[技术问题解答] Ltib编译出错:gnome-desktop安装通不过
826|0
 楼主| uusoso 发表于 2016-4-15 08:04 | 显示全部楼层 |阅读模式
各位大侠,小弟编译ltib时,报如下错误,按照网上的方法,安装了一些东西,但没成功。请问我该怎样做才能让其编译通过?
Processing: gnome-desktop
Build path taken because: directory build, build key set, no prebuilt rpm,
checking for XLIB... yes
checking for GNOME_DESKTOP... configure: error: Package requirements (libxml-2.0 >= 2.4.20 gdk-pixbuf-2.0 >= 2.4.0 gtk+-2.0 >= 2.11.3 glib-2.0 >= 2.15.4 gio-2.0 >= 2.15.4 libgnomeui-2.0 >= 2.6.0 gconf-2.0 >= 2.0.0 ) were not met:
No package 'libgnomeui-2.0' found
No package 'gconf-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables GNOME_DESKTOP_CFLAGS
and GNOME_DESKTOP_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
error: Bad exit status from /home/uu/ltib_install/ltib/tmp/rpm-tmp.12779 (%build)
RPM build errors:
Build time for gnome-desktop: 5 seconds
Failed building gnome-desktop
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Fri Apr 15 08:00:21 2016
Ended:   Fri Apr 15 08:00:32 2016
Elapsed: 11 seconds
These packages failed to build:
gnome-desktop
Build Failed
Exiting on error or interrupt
