[STM32F1] 求教F103串口中断接收问题
1331|2
 楼主| lbb_1112 发表于 2016-3-18 10:18 | 显示全部楼层 |阅读模式
我写的中断接收数据,然后查询发送不能正常工作,求高手指点:
void NVIC_Configuration(void);
u8   i,rt;
u8 data1[3]={0,0,0};
int main()
        u8 i;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_USART1|RCC_APB2Periph_AFIO, ENABLE);
        USART1_init1();
        NVIC_Configuration();
        USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
        USART_ClearFlag(USART1,USART_FLAG_TC);
        USART_Cmd(USART1,ENABLE);
        while(1)
                if(rt==1)
                        for(i=0;i<3;i++)
                        USART_SendData(USART1, data1);
                        while(USART_GetFlagStatus(USART1, USART_FLAG_TC)!=SET);
                        rt=0;
                else
                __nop();
  NVIC_InitTypeDef NVIC_InitStructure;
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void USART1_IRQHandler(void)
//        USART_ClearITPendingBit(USART1, USART_IT_TC);
if(USART_GetITStatus(USART1,USART_IT_RXNE)==SET)
  {for(i=0;i<3;i++)
    USART_ClearITPendingBit(USART1,USART_IT_RXNE);
    data1=USART_ReceiveData(USART1);
                USART_ClearITPendingBit(USART1, USART_IT_RXNE);
                if(i==2)
                {i=0;
                        rt=1;
初始化串口程序:
void USART1_init1(void)
        GPIO_InitTypeDef                 GPIO_InitStructure;
        USART_InitTypeDef         USART_InitStructure;
        USART_DeInit(USART1);//¸´Î»´®¿Ú1;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;                                 //PA9ΪUSART1_TX£¬Ð´³ö
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //ÍÆÍ츴ÓÃÊä³ö£»
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        USART_InitStructure.USART_BaudRate = 9600;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None ;
        USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
        USART_Init(USART1, &USART_InitStructure);
xmshao 发表于 2016-3-18 12:20 | 显示全部楼层
ST官方库基本都是库里现存的工程,仔细检查下。
还有,下面代码没问题?
for(i=0;i<3;i++)
                         USART_SendData(USART1, data1);//????
 楼主| lbb_1112 发表于 2016-3-18 12:40 | 显示全部楼层
还有,下面代码没问题?
谢谢回答
发贴子的时候后面【I】没显示。
这个程序问题找到了,谢谢
