[应用相关] swd下载出错求解决
674|2
 楼主| Brand2 发表于 2016-4-25 19:15 | 显示全部楼层 |阅读模式
我用了三根线分别接到swdio swdclk  gnd  但是一直有一个这样的错误
* JLink Info: STM32F1xxx: Can not attach to CPU. Trying connect under reset.
**JLink Warning: RESET (pin 15) high, but should be low. Please check target hardware.
***JLink Error: Supply voltage too low (1 Volt is required, Measured: 0.8 Volt).
Please check target power.
请问如何解决?
Garen2 发表于 2016-4-25 19:31 | 显示全部楼层
BOOT设置正确吗?
戈卫东 发表于 2016-4-25 19:34 | 显示全部楼层
目标板没有电?
