MSP430 按键程序范例(附原理图)
2407|16
 楼主| dirtwillfly 发表于 2016-3-7 22:22 | 显示全部楼层 |阅读模式
#i nclude <MSP430x14x.h>
void Init_Port(void)
    //将P1口所有的管脚在初始化的时候设置为输入方式
    P1DIR = 0;
    //将P1口所有的管脚设置为一般I/O口
    P1SEL = 0;
    // 将P1.4 P1.5 P1.6 P1.7设置为输出方向
    P1DIR |= BIT4;
    P1DIR |= BIT5;
P1DIR |= BIT6;
    P1DIR |= BIT7;
//先输出低电平
P1OUT = 0x00;
// 将中断寄存器清零
    P1IE = 0;
    P1IES = 0;
    P1IFG = 0;
    //打开管脚的中断功能
//对应的管脚由高到低电平跳变使相应的标志置位
    P1IE |= BIT0;
    P1IES |= BIT0;
    P1IE |= BIT1;
    P1IES |= BIT1;
P1IE |= BIT2;
    P1IES |= BIT2;
    P1IE |= BIT3;
    P1IES |= BIT3;
_EINT();//打开中断
    return;
void Delay(void)
int i;
for(i = 100;i--;i > 0) ;//延时一点时间
int KeyProcess(void)
    int nP10,nP11,nP12,nP13;
int nRes = 0;
//P1.4输出低电平
P1OUT &= ~(BIT4);
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes = 13;
nP11 = P1IN & BIT1;
if (nP11 == 0) nRes = 14;
nP12 = P1IN & BIT2;
if (nP12 == 0) nRes = 15;
nP13 = P1IN & BIT3;
if (nP13 == 0) nRes = 16;
//P1.5输出低电平
P1OUT &= ~(BIT4);
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes = 9;
nP11 = P1IN & BIT1;
if (nP11 == 0) nRes = 10;
nP12 = P1IN & BIT2;
if (nP12 == 0) nRes = 11;
nP13 = P1IN & BIT3;
if (nP13 == 0) nRes = 12;
//P1.6输出低电平
P1OUT &= ~(BIT4);
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes = 5;
nP11 = P1IN & BIT1;
if (nP11 == 0) nRes = 6;
nP12 = P1IN & BIT2;
if (nP12 == 0) nRes = 7;
nP13 = P1IN & BIT3;
if (nP13 == 0) nRes = 8;
//P1.7输出低电平
P1OUT &= ~(BIT4);
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes = 1;
nP11 = P1IN & BIT1;
if (nP11 == 0) nRes = 2;
nP12 = P1IN & BIT2;
if (nP12 == 0) nRes = 3;
nP13 = P1IN & BIT3;
if (nP13 == 0) nRes = 4;
P1OUT = 0x00;//恢复以前值。
//读取各个管脚的状态
nP10 = P1IN & BIT0;
nP11 = P1IN & BIT1;
nP12 = P1IN & BIT2;
nP13 = P1IN & BIT3;
for(;;)
  if(nP10 == 1 && nP11 == 1 && nP12 == 1 && nP13 == 1)
   //等待松开按键
   break;
return nRes;
// 处理来自端口 1 的中断
interrupt [PORT1_VECTOR] void PORT_ISR(void)
Delay();
KeyProcess();
    if(P1IFG & BIT0)
     P1IFG &= ~(BIT0);// 清除中断标志位
    if(P1IFG & BIT1)
     P1IFG &= ~(BIT1);// 清除中断标志位
    if(P1IFG & BIT2)
     P1IFG &= ~(BIT2);// 清除中断标志位
if(P1IFG & BIT3)
     P1IFG &= ~(BIT3);// 清除中断标志位
void Init_CLK(void)
    unsigned int i;
    BCSCTL1 = 0X00;   //将寄存器的内容清零
     //XT2震荡器开启
     //LFTX1工作在低频模式
     //ACLK的分频因子为1
    do
IFG1 &= ~OFIFG;                       // 清除OSCFault标志
for (i = 0x20; i > 0; i--);
    while ((IFG1 & OFIFG) == OFIFG);      // 如果OSCFault =1
    BCSCTL2 = 0X00;   //将寄存器的内容清零
    BCSCTL2 += SELM1;  //MCLK的时钟源为TX2CLK,分频因子为1
    BCSCTL2 += SELS;  //SMCLK的时钟源为TX2CLK,分频因子为1
 楼主| dirtwillfly 发表于 2016-3-7 22:23 | 显示全部楼层
i1mcu 发表于 2016-3-7 22:36 | 显示全部楼层
扫码按键可以设计的更简单
i1mcu 发表于 2016-3-7 22:37 | 显示全部楼层
这个版块有个设计键盘的,用二极管的,不浪费io口
数码小叶 发表于 2016-3-8 10:58 | 显示全部楼层
二极管???
lzbf 发表于 2016-3-10 22:34 | 显示全部楼层
好像见到过这个帖子
lzbf 发表于 2016-3-10 22:38 | 显示全部楼层
https://bbs.21ic.com/icview-793454-1-1.html?_dsign=fbf893c4
lzbf 发表于 2016-3-10 22:39 | 显示全部楼层
cehuafan 发表于 2016-3-11 22:17 | 显示全部楼层
这个是什么原理?
cehuafan 发表于 2016-3-11 22:25 | 显示全部楼层
感觉好省io资源呢
baimiaocun2015 发表于 2016-3-13 19:24 | 显示全部楼层
楼上分享的集中按键设计的都非常经典。
ywzqdpj 发表于 2016-3-13 21:27 | 显示全部楼层
顶,我的提问帖貌似经常看到你帮我问答问题,谢谢你,虽然没有解决
firstblood 发表于 2016-3-15 22:34 | 显示全部楼层
这个关键是你吧相关的管脚的IO口设置成输入并且尽可能的设置成中断的
smilingangel 发表于 2016-3-17 19:35 | 显示全部楼层
这个主要就是中断响应的,然后检测相应的IO管脚的电平状态的
comeon201208 发表于 2016-3-17 19:40 | 显示全部楼层
这个检测按键的状态时还需要设置一定的小延时的处理。
vibra2016 发表于 2016-3-17 22:51 | 显示全部楼层
采用矩阵式按键设计的会节省IO管脚的
Varus 发表于 2016-3-18 20:12 | 显示全部楼层
板主有没有430读写AT24C16的程序,想参考一下
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1203
