【TI DSP分享季】+TMS320C6678高性能定-浮点DSP
1232|7
zhangmangui|  楼主 | 2016-4-18 22:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TMS320C6678主要特性:
• Eight SMS320C66x™ DSP Core Subsystems (C66x CorePacs), Each with
– 1.0 GHz C66x Fixed/Floating-Point CPU Core
› 44.8 GMAC/Core for Fixed Point @ 1 GHz
› 22.4 GFLOP/Core for Floating Point @ 1 GHz
– Memory
› 32K Byte L1P Per Core
› 32K Byte L1D Per Core
› 512K Byte Local L2 Per Core
• Multicore Shared Memory Controller (MSMC)
– 4096KB MSM SRAM Memory Shared by Eight DSP C66x CorePacs
– Memory Protection Unit for Both MSM SRAM and DDR3_EMIF
• Multicore Navigator
– 8192 Multipurpose Hardware Queues with Queue Manager
– Packet-Based DMA for Zero-Overhead Transfers
• Network Coprocessor
– Packet Accelerator Enables Support for
› Transport Plane IPsec, GTP-U, SCTP, PDCP
› L2 User Plane PDCP (RoHC, Air Ciphering)
› 1-Gbps Wire-Speed Throughput at 1.5 MPackets Per Second
– Security Accelerator Engine Enables Support for
› IPSec, SRTP, 3GPP, WiMAX Air Interface, and SSL/TLS Security
› ECB, CBC, CTR, F8, A5/3, CCM, GCM, HMAC, CMAC,
GMAC, AES, DES, 3DES, Kasumi, SNOW 3G, SHA-1, SHA-2 (256-bit Hash), MD5
› Up to 2.8 Gbps Encryption Speed
• Peripherals
– Four Lanes of SRIO 2.1
› 1.24/2.5/3.125/5 GBaud Operation Supported Per Lane
› Supports Direct I/O, Message Passing
› Supports Four 1×, Two 2×, One 4×, and Two 1× +One 2× Link Configurations
– PCIe Gen2
› Single Port Supporting 1 or 2 Lanes
› Supports Up To 5 GBaud Per Lane1
› Supports up to 3.125 GBaud Per Lane in Extended
Temperature Range of - 55°C to 115°C
– HyperLink
› Supports Connections to Other KeyStone Architecture Devices Providing Resource
Scalability
› Supports up to 25 Gbaud
– Gigabit Ethernet (GbE) Switch Subsystem
› Two SGMII Ports
› Supports 10/100/1000 Mbps Operation
– 64-Bit DDR3 Interface (DDR3-1600)
› 8G Byte Addressable Memory Space
› DDR3 functionally tested for extended temperature range of - 55°C to 115°C
› Some Noted Parameters Specified for - 40°C to 105°C Only
– 16-Bit EMIF
– Two Telecom Serial Ports (TSIP)
› Supports 1024 DS0s Per TSIP
› Supports 2/4/8 Lanes at 32.768/16.384/8.192 Mbps Per Lane
– UART Interface
– I2C Interface
– 16 GPIO Pins
– SPI Interface
– Semaphore Module
– Sixteen 64-Bit Timers
– Three On-Chip PLLs
• Extended Temperature:
– - 55°C to 115°C
TMS320C6678应用:
• Mission-Critical Systems
• High-Performance Computing Systems
• Communications
• Audio
• Video Infrastructure
• Imaging
• Analytics
• Networking
• Media Processing
• Industrial Automation
• Automation and Process Control
zhangmangui|  楼主 | 2016-4-18 22:55 | 只看该作者
20140925110240506.pdf (1.1 MB)
SM320C6678-HIREL.pdf (2.07 MB)
TMDSEVM6678L EVM.pdf (1.23 MB)
TMDSEVM6678Lx_EVM_REV_3_0_DSN.pdf (1.1 MB)
zhangmangui|  楼主 | 2016-4-18 22:56 | 只看该作者
TMDSEVM6678L_QSG_1.0_L.pdf (526.18 KB)
TMDSEVM6678L_Technical_Reference_Manual_2V01_0320.pdf (1.23 MB)
LearningASM| | 2016-4-19 16:16 | 只看该作者
22.4 GFLOP/Core for Floating Point @ 1 GHz是单精度的还是双精度的,或者扩展精度的?
个人签名:欢迎进入【TI DSP 论坛】 & 【DSP 技术】           TI忠诚粉丝!
935
