[STM32F0] 【STM32F072-Discover】+ 过年中的板子
1425|3
 楼主| strong161 发表于 2016-4-6 16:16 | 显示全部楼层 |阅读模式
150过年板中的,一直没有时间玩,
板子功能强大。
先点个最简点的流水灯试试,结果一直不成功,后来才发现flash选错了,默认是STML0的flash
我也一直当它是STM32L072,醉了醉了……错太多!
原来一直用的IAR这次试水MDK确实要麻烦一些!
如果选中了下载到flash就能不在线调试!
int main(void)
    RCC_AHBPeriphClockCmd(LED3_GPIO_CLK|
                          LED4_GPIO_CLK|
                          LED5_GPIO_CLK|
                          LED6_GPIO_CLK,
                            ENABLE);
    GPIO_InitStructure.GPIO_Pin = LED3_PIN|LED4_PIN|LED5_PIN|LED6_PIN;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
    GPIO_InitStructure.GPIO_Speed =  GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    /*GPIO_InitTypeDef BUTTON_InitStructure;
    BUTTON_InitStructure.GPIO_Pin = USER_BUTTON_PIN;
    BUTTON_InitStructure.GPIO_Mode = GPIO_Mode_IN;
    BUTTON_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    BUTTON_InitStructure.GPIO_OType = GPIO_OType_OD;
    BUTTON_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    RCC_AHBPeriphClockCmd(USER_BUTTON_GPIO_CLK,ENABLE);*/
    GPIO_Init(LED3_GPIO_PORT,&GPIO_InitStructure);
   // GPIO_Init(USER_BUTTON_GPIO_PORT,&BUTTON_InitStructure);
    delay_init(48);
  while (1)
        GPIO_SetBits(LED3_GPIO_PORT,LED3_PIN);
        delay_ms(500);
        GPIO_ResetBits(LED3_GPIO_PORT,LED3_PIN);
        delay_ms(500);
        GPIO_SetBits(LED4_GPIO_PORT,LED4_PIN);
        delay_ms(500);
        GPIO_ResetBits(LED4_GPIO_PORT,LED4_PIN);
        delay_ms(500);
        GPIO_SetBits(LED5_GPIO_PORT,LED5_PIN);
        delay_ms(500);
        GPIO_ResetBits(LED5_GPIO_PORT,LED5_PIN);
        delay_ms(500);
        GPIO_SetBits(LED6_GPIO_PORT,LED6_PIN);
        delay_ms(500);
        GPIO_ResetBits(LED6_GPIO_PORT,LED6_PIN);
        delay_ms(500);
ccw1986 发表于 2016-4-6 20:40 | 显示全部楼层
板子的RAM多大,价格便宜吗
ccw1986 发表于 2016-4-6 20:43 | 显示全部楼层
这个芯片的RAM大吗,价格大概是多少?
 楼主| strong161 发表于 2016-4-7 09:26 | 显示全部楼层
这个芯片的RAM大吗,价格大概是多少?
(up to 128 Kbytes of Flash memory and 16 Kbytes of SRAM)
