keil编译优化问题
3435|3
 楼主| Mick_liang 发表于 2009-11-14 13:12 | 显示全部楼层 |阅读模式
我在测试端写的电平状态时写了如下代码:
#define LO1_ADDR XBYTE[0x1FFF]
unsigned char bdata TranByte;
sbit SDIO = TranByte^0;
void mian()
SDIO = 0;
LO1_ADDR = TranByte;
SDIO = 1;
SDIO = 0;
SDIO = 1;
优化级别是默认的,但是后面的代码LO1_ADDR = TranByte;被优化了,导致写出的电平状态不对。
不知道该如何解决,去掉优化?
冷漠 发表于 2009-11-16 11:13 | 显示全部楼层
没优化呀?
    10: void mian()
    11: {
    12: SDIO = 0;
C:0x0000    C200     CLR      SDIO(0x20.0)
    13: LO1_ADDR = TranByte;
C:0x0002    901FFF   MOV      DPTR,#0x1FFF
C:0x0005    E520     MOV      A,TranByte(0x20)
C:0x0007    F0       MOVX     @DPTR,A
    14: SDIO = 1;
C:0x0008    D200     SETB     SDIO(0x20.0)
    15: LO1_ADDR = TranByte;
    16:
C:0x000A    E520     MOV      A,TranByte(0x20)
C:0x000C    F0       MOVX     @DPTR,A
    17: SDIO = 0;
C:0x000D    C200     CLR      SDIO(0x20.0)
    18: LO1_ADDR = TranByte;
C:0x000F    E520     MOV      A,TranByte(0x20)
C:0x0011    F0       MOVX     @DPTR,A
    19: SDIO = 1;
C:0x0012    D200     SETB     SDIO(0x20.0)
    20: LO1_ADDR = TranByte;
C:0x0014    E520     MOV      A,TranByte(0x20)
C:0x0016    F0       MOVX     @DPTR,A
    21: }
C:0x0017    22       RET
C:0x0018    00       NOP
C:0x0019    00       NOP
C:0x001A    00       NOP
C:0x001B    00       NOP
C:0x001C    00       NOP
C:0x001D    00       NOP
 楼主| Mick_liang 发表于 2010-1-8 12:40 | 显示全部楼层
在我的编译器里被优化了...
xlsbz 发表于 2010-1-8 13:39 | 显示全部楼层
不知道该如何解决,去掉优化?
什么叫 后面的代码LO1_ADDR = TranByte ????
