| #define ZLG7289_pinCLK  (GPIO_PIN_0)  //PE0时钟信号,上升沿有效 #define ZLG7289_pinDIO  (GPIO_PIN_1)   //PE1数据信号,双向
 #define ZLG7289_pinCS  (GPIO_PIN_2)  //PE2片选信号,低电平有效
 #define ZLG7289_pinINT  (GPIO_PIN_7)  //PD7键盘中断请求信号,低电平(负边沿)有效
 #define  WHITE   0
 #define  BLACK   1
 #define  LEDS8   (0xFF<<0) // P1[25:18]控制LED8~LED1,低电平点亮
 //OLED屏测试用变量
 #define   AD0_PIN_NUM    0   //8位数据总线
 #define   RD_PIN_NUM     2    //PE08 读数据/指令控制位,低电平有效
 #define   WR_PIN_NUM     3    //PE09 写数据/指令控制位,高电平变低电平时写入
 #define  DC_PIN_NUM     1    //PE10数据/指令控制位,低电平—指令操作,高电平—数据操作
 #define   RES_PIN_NUM    7   //PE11 复位信号,低电平复位
 #define   CS_PIN_NUM     6   //PE12 使能位,低电平有效
 #define PIN_RD               (   1 <<  2)
 #define PIN_RW               (   1 <<  3)
 #define PIN_DC               (   1 << 1)
 #define PIN_RST              (   1 << 7)
 #define PIN_CS               (   1 << 6)
 #define PINS_CTRL            (0x1F <<  8)
 #define PINS_DATA            (0xFF <<  0)
 #define PINS_ALL             (PINS_CTRL | PINS_DATA)
 /* pin CS  setting to 0 or 1                                                  */
 #define LCD_CS(x)             GPIOC->ODR = (GPIOC->ODR & ~PIN_CS)  | (x ? PIN_CS : 0 );
 /* pin RST setting to 0 or 1                                                   */
 #define LCD_RST(x)            GPIOC->ODR = (GPIOC->ODR & ~PIN_RST) | (x ? PIN_RST : 0);
 /* pin RS setting to 0 or 1                                                   */
 #define LCD_DC(x)             GPIOC->ODR = (GPIOC->ODR & ~PIN_DC)  | (x ? PIN_DC : 0 );
 /* pin RW setting to 0 or 1                                                   */
 #define LCD_RW(x)             GPIOC->ODR = (GPIOC->ODR & ~PIN_RW)  | (x ? PIN_RW : 0 );
 /* pin RD setting to 0 or 1                                                   */
 #define LCD_RD(x)             GPIOC->ODR = (GPIOC->ODR & ~PIN_RD)  | (x ? PIN_RD : 0 );
 /* Reading DATA pins                                                          */
 #define LCD_DATA_IN           (((GPIOB->IDR & PINS_DATA) >> 0) & 0xFF)
 /* Writing value to DATA pins                                                 */
 #define LCD_DATA_OUT(x)       GPIOB->ODR = (GPIOB->ODR & ~PINS_DATA) | (x << 0);
 #define DELAY_2N     0
 char  dispbuff[32];
 unsigned char page;   //显示页面数,0-63行,分为 0-7 个页面
 unsigned char com;   //显示命令
 unsigned char dat;   //显示数据
 unsigned char jj;   //字库查询辅助变量
 unsigned char   w_or_b;
 extern void ExBusInit(void);
 extern uint8 ReadData(void);
 extern void WriteCommand(uint8 Data);
 extern void WriteData(uint8 Data);
 extern void clr_oled(void);
 extern void init_oled(void);
