这个例子用IIR求传输函数的补偿系数是怎么推导的?
2206|0
 楼主| snakeemail 发表于 2007-11-13 17:28 | 显示全部楼层 |阅读模式
Calculating&nbsp;the&nbsp;Compensator&nbsp;Coefficients<br />A&nbsp;convenient&nbsp;way&nbsp;of&nbsp;determining&nbsp;the&nbsp;coefficients&nbsp;for&nbsp;an<br />IIR&nbsp;(Infinite&nbsp;Impulse&nbsp;Response)&nbsp;compensator&nbsp;from&nbsp;an<br />analog&nbsp;transfer&nbsp;function&nbsp;in&nbsp;the&nbsp;Laplace&nbsp;(s)&nbsp;domain&nbsp;is&nbsp;the<br />Bilinear&nbsp;z-transform.&nbsp;The&nbsp;following&nbsp;example&nbsp;illustrates<br />the&nbsp;technique&nbsp;for&nbsp;a&nbsp;compensator&nbsp;with&nbsp;a&nbsp;single&nbsp;pole.<br />推荐自动控制的书也可以,我看了些自动控制的书,都没有讲全呀,例如上面讲到了穿越频率,还有s到z域的双线性变换.<br />这个是逆变器的例子
