[i.MX] sd卡启动
1055|2
 楼主| kcy15 发表于 2016-3-24 14:25 | 显示全部楼层 |阅读模式
SD卡, TI, ni, se, AD
自己设计的板子,通过MFG烧写到SD card 中,然后拨码从SD卡启动一直失败提示*** Warning - bad CRC or MMC, using default environment
In:    serial
Out:   serial
Err:   serial
reading /recovery/update.zip
** [check_ota]read update.zip error, has no update.zip in sdcard **
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
mmc2 init failed
fastboot is in init......flash target is MMC:2
MMC card init failed!
Bad partition index:1 for partition:boot
Bad partition index:2 for partition:recovery
Bad partition index:5 for partition:system
USB Mini b cable Connected!
fastboot initialized
USB_SUSPEND
USB_RESET
USB_RESET
kris_fei 发表于 2016-3-24 15:33 | 显示全部楼层
这句提示不影响开机的。
mini1986 发表于 2016-4-14 09:00 | 显示全部楼层
你这打印信息看上去是进了adb模式吧,都没有从sd启动......