 extern void set_position(uint8 page1,uint8 p1,uint8 col1);
 extern void display_prog(uint8 line,uint8 column,uint8 nn); //显示程序
 extern void dprintf_CHAR12 (uint8 line,uint8 column,char str[20]);
 extern void dprintf_WORD16 (uint8 line,uint8 column,char str[20]);
 extern void dprintf_NUM48(uint8 line,uint8 column,char str[20]);
 extern void disp_float(uint8 row,uint8 col,float x);
 extern void disp_float_1(uint8 row,uint8 col,float x);
 extern void disp_int(uint8 row,uint8 col,uint16 x);
 //**纵向取模,字节倒序
 typedef struct typCHAR_12 // 汉字字模显示数据结构
 uint8 Index[2];
 uint8 Msk[16];
 }typCHAR_12;
 typCHAR_12 const CHAR_12[]={  //16*8 字符
 "1",0x00,0x00,0x20,0x20,0xF8,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x1F,0x10,0x10,0x00,
 "2",0x00,0x30,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x18,0x14,0x12,0x11,0x10,0x18,0x00,
 "3",0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x0C,0x10,0x10,0x10,0x11,0x0E,0x00,
 "4",0x00,0x80,0x40,0x20,0xF8,0x00,0x00,0x00,0x00,0x03,0x02,0x12,0x1F,0x12,0x12,0x00,
 "5",0x00,0xF8,0x88,0x48,0x48,0x48,0x88,0x00,0x00,0x0C,0x10,0x10,0x10,0x10,0x0F,0x00,
 "6",0x00,0xE0,0x10,0x88,0x88,0x98,0x00,0x00,0x00,0x0F,0x11,0x10,0x10,0x10,0x0F,0x00,
 "7",0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,
 "8",0x00,0x70,0x88,0x88,0x88,0x88,0x70,0x00,0x00,0x0E,0x11,0x10,0x10,0x11,0x0E,0x00,
 "9",0x00,0xF0,0x08,0x08,0x08,0x90,0xE0,0x00,0x00,0x00,0x19,0x11,0x11,0x08,0x07,0x00,
 "0",0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x07,0x08,0x10,0x10,0x08,0x07,0x00,
 ".",0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,
 "a",0x00,0x20,0x90,0x50,0x50,0xE0,0x00,0x00,0x00,0x03,0x04,0x04,0x04,0x07,0x04,0x00,
 "b",0x02,0xFE,0x20,0x10,0x10,0x10,0xE0,0x00,0x00,0x07,0x04,0x04,0x04,0x04,0x03,0x00,
 "c",0x00,0xC0,0x20,0x10,0x10,0x10,0x20,0x00,0x00,0x01,0x02,0x04,0x04,0x04,0x02,0x00,
 "d",0x00,0xE0,0x10,0x10,0x10,0x12,0xFE,0x00,0x00,0x03,0x04,0x04,0x04,0x02,0x07,0x04,
 "e",0x00,0xE0,0x50,0x50,0x50,0x50,0x60,0x00,0x00,0x03,0x04,0x04,0x04,0x04,0x02,0x00,
 "f",0x00,0x10,0x10,0xFC,0x12,0x12,0x06,0x00,0x00,0x04,0x04,0x07,0x04,0x04,0x00,0x00,
 "g",0x00,0xB0,0x48,0x48,0x48,0x38,0x08,0x00,0x00,0x06,0x09,0x09,0x09,0x09,0x06,0x00,
 "h",0x02,0xFE,0x20,0x10,0x10,0x10,0xE0,0x00,0x04,0x07,0x04,0x00,0x00,0x04,0x07,0x04,
 "i",0x00,0x10,0x16,0xF6,0x00,0x00,0x00,0x00,0x00,0x04,0x04,0x07,0x04,0x04,0x00,0x00,
 "k",0x02,0xFE,0x80,0x40,0xB0,0x10,0x10,0x00,0x04,0x07,0x04,0x00,0x05,0x06,0x04,0x00,
 "l",0x00,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,0x00,0x04,0x04,0x07,0x04,0x04,0x00,0x00,
 "m",0x10,0xF0,0x10,0xF0,0x10,0xE0,0x00,0x00,0x04,0x07,0x00,0x07,0x00,0x07,0x04,0x00,
