谁用过PWM-chopper ?
720|2
 楼主| jlyuan 发表于 2016-3-21 21:40 | 显示全部楼层 |阅读模式
谁用过PWM-chopper ?
jiaxw 发表于 2016-3-21 21:43 | 显示全部楼层
你有什么困惑?
 楼主| jlyuan 发表于 2016-3-21 21:46 | 显示全部楼层
**中讲到:
The PWM-chopper submodule allows a high-frequency carrier signal to modulate the PWM waveform
generated by the action-qualifier and dead-band submodules. This capability is important if you need
pulse transformer-based gate drivers to control the power switching elements.
