[i.MX] imx6dl Linux lcd无法显示
4293|18
 楼主| Wonderself 发表于 2016-3-15 09:41 | 显示全部楼层 |阅读模式
i.mx6 dual lite的板子,Linux平台,使用Yocto编译环境,fsl-yocto-3.14.28-1.0.0
现在屏幕始终无任何显示。屏是1920×720分辨率,使用双路Lvds
飞思卡尔技术支持能否帮忙看下,有做过的也请指导下,搞了好几天了还没搞定
 楼主| Wonderself 发表于 2016-3-15 09:42 | 显示全部楼层
这是uboot参数:
        "fb0base=0x27b00000 "             \
        "video=mxcfb0:dev=ldb,LDB-XGA,if=RGB8888,bpp=32 fbmem=32M\0"   \
kernel dtsi配置:
&ldb {
        status = "okay";
/*        dual-mode;*/
        split-mode;
        lvds-channel@0 {
                fsl,data-mapping = "spwg";
                fsl,data-width = <24>;
                primary;
                status = "okay";
                display-timings {
                        native-mode = <&timing0>;
                        timing0: hsd100pxn0 {
                                clock-frequency = <47500000>;
                                hactive = <960>;
                                vactive = <720>;
                                hback-porch = <50>;
                                hfront-porch = <10>;
                                vback-porch = <40>;
                                vfront-porch = <20>;
                                hsync-len = <1>;
                                vsync-len = <1>;
        lvds-channel@1 {
                status = "okay";
                display-timings {
                        native-mode = <&timing1>;
                        timing1: hsd100pxn1 {
                                hactive = <960>;
                                vactive = <720>;
                                hback-porch = <50>;
                                vback-porch = <40>;
                                hsync-len = <1>;
                                vsync-len = <1>;
 楼主| Wonderself 发表于 2016-3-15 10:12 | 显示全部楼层
@FSL_TICS_Rita 请帮我看下,谢谢了!
1920×720双路LVDS显示,在dtsi是配成两个960×720吗?
附件是屏的参数
1920×720屏幕参数
1920×720屏幕参数
mini1986 发表于 2016-3-15 10:19 | 显示全部楼层
关注一下......
 楼主| Wonderself 发表于 2016-3-15 11:06 | 显示全部楼层
附件是量到的RxOIN0-信号
RxOIN0-
RxOIN0-
free_tend 发表于 2016-3-17 09:30 | 显示全部楼层
是单屏用双路lvds还是双路输出到不通的屏上
free_tend 发表于 2016-3-17 09:39 | 显示全部楼层
如果使用split-mode就是双路输出到同一个屏上, 要翻倍的 要用1920x720的分辨率设置而不是960x720
 楼主| Wonderself 发表于 2016-3-19 14:28 | 显示全部楼层
如果使用split-mode就是双路输出到同一个屏上, 要翻倍的 要用1920x720的分辨率设置而不是960x720 ...
之前是屏接触有问题。
现在改成1920×720后,只显示企鹅,后面企鹅会慢慢变暗,没有yocto显示。我用另一块单路lvds的屏能正常显示。
这是1920×720屏的配置:
        lvds-channel@0 {
                primary;
                status = "okay";
                display-timings {
                        timing0: hsd100pxn1 {
                                clock-frequency = <95000000>;
                                hactive = <1920>;
                                vactive = <720>;
                                hback-porch = <40>;
                                hfront-porch = <40>;
                                vback-porch = <20>;
                                hsync-len = <1>;
                                vsync-len = <1>;
这是能正常显示的屏的配置:
        lvds-channel@0 {
                primary;
                status = "okay";
                  display-timings {
                                clock-frequency = <65500000>;
                                hactive = <1280>;
                                vactive = <720>;
                                hback-porch = <70>;
                                hfront-porch = <90>;
                                vback-porch = <30>;
                                vfront-porch = <7>;
                                hsync-len = <1>;
                                vsync-len = <1>;
是我哪里配错了吗?