 "n",0x10,0xF0,0x20,0x10,0x10,0x10,0xE0,0x00,0x04,0x07,0x04,0x00,0x00,0x04,0x07,0x04,
 "o",0x00,0xC0,0x20,0x10,0x10,0x20,0xC0,0x00,0x00,0x01,0x02,0x04,0x04,0x02,0x01,0x00,
 "p",0x08,0xF8,0x10,0x08,0x08,0x08,0xF0,0x00,0x08,0x0F,0x0A,0x02,0x02,0x02,0x01,0x00,
 "q",0x00,0xF0,0x08,0x08,0x08,0x08,0xF8,0x00,0x00,0x01,0x02,0x02,0x02,0x09,0x0F,0x08,
 "r",0x10,0x10,0xF0,0x20,0x10,0x10,0x30,0x00,0x04,0x04,0x07,0x04,0x04,0x00,0x00,0x00,
 "s",0x00,0x60,0x90,0x90,0x90,0x30,0x00,0x00,0x00,0x06,0x04,0x04,0x04,0x03,0x00,0x00,
 "t",0x00,0x10,0x10,0xFC,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x03,0x04,0x04,0x00,0x00,
 "u",0x10,0xF0,0x00,0x00,0x00,0x10,0xF0,0x00,0x00,0x03,0x04,0x04,0x04,0x02,0x07,0x04,
 "v",0x10,0x30,0xD0,0x00,0x00,0xD0,0x30,0x10,0x00,0x00,0x01,0x06,0x01,0x00,0x00,0x00,
 "w",0x10,0xF0,0x00,0xF0,0x00,0xF0,0x10,0x00,0x00,0x00,0x07,0x00,0x07,0x00,0x00,0x00,
 "x",0x00,0x10,0x30,0xC0,0xD0,0x30,0x10,0x00,0x00,0x04,0x06,0x05,0x01,0x06,0x04,0x00,
 "y",0x08,0x18,0xE8,0x00,0x80,0x68,0x18,0x08,0x08,0x08,0x08,0x07,0x01,0x00,0x00,0x00,
 "z",0x00,0x30,0x10,0x90,0x50,0x30,0x10,0x00,0x00,0x04,0x06,0x05,0x04,0x04,0x06,0x00,
 "_",0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
 "/",0x00,0x00,0x00,0xE0,0x18,0x07,0x00,0x00,0x00,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,
 ":",0x00,0x00,0x00,0x60,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x0C,0x00,0x00,0x00,
 " ",0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
 ">",0x00,0x00,0x40,0x40,0x80,0x80,0x00,0x00,0x01,0x01,0x05,0x05,0x03,0x03,0x01,0x01,
 "<",0x00,0xFC,0x07,0x07,0x04,0xF8,0x00,0x00,0x10,0x9F,0xF0,0x90,0xF0,0x9F,0x10,0x00,
 "C",0x00,0xF0,0x08,0x08,0x08,0x08,0x38,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x10,0x00,
 "%",0xE0,0x50,0xE0,0x90,0x68,0x14,0x0A,0x00,0x00,0x31,0x0C,0x03,0x0E,0x11,0x0E,0x00,
 "+",0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x0F,0x01,0x01,0x01,
 "-",0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
 ";",0x00,0x00,0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x08,0x04,0x02,0x01,0x00,
 "=",0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
 "L",0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x00,
 "A",0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,
 "B",0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00,
 "O",0xF8,0x04,0x02,0x02,0x02,0x04,0xF8,0x00,0x01,0x02,0x04,0x04,0x04,0x02,0x01,0x00,
 "N",0x00,0x02,0xFE,0x0E,0x70,0x82,0xFE,0x02,0x00,0x04,0x07,0x04,0x00,0x03,0x07,0x00,
 "D",0x00,0x02,0xFE,0x02,0x02,0x02,0x04,0xF8,0x00,0x04,0x07,0x04,0x04,0x04,0x02,0x01,
