[STM32F1] STM32F103C8T6的CAN通信调试问题
7015|6
 楼主| 剡溪渡口 发表于 2016-4-12 20:44 | 显示全部楼层 |阅读模式
CAN通信调试好几天了,被一个问题卡住,用到是3.5的库,发送函数先贴出代码
uint8_t CAN_Transmit(CAN_TypeDef* CANx, CanTxMsg* TxMessage)
  uint8_t transmit_mailbox = 0;
  /* Check the parameters */
  assert_param(IS_CAN_ALL_PERIPH(CANx));
  assert_param(IS_CAN_IDTYPE(TxMessage->IDE));
  assert_param(IS_CAN_RTR(TxMessage->RTR));
  assert_param(IS_CAN_DLC(TxMessage->DLC));
  /* Select one empty transmit mailbox */
  if ((CANx->TSR&CAN_TSR_TME0) == CAN_TSR_TME0)
  else if ((CANx->TSR&CAN_TSR_TME1) == CAN_TSR_TME1)
    transmit_mailbox = 1;
  else if ((CANx->TSR&CAN_TSR_TME2) == CAN_TSR_TME2)
    transmit_mailbox = 2;
  else
    transmit_mailbox = CAN_TxStatus_NoMailBox;
  if (transmit_mailbox != CAN_TxStatus_NoMailBox)
    /* Set up the Id */
    CANx->sTxMailBox[transmit_mailbox].TIR &= TMIDxR_TXRQ;
    if (TxMessage->IDE == CAN_Id_Standard)
      assert_param(IS_CAN_STDID(TxMessage->StdId));
      CANx->sTxMailBox[transmit_mailbox].TIR |= ((TxMessage->StdId << 21) | \
                                                  TxMessage->RTR);
    else
      assert_param(IS_CAN_EXTID(TxMessage->ExtId));
      CANx->sTxMailBox[transmit_mailbox].TIR |= ((TxMessage->ExtId << 3) | \
                                                  TxMessage->IDE | \
                                                  TxMessage->RTR);
    /* Set up the DLC */
    TxMessage->DLC &= (uint8_t)0x0000000F;
    CANx->sTxMailBox[transmit_mailbox].TDTR &= (uint32_t)0xFFFFFFF0;
    CANx->sTxMailBox[transmit_mailbox].TDTR |= TxMessage->DLC;
    /* Set up the data field */
    CANx->sTxMailBox[transmit_mailbox].TDLR = (((uint32_t)TxMessage->Data[3] << 24) |
                                             ((uint32_t)TxMessage->Data[2] << 16) |
                                             ((uint32_t)TxMessage->Data[1] << 8) |
                                             ((uint32_t)TxMessage->Data[0]));
    CANx->sTxMailBox[transmit_mailbox].TDHR = (((uint32_t)TxMessage->Data[7] << 24) |
                                             ((uint32_t)TxMessage->Data[6] << 16) |
                                             ((uint32_t)TxMessage->Data[5] << 8) |
                                             ((uint32_t)TxMessage->Data[4]));
    /* Request transmission */
    CANx->sTxMailBox[transmit_mailbox].TIR |= TMIDxR_TXRQ;
  return transmit_mailbox;
分别查询空闲发送信箱后,transmit_mailbox最后为4,导致后续无法继续发送,是因为发送完成过后缺少清空信箱的操作导致最后没有空闲信箱吗?
在transmit_mailbox为0,1,2,4时读取CAN_TSR寄存器的值分别是0x1c000000,0x19000008,0x52000008,0x82000008,一直提示TERR0=1,邮箱0因为出错导致发送失败
不知道是什么原因
楼主问题解决了吗? 遇到一样的问题,回环测试是ok的  发表于 2021-1-14 22:08
 楼主| 剡溪渡口 发表于 2016-4-15 09:14 | 显示全部楼层
哪位大神能指点一下迷津
M.gtd 发表于 2016-4-16 15:25 | 显示全部楼层
can通讯必须联网调试,否则没有ack信号,触发错误,所以节点配置需要多加注意
xmshao 发表于 2016-4-16 18:14 | 显示全部楼层
先用LOOPBACK模式测试 验证软件配置方面没问题;
然后做NORMAL模式验证,此事硬件一定都要要接好,包括匹配电阻。
vitasnokia 发表于 2019-1-2 18:02 | 显示全部楼层
楼主 你好 请问这个问题你解决了吗 可以通过qq 773464872 沟通吗 谢谢你了
zchong 发表于 2021-1-15 08:00 来自手机 | 显示全部楼层
两端都要搞起