对了,双路LVDS共用同一个clk,那边需要怎么改吗?
free_tend 发表于 2016-3-22 15:24 | 显示全部楼层
之前是屏接触有问题。
现在改成1920×720后,只显示企鹅,后面企鹅会慢慢变暗,没有yocto显示。我用另一 ...
实际上就是2080x760 就是行前行后 都要翻倍的 你尝试一下。
另外如果变黑 你可以去/sys/class/graphics/fbx里面去控制fb0里面的blank 能否将屏幕变暗变亮。
或者直接用图片dd 到/dev/fb0 屏幕是否有反映。
 楼主| Wonderself 发表于 2016-3-24 18:17 | 显示全部楼层
另外如果变黑 你可以去/sys/class/graphics/f ...
谢谢指点。
试过仍不能显示。
echo 0/1 > blank可以控制屏幕开关,但仍无图像显示。
@FSL_TICS_Rita 能否过来帮忙看下? 双路LVDS是否可以只接一个CLK?现在怀疑是clk的问题。
kris_fei 发表于 2016-3-25 08:45 | 显示全部楼层
飞思卡尔FAE已经不在这做技术支持了
小番茄 发表于 2016-3-28 12:09 | 显示全部楼层
附件是屏的参 ...
楼主是不是用的C123HAN01.1 这个屏啊  我看屏的参数和我的一样
我现在也出现这个问题了,怎么调试屏幕上都没有任何变化,一片黑的,没有任何显示, 背光开启时比关闭时亮一点点
不知道楼主这个问题解决了没?
free_tend 发表于 2016-3-28 15:34 | 显示全部楼层
谢谢指点。
试过仍不能显示。
具体硬件接法我倒是不太熟悉
 楼主| Wonderself 发表于 2016-3-29 14:28 | 显示全部楼层
我现在也出现这个问题了,怎么调试屏幕 ...
是的,跟飞思卡尔确认了,Lvds两路clk都要接上,否则无法显示。
小番茄 发表于 2016-4-5 16:39 | 显示全部楼层
我们的LCD是有一个背光板驱动板的,驱动板的原理图我没有,我看了我这边主板原理图,两路CLK都是接进去了,我看了下LCD只有一路CLK引脚吧,至于是不是主板的两路CLK都接在了LCD的CLK引脚上我就不知道了
我是这样的解决的
频率计算时,正常的是 10^12/47.5MHz
我改成了 10^12/(47.5MHz*2)
mini1986 发表于 2016-4-14 08:07 | 显示全部楼层
我调过2个lvds同显,没有问题......
myfish1235 发表于 2017-3-28 14:05 | 显示全部楼层
楼主,问题解了么?求指导
myfish1235 发表于 2017-3-28 14:22 | 显示全部楼层
我的设置:
        mxcfb1: fb@0 {
                compatible = "fsl,mxc_sdc_fb";
                disp_dev = "ldb";
                interface_pix_fmt = "RGB666";
                default_bpp = <16>;
                int_clk = <0>;
                late_init = <0>;
                status = "disabled";
lvds-channel@1 {
                fsl,data-width = <18>;
                primary;
                status = "okay";
                display-timings {
                                clock-frequency = <65000000>;
                                hactive = <1024>;
                                vactive = <600>;
                                hback-porch = <110>;
                                hfront-porch = <110>;
                                vback-porch = <17>;
                                vfront-porch = <17>;
                                hsync-len = <100>;
                                vsync-len = <4>;
&ldb {
        lvds-channel@0 {
                crtc = "ipu1-di0";
        lvds-channel@1 {
                crtc = "ipu1-di1";
出现的只有条纹,还需要什么其他配置么?
嵌入式渣渣 发表于 2017-9-21 13:59 | 显示全部楼层
解决了这个问题吗,我最近填双8LVDS屏幕也是没显示,只有背光起来了,怎么破?
