F28335_PWM使用
685|1
 楼主| lefeng 发表于 2016-3-28 22:18 | 显示全部楼层 |阅读模式
// Configure ePWM1
// Setup TBCLK
   EPwm1Regs.TBPRD = EPWM_TIMER_TBPRD;           // Set timer period 1500/2 TBCLKs
   EPwm1Regs.TBPHS.half.TBPHS = 0x0000;           // Phase is 0
   EPwm1Regs.TBCTR = 0x0000;                      // Clear counter
   // Set Compare values
   EPwm1Regs.CMPA.half.CMPA = EPWM_CMPAB;     // Set compare A value
//   EPwm1Regs.CMPB = EPWM_CMPAB;               // Set Compare B value
   // Setup counter mode
   EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up down
   EPwm1Regs.TBCTL.bit.PHSEN = TB_ENABLE;        // enable phase loading   use for sync
   EPwm1Regs.TBCTL.bit.PHSDIR=TB_UP;
   EPwm1Regs.TBCTL.bit.SYNCOSEL=TB_SYNC_IN;
   EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV2+TB_DIV4+TB_DIV4;       // TBClock ratio = SYSCLKOUT/(2*HSPCLKDIV*
   EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;                //                                                   2^CLKDIV)
   // Setup shadowing
   EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
//   EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
   EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;  // Load on Zero
//  EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
   // Set actions
   EPwm1Regs.AQCTLA.bit.CAU = AQ_SET;             // Set PWM1A on event A, up count
   EPwm1Regs.AQCTLA.bit.CAD = AQ_CLEAR;           // Clear PWM1A on event A, down count
  // EPwm1Regs.AQCTLB.bit.CAU = AQ_CLEAR;             //Clear  PWM1B on event A, up count
  // EPwm1Regs.AQCTLB.bit.CAD = AQ_SET;           //  Set PWM1B on event A, down count
   // Set DeadBand
   EPwm1Regs.DBCTL.bit.IN_MODE=DBA_ALL;
   EPwm1Regs.DBCTL.bit.POLSEL=DB_ACTV_HIC;
   EPwm1Regs.DBCTL.bit.OUT_MODE=DB_FULL_ENABLE;
   EPwm1Regs.DBRED=Dbred;                                                // Dead-band rising edge delay
   EPwm1Regs.DBFED=Dbfed;                                                // Dead-band falling edge delay
   // Set Trip Zone
   EPwm1Regs.TZSEL.bit.OSHT1=TZ_ENABLE;
   EPwm1Regs.TZCTL.bit.TZA=TZ_FORCE_LO;
   EPwm1Regs.TZCTL.bit.TZB=TZ_FORCE_LO;
   // Interrupt where we will change the Compare Values
   EPwm1Regs.ETSEL.bit.SOCBSEL= ET_CTR_ZERO;      // Select start ADC (EPWMxSOCB) on Zero event
   EPwm1Regs.ETSEL.bit.SOCBEN= Enable;                 // Enable
   EPwm1Regs.ETPS.bit.SOCBPRD=ET_1ST;
复制代码
     主要注意的就是EPWM的死区子模块。由比较器产生A,B个比较信号进入动作限定子模块,并且出来EPWMxA(1)与EPWMxB(1)两路信号,然后进入死区模块。对于死区模块是双输入双输出的,输入为EPWMxA(1)与EPWMxB(1),输出为EPWMxA(2)与EPWMxB(2),其中(2)的信号可以由(1)的其中一个或者两个共同产生。对于我的使用时为了产生SVPWM去控制IPM,因此需要互补信号,只要用EPWMxA(1)去产生EPWMxA(2)与EPWMxB(2)。
zhangmangui 发表于 2016-3-28 22:28 | 显示全部楼层
是分享   啊      感谢
