00,//’C’  12
0x1C,0x12,0x11,0x11,0x11,0x12,0x1C,0x00,//’D’  13
0x1F,0x10,0x10,0x1E,0x10,0x10,0x1F,0x00,//’E’   14
0x1F,0x10,0x10,0x1E,0x10,0x10,0x10,0x00,//’F’   15
0x0E,0x11,0x10,0x17,0x11,0x11,0x0F,0x00,//’G’   16
0x11,0x11,0x11,0x1F,0x11,0x11,0x11,0x00,//’H’   17
0x0E,0x04,0x04,0x04,0x04,0x04,0x0E,0x00,//’I’   18
0x07,0x02,0x02,0x02,0x02,0x12,0x0C,0x00,//’J’   19
0x11,0x12,0x14,0x18,0x14,0x12,0x11,0x00,//’K’   20
0x10,0x10,0x10,0x10,0x10,0x10,0x1F,0x00,//’L’   21
0x11,0x1B,0x15,0x15,0x11,0x11,0x11,0x00,//’M’   22
0x11,0x11,0x19,0x15,0x13,0x11,0x11,0x00,//’N’   23
0x0E,0x11,0x11,0x11,0x11,0x11,0x0E,0x00,//’O’   24
0x1E,0x11,0x11,0x1E,0x10,0x10,0x10,0x00,//’P’   25
0x0E,0x11,0x11,0x11,0x15,0x12,0x0D,0x00,//’Q’   26
0x1E,0x11,0x11,0x1E,0x14,0x12,0x11,0x00,//’R’   27
0x0F,0x10,0x10,0x0E,0x01,0x01,0x1E,0x00,//’S’   28
0x1F,0x04,0x04,0x04,0x04,0x04,0x04,0x00,//’T’    29
0x11,0x11,0x11,0x11,0x11,0x11,0x0E,0x00,//’U’    30
0x11,0x11,0x11,0x11,0x11,0x0A,0x04,0x00,//’V’    31
0x11,0x11,0x11,0x15,0x15,0x15,0x0E,0x00,//’W’    32
0x11,0x11,0x0A,0x04,0x0A,0x11,0x11,0x00,//’X’    33
0x11,0x11,0x11,0x0A,0x04,0x04,0x04,0x00,//’Y’    34
0x1F,0x01,0x02,0x04,0x08,0x10,0x1F,0x00,//’Z’    35
0x00,0x00,0x0E,0x01,0x0F,0x11,0x0F,0x00,//’a’    36
0x10,0x10,0x16,0x19,0x11,0x11,0x1E,0x00,//’b’    37
0x00,0x00,0x0E,0x10,0x10,0x11,0x0E,0x00,//’c’    38
0x01,0x01,0x0D,0x13,0x11,0x11,0x0F,0x00,//’d’    39
0x00,0x00,0x0E,0x11,0x1F,0x10,0x0E,0x00,//’e’    40
0x00,0x06,0x09,0x08,0x1C,0x08,0x08,0x00,//’f’    41
0x10,0x10,0x16,0x19,0x11,0x11,0x11,0x00,//’h’     42
0x04,0x00,0x0C,0x04,0x04,0x04,0x0E,0x00,//’i’     43
0x02,0x00,0x06,0x02,0x02,0x12,0x0C,0x00,//’j’     44
0x08,0x08,0x09,0x0A,0x0C,0x0A,0x09,0x00,//’k’    45
0x0C,0x04,0x04,0x04,0x04,0x04,0x0E,0x00,//’l’     46
0x00,0x00,0x1E,0x15,0x15,0x11,0x11,0x00,//’m’    47
0x00,0x00,0x16,0x19,0x11,0x11,0x11,0x00,//’n’     48
0x00,0x00,0x0E,0x11,0x11,0x11,0x0E,0x00,//’o’    49
0x00,0x00,0x1E,0x11,0x1E,0x10,0x10,0x00,//’p’    50
0x00,0x00,0x0D,0x13,0x0F,0x01,0x01,0x00,//’q ’    51
0x00,0x00,0x16,0x19,0x10,0x10,0x10,0x00,//’r’     52
0x00,0x00,0x0E,0x10,0x0E,0x01,0x0E,0x00,//’s’     53
0x00,0x08,0x08,0x1C,0x08,0x09,0x06,0x00,//’t ’     54
0x00,0x00,0x11,0x11,0x11,0x13,0x0D,0x00,//’u’     55
0x00,0x00,0x11,0x11,0x11,0x0A,0x04,0x00,//’v’     56
0x00,0x00,0x11,0x11,0x15,0x15,0x0A,0x00,//’w’     57
0x00,0x00,0x11,0x0A,0x04,0x0A,0x11,0x00,//’x’     58
0x00,0x00,0x11,0x11,0x0F,0x01,0x0E,0x00,//’y’      59
0x00,0x00,0x1F,0x02,0x04,0x08,0x1F,0x00,//’z’      60
