双口ram
1035|12
 楼主| kangzj 发表于 2016-4-15 22:14 | 显示全部楼层 |阅读模式
读写数据一直不成功
zwll 发表于 2016-4-15 22:15 | 显示全部楼层
源代码
 楼主| kangzj 发表于 2016-4-15 22:17 | 显示全部楼层
parameter idle=2'b00;
parameter write_state=2'b01;
parameter read_state=2'b10;
reg [1:0]current_state;
reg [1:0]next_state;
reg [1:0]cnt;
reg [9:0]init_cnt;
always@(posedge clk or negedge rst_n)
begin
if(!rst_n)
current_state<=idle;
else
current_state<=next_state;
end
always@(*)
begin
case(current_state)
  idle:begin
    if(init_cnt==10'd1023)
     next_state=write_state;
   else
   next_state<=idle;
   end
  write_state:begin
   if((addr==17'h1fffe)&(cnt==2'b11))
    next_state<=read_state;
   else
    next_state<=write_state;
  end
  read_state:begin
    next_state<=idle;
   else
  end
  default:
   next_state<=idle;
    endcase
end
always@(posedge clk or negedge rst_n)begin
if(!rst_n)begin
addr<=17'h0;
oe<=1'b1;
wr<=1'b1;
cnt<=2'b0;
init_cnt<=10'h0;
end
else begin
case(current_state)
idle:begin
    addr<=17'h0;
    oe<=1'b1;
    wr<=1'b1;
  ce<=1'b1;
    write_data<=8'h0;
    read_data<=8'h0;
    init_cnt<=10'd1023;
    else
   init_cnt<=init_cnt+1;
    end
  write_state:begin
   cnt<=cnt+1;
   ce<=1'b0;
   if(cnt==2'b00)begin
    wr<=1'b0;
   end
   else if(cnt==2'b01)begin
    wr<=1'b1;
   end
   else if(cnt==2'b10)begin
    ce<=1'b1;
   end
   else if(cnt==2'b11)begin
       if(addr==17'h1fffe)begin
    addr<=17'h0;
    cnt<=2'b0;
    write_data<=8'h0;
    end
    else begin
      addr<=addr+1;
    write_data<=8'h5a;//write_data+1;
    ce<=1'b0;
      cnt<=2'b0;
    end
   end
   end
   read_state:begin
    cnt<=cnt+1;
    wr<=1'b1;
    if(cnt==2'b00)begin
    ce<=1'b0;
   end
    oe<=1'b0;
   end
    read_data<=dpram_data;
    oe<=1'b1;
   end
    addr<=17'h0;
    cnt<=2'b0;
    end
   else begin
    addr<=addr+1;
     //addr<=17'h0;
    ce<=1'b1;
    cnt<=2'b00;
   end
   end
  end
default:begin
          addr<=17'h0;
        oe<=1'b1;
    ce<=1'b1;
        wr<=1'b1;
        end
       endcase
      end
     end
assign dpram_ce=ce;
assign dpram_oe=oe;
assign dpram_wr=wr;
assign dpram_addr=addr;
assign dpram_data=(~wr)?write_data:8'hzzzz;
chuxh 发表于 2016-4-15 22:18 | 显示全部楼层
仿真图也一并发上来吧
 楼主| kangzj 发表于 2016-4-15 22:19 | 显示全部楼层
 楼主| kangzj 发表于 2016-4-15 22:23 | 显示全部楼层
juventus9554 发表于 2016-4-15 22:24 | 显示全部楼层
顺序是?
 楼主| kangzj 发表于 2016-4-15 22:25 | 显示全部楼层
图的顺序是读操作和写操作
 楼主| kangzj 发表于 2016-4-15 22:26 | 显示全部楼层
已经好用了 :P
司徒老鹰 发表于 2016-4-15 22:29 | 显示全部楼层
怎么解决的啊
 楼主| kangzj 发表于 2016-4-15 22:30 | 显示全部楼层
芯片有个sem端口,需要把它置高,我们硬件的把它浮空了,上拉后就好了
llljh 发表于 2016-4-15 22:31 | 显示全部楼层
 楼主| kangzj 发表于 2016-4-15 22:32 | 显示全部楼层
哈哈,结贴了哈
